Old 10-07-2007, 09:16 AM   #1 (permalink)
abhishekkulkarni's Avatar
Default A problem with the Nokia 5700
I've bought a Nokia 5700 a few days ago. The moment I got the phone I began fiddling with its features.
The phone is awesome and beats the entire N series hands down when it comes to value for money, but there's a small problem - whenever I try to install any .sis Symbian application through PC Suite, the phone gives me the following error - "Installation of filename.sis not supported".
I've been an Ericsson user till now and hence I don't know much about the Symbian OS and its tweaks. Please help me with the above problem..
May the source be with you ..
abhishekkulkarni is offline
Old 10-07-2007, 09:46 AM   #2 (permalink)
Rockin g33k
dreamcatcher's Avatar
Default Re: A problem with the Nokia 5700
dnt install thru pc suite just take the installation file inside the phone thru data transfer mode and then install in frm the phone itself...pc suite does create sum problems sumtimes...and dude..same here..was a sony ericsson all the while..but those paple realy cudnt live up to my xpectsations so i had to buy this..will be selling it off as he w960 or k850 hits the stores..
My blog-www.rayarunava.com
dreamcatcher is offline
Old 10-07-2007, 12:39 PM   #3 (permalink)
Noobie Pro
alsiladka's Avatar
That is not the issue. Nokia 5700 is a Symbian OS 9.2 phone, which is the S60v3 FP1. It does not support installation of S60v2 softwares. All the softwares need to be recoded using the new APIs and format.
Most of the softwares have been updated to support S60v3.
www.twitter.com/alsiladka
alsiladka is offline
Old 11-07-2007, 10:26 AM   #4 (permalink)
@alsiladka
Ok. Thanks a ton.
XFX 5700 le - Problem help? ganesh_2218 Hardware Q&A 1 09-11-2005 12:54 AM
FX 5200 to gfx 5700 medigit Graphic cards 4 06-06-2005 10:58 AM
FX 5200 256 MB or FX 5700 LE 128 MB??? shwetanshu QnA (read only) 8 30-12-2004 11:56 PM
Wanna know how to convert a 5700 LE into 5700 ultra ? regenade QnA (read only) 6 16-11-2004 11:36 AM
