Old 15-08-2007, 05:56 PM   #1 (permalink)
The Sexy Beast
Default Micro SD card problem
yesterday i formatted my 2gb micro sd card and found that it now supports only 1.42gb instead of the 1.9gb i was getting till yesterdayi have this card for over two months now.
also in my 5300 music player whenever it starts for the first time it takes almost 4min to start and about 2min to switch categories like from albums to artists.it used to work fine in the beginning without not more than a second delay
ratedrsuperstar is offline
Old 15-08-2007, 07:15 PM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: Micro SD card problem
Moral of the story: Don't buy cheap unbranded memory cards. Always buy original, even if you've to pay more.
Old 15-08-2007, 07:26 PM   #3 (permalink)
run a scandisk with a usb card reader and reformat...it might work
a ship is safest at the harbour but thats not what its built for!
serendipiti is offline
Old 15-08-2007, 07:47 PM   #4 (permalink)
Google Bot
Pathik's Avatar
format ur cell once.. And ur micro sd again too..
Pathik is offline
Old 15-08-2007, 10:07 PM   #5 (permalink)
The Sexy Beast
i have transcend original card i will take it for replacement
i don't know how to format my 5300 there is no option other than restore factory settings
Old 15-08-2007, 10:35 PM   #6 (permalink)
Wandering in time...
Ankur Gupta's Avatar
*#7370# will format your phone...
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 15-08-2007, 10:37 PM   #7 (permalink)
Noobie Pro
alsiladka's Avatar
*#7370# is nothing but the code for "restore factory settings".
Try to format it once on the pc using the Mass Storage mode.
www.twitter.com/alsiladka
alsiladka is offline
Old 16-08-2007, 07:45 AM   #8 (permalink)
krazyfrog
Posts: n/a
^^ Nope. *#7370# is a code for formatting the phone. *#7780# is the code to restore factory settings. The first code, however only works in Nokia's smartphones. You cannot format the phone memory of 5300.
Old 18-08-2007, 02:43 PM   #9 (permalink)
The Sexy Beast
should i get the phone replaced too coz it seems it hasn't slowed down only the opening app or playing file animation gets stuck and this causes the delay
Old 18-08-2007, 06:12 PM   #10 (permalink)
Still learning...
He28's Avatar
I was facing similar issue and guys at Digit Forum suggested me to format the Memory Card using USB card reader. Make a Complete Format using FAT file system (not FAT32). Once the formatting is done successfully, immidiately run ScanDisk. This may help you.
All the best.
People laugh at me because I am different...,
I laugh at them because they all are the same...
This is... attitude!
He28 is offline
Help needed for micro SD card mahip7 Hardware Q&A 5 07-08-2007 06:01 PM
Micro SD memory card JohnephSi Mobiles and Tablets 5 26-06-2007 02:30 PM
Diff between MS Pro Duo & Micro?? hareesh Mobiles and Tablets 2 26-11-2006 12:23 PM
My new Creative Zen Micro 5GB grooveman Software Q&A 6 12-05-2005 03:49 PM
