| Forum |
| Buying Advice Sub-section for Buying Advice queries. |
#1 (permalink) |
Tribal Boy
All the time while buying mobile phones, making calls was the last thing for me. I use my mobile for GPRS / EDGE / Camera. Now I need a phone (5K is enough I think) for my wife. Exclusively for making / receiving calls. Even GPRS is not needed. Need some model that is of good build quality, reliable, then good looks too. Will I get a clam shell (or whetever it is called, you got what I meant rt ? lol) for 5K ? Please suggest. Thanks in advance .... |
#2 (permalink) |
The G-Axe Effect
Check relience's offerings, they got cheap calling rate for relience to relience
in GSM, best & no nonsence phone is Nokia 1100 or SE J200i
Graphics & Web Designer - SlideShare Portfolio & Blog : http://gxsaurav.com |
#3 (permalink) |
Tribal Boy
No, I have a Excel Anant Sim. So need a phone anyway (I mean can't go for CDMA) .
Among Nokia 1100 and SE J200i which will be better ? Or as both are basic models, nothing much difference ? |
#5 (permalink) |
Wire muncher!
a moto w205 or nokia 1112 should be enough for the requirements u'v mentioned. both are available for abt 1.6k. why spend 5k for a phone which is used for jus making calls and nothing else?
if u wanna go in for a clamshell u may consider samsung x160 or moto w220. both available for abt 2.6k.
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
#6 (permalink) |
The G-Axe Effect
How about that Motorola "Yeh sirf dikhta mahanga hai" Phone
#8 (permalink) |
* Teh Flirt King *
I suggest Motorola w220...
My friend has it... It looks cool, and expensive. Very cheap considering its build quality and design.
World is just a Quizzical Reality : Quiz_Master//Ashwin Blog: http://ashwinsaxena.com/blog - Tech, Life and Other Things. |
#10 (permalink) |
Tribal Boy
On a second thought ..
infra_red_dude is right. Why should I spend 5K, I think I will go for N 1112. Anyway I have SE K 550i, so all other needs, I can use that. Thanks a lot friends - for your suggestions. |
#13 (permalink) |
Wire muncher!
^^^ completely my personel opinion but, the screen build of 1112 seems better than 1600.
#15 (permalink) | |
Wire muncher!
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com Last edited by infra_red_dude; 11-07-2007 at 09:15 PM. |
#17 (permalink) |
Wire muncher!
yeah the only thing they've changed in 1600 is the screen - colour. otherwise everything is same. to keep the costs low, imo they've put in a very low quality screen. i'd prefer 1112 anyday to n1600.
#21 (permalink) |
Tribal Boy
Hmm, no, not 1600. Didn't like it at all.
6030 ? No, never, build quality is very poor. My Dad use N1112, so far no problems, mostly will go for that itself. Will buy it tomo. Thank you again friends. |
#22 (permalink) |
The G-Axe Effect
din, have a look at Pink J200i. Madam will sure like it
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| suggest a ringtone for my new n70 mobile phone | arunks | Buying Advice | 17 | 14-01-2007 08:37 PM |
| SUggest A Mobile Phone Exclusively for Accessing Internet On PC | NiluGeek | Buying Advice | 3 | 01-01-2007 01:31 AM |
| Plz suggest a Mobile Phone for me | gkiran | Buying Advice | 7 | 23-09-2006 02:02 PM |
| Suggest Mobile Phone | sweet.grrll | Buying Advice | 10 | 04-09-2006 02:59 AM |
| SUGGESTIONS : Pls Suggest a MOBILE phone under 8K | Vishal Gupta | Buying Advice | 20 | 06-04-2006 09:02 PM |
