Old 28-04-2007, 01:18 AM   #1 (permalink)
Default Plz Suggest me Mobile with good signal capability
Hi
Currently i am using Nokia6233.Music wise it is a good phone but signal is that good. If any body is using just tell me how is the signal strength? Now i am planning to change my mobile plz suggest me the good mobile with good signal and good Audio(Music).
Thanks in Advance.
jrsc is offline
Old 28-04-2007, 01:24 AM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: Plz Suggest me Mobile with good signal capability
well buddy.. my fren uses it and there has been no probs wid signal. in fact any phone of today doesn't haf any signal probs. there must be a problem wid the operator or wid the phone's antenna. get it checked.
as for ur second Q, the forum is full of Qs on that. search.....
infra_red_dude is offline
Old 28-04-2007, 01:58 AM   #3 (permalink)
Tech.Masti's Avatar
^^^ ya, Nokia phones signal receiving capacity is best, you may have problem with your operator or phone....
Tech.Masti is offline
Old 29-04-2007, 08:11 AM   #4 (permalink)
No you can't increase your signal strength......
As it is decided automatically. It's a GSM technology function.
When you are near to the Base station in perticular cell then the base station tells your mobile to reduce you transmitting power. And if you are far from base station than you mobile transmitter automatically strengthen its signal.
Understand that the antenna is a passive device.
It doesn't requied any power to receive the signal. It's all depend on antena construction. And it is standered as per the GSM technology.
Difficulty in receiving the signal suggest that there may be some damage in your phone antenna or other controlling device of your phone.
parimal_xp2003 is offline
Old 30-04-2007, 11:25 AM   #5 (permalink)
Ganeshkumar's Avatar
So Independent of Phones...
The signal strength will be same??
Ganeshkumar is offline
Old 30-04-2007, 01:09 PM   #6 (permalink)
Google Bot
Pathik's Avatar
Nope some fones hav better signal strength than others...
Even the positioning of the internal antenna can make a difference..
Pathik is offline
Old 30-04-2007, 05:08 PM   #7 (permalink)
Wire muncher!
^^^ rarely noticable..... but almost all the mid range phones haf the same receiving capability.... tried and tested!!!
Old 01-05-2007, 04:38 AM   #8 (permalink)
The Techno Perv
well buddy.. it depends on both.. the cell as well as ur network.. as far as i know, 6233 has very good reception.. all nokia fones do for that matter.. so in ur case i guess its the network provider who is at fault..not the fone
dtox is offline
w810i audio/video capability? PainKiller Mobiles and Tablets 11 19-12-2006 12:15 AM
Any ways to boost weak mobile signal inside house? varun_ag Mobiles and Tablets 4 01-09-2006 03:52 PM
suggest a phone for using Mobile Office in good speed Tech.Masti Buying Advice 10 31-01-2006 06:54 PM
POLL-----what phones have best signal receiving capability Tech.Masti Mobiles and Tablets 9 16-12-2005 04:59 PM
