| Forum |
| Buying Advice Sub-section for Buying Advice queries. |
#1 (permalink) |
however when i plug in the headphone( provided with it) in the same slot it sometimes show "Enhancement not supported" but works 90% in all cases however nowadays the data cable work depending upon probability,ie it may show sometimes or it may not work .Recently when i pressed it hard against the phone it rebooted it What should I do? |
#2 (permalink) |
~[::BOoYaKa::]~
Strange! My 7610 is working absolutely fine, no problem like that... It may be a faulty piece... If the phone is under warranty take it to the Nokia doc, they might replace it...
[::Eddie n Benoit Live Forever::] |
#4 (permalink) |
I too had the same data cable problem in my Nokia 3230, it would not display the USB icon on the phone and would give me that message about malfunction..
I changed the data cable and things were fine after that..May be you should try the same.. About the headset thing, a friend of mine has this trouble, the phone (7610) doesn't recognize the enhancement, but that gets corrected only if he uses a single earpiece headset..
________________________________________________ In love with my Mac ________________________________________________ |
#5 (permalink) | |
Exactly exactly thats what i think,because if my phone had a problem no attachment should work ,i will try that. in fact i noticed today that in the phone end of the cable ,one pin is very shorter than other ie it looks like it has been pushed inside .i think it may be malfunction by the way they give single earpiece by default |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Nokia 7610 and 1GiG RS-MMC | REY619 | Mobiles and Tablets | 11 | 10-07-2007 08:00 PM |
| Formatting Nokia 7610 | Garbage | Mobiles and Tablets | 3 | 20-02-2007 06:45 PM |
| Anyone using a 1GB RS MMC with a NOKIA 7610 | beaditya | Mobiles and Tablets | 21 | 04-11-2005 07:44 AM |
| NOKIA 7610 FM Radio | stalin | Mobiles and Tablets | 4 | 07-05-2005 01:06 AM |
| MMS Problem in Nokia 7610 | siddhesh | QnA (read only) | 8 | 05-03-2005 08:21 PM |
