Old 15-07-2007, 12:39 AM   #1 (permalink)
Default New Mobile Using Two Technologies Simultaneously.
hello guys their is one Mobile Phone manufactured by samsung, it came on ndtv india and last months my mobile magazine also 1 reader mentioned it, It has both the technologies GSM and CDMA 2000, one can switch fromm Airtel to rim/tata and vice versa, does any one know its model no.thanks, it has not yet come in india.
Necessity is the mother of Invention
NiluGeek is offline
Old 04-08-2007, 09:33 AM   #2 (permalink)
Default Re: New Mobile Using Two Technologies Simultaneously.
Spice has also launched such phone.
One which allows you to insert two GSM sims in the same phone at same time and the other which allows you to insert one CDMA and one GSM SIM at same time , and it costs just Rs. 9849(MRP when it is launched_ and price would fall very shortly
ThinkFree is offline
Old 04-08-2007, 10:22 AM   #3 (permalink)
Google Bot
Pathik's Avatar
its the samsung duo.. available for 10k..
Pathik is offline
Old 04-08-2007, 10:56 AM   #4 (permalink)
AJJU
azzu's Avatar
yup samsung dou with tata indicom
I love and Live to Design
azzu is offline
Old 05-08-2007, 01:24 PM   #5 (permalink)
Hello guys
samsung duo is not a good phone, secondly you have to compulsorily take tata indicom network, which is not fair,there should be a handset which can use two gsm technologies simultaneously, right now there is scope for cdma and gsm only...............
NiluGeek is offline
Old 05-08-2007, 05:19 PM   #6 (permalink)
Wandering in time...
Ankur Gupta's Avatar
I guess Spice ones dont have such restriction...
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 05-08-2007, 09:39 PM   #7 (permalink)
Spice d88 is a dual technology phone with one slot for GSM sim and other for CMDA. Spice D80 has two sim slots both of which are for GSM sims. But not knowing if both connections can work at the same time or not
Old 06-08-2007, 05:24 PM   #8 (permalink)
I think you can operate only one connection at a given time. It lets you choose between which network to choose when you want to make a call. Also it shows when you recieve a call which network it is coming from. I don't think that it will let you use both networks simultaneously. Somebody already using the phone can tell you better.
Anyone who has never made a mistake has never tried anything new
sandeepk is offline
Old 06-08-2007, 05:50 PM   #9 (permalink)
Isnt the same available in Nokia 6233 also?
If u think u r right...u r a bad thinker!
Jatin_T is offline
Old 06-08-2007, 05:52 PM   #10 (permalink)
Boom Boom Boom
cooldudie3's Avatar
Unhappy Re: New Mobile Using Two Technologies Simultaneously.
i never seen that before
no not in nokia 6233!!!
I'm back! Gimme a hugggggg...
cooldudie3 is offline
Old 06-08-2007, 11:07 PM   #11 (permalink)
No this is about a series of phones launched which support 2 sim cards. Nokia 6233 does not support this. These type of phones are just launched in India.
sandeepk is offline
Old 07-08-2007, 06:43 PM   #12 (permalink)
Boom Boom Boom
cooldudie3's Avatar
o
it only comes in india
lool
How to listen to 2 different songs using headphone and speaker simultaneously? Ray Mobiles and Tablets 27 29-05-2007 11:03 PM
Running simultaneously Windows...??? chahal63 Software Q&A 3 04-01-2007 11:39 PM
Wi-fi can i use UL 900 simultaneously?? NagpurDaMunda QnA (read only) 10 30-12-2006 08:02 AM
using 2 internet connections simultaneously on pc nirubhai Internet & WWW 11 09-11-2006 07:45 PM
Mobile Technologies ravimevcha Tutorials 1 12-05-2005 11:36 AM
