Old 26-04-2007, 10:23 PM   #1 (permalink)
Default Any suggestions for basic FM phone
Hello friends,
I need a basic, entry-level phone with FM. My budget is maximum Rs.3000/-. Do not need a camera, MP3, Bluetooth, and other fancies.
Features in decreasing order of preference are:
- FM radio (stereo)
- Decent to good battery (at least 2-3 days w/o charging)
- Good reception outside city
- Alarm
- Vibration mode
- Handsfree/speaker
- PC connection (USB)
- Stopwatch
Any views/reviews about the Radiomoto W209. Seems pretty close to what I want but doesn't have USB and not sure about its outside-city reception.
TIA
bacchan is offline
Old 26-04-2007, 10:34 PM   #2 (permalink)
Genius in making mistakes
bhushan05d251's Avatar
Default Re: Any suggestions for basic FM phone
If you extend your budget upto 3.5k then u can get Nokia 6030.
It matches all your requirement.
It has following features
  • High-resolution color display with up to 65,536 colors (128 x 128 pixels)
  • Large, easy-to-use keypad
  • Intuitive, user-friendly interface
  • Multimedia messaging (MMS)
  • FM radio
  • Address book, calendar, and reminders
  • Xpress-on™ covers
bhushan05d251 is offline
Old 26-04-2007, 10:37 PM   #3 (permalink)
realfan4ever's Avatar
Moto C168 has all the things other than speaker and pc conectivity. i am using it and its fultoo VFM.
I bought this fone for two things only, 250 SMSs and FM radio. And am fully satified with it.
realfan4ever is offline
Old 26-04-2007, 10:38 PM   #4 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
Motorola C168 is a good phone for you at Rs.2600 but dont have speaker and PC connecting USB.
n00b forever...
~Phenom~ is offline
Old 26-04-2007, 11:07 PM   #5 (permalink)
Tech.Masti's Avatar
6030 have MONO radio, take C168 best in its class, it lacks data connectivity, but good enough battery backup and network reception ...
Tech.Masti is offline
Old 26-04-2007, 11:37 PM   #6 (permalink)
Google Bot
Pathik's Avatar
6030
Pathik is offline
Old 27-04-2007, 01:57 AM   #7 (permalink)
kumarmohit's Avatar
I think you can try Motorola W209 as you suggest
http://indiagsm.com/viewdetails.php?...brand=Motorola
Or you can try to extend your budget a bit and get the MotoFlip W220, The new W series has the cute LED indicators on top too. And its got great FM.
kumarmohit is offline
Old 27-04-2007, 11:27 PM   #8 (permalink)
Wire muncher!
infra_red_dude's Avatar
moto c168 is what i suggest. the reception is very good. a slim phone and well within ur budget. do not buy 6030, its got mono fm. but disadvantage wid c168 is that there's no pc connectivity (why wud u need it anyway?)
infra_red_dude is offline
Old 28-04-2007, 12:45 AM   #9 (permalink)
Even i have the same requirement as the topic starter, as someone stole my Nokia 1108 in bus. I have zeroed in on SE J230i as it also has a speaker phone. I was also considering Radiomoto W209, but it does'nt have gprs.
Shall i get se j230i?
casual_gamer is offline
Old 28-04-2007, 12:47 AM   #10 (permalink)
Wire muncher!
j230i is a good choice. but be forewarned that it doesn't haf an in built modem. meaning, tho u can use the net on phone, u can't connect it to ur pc and browse!
Old 28-04-2007, 01:54 AM   #11 (permalink)
Tech.Masti's Avatar
heard that J230i have memory problem, i.e. if you open SIM then all message ( some times all contacts also ) in phone memory will be erased , dont know its true or not....
Old 28-04-2007, 10:33 AM   #12 (permalink)
Wire muncher!
^^^ not true.
Old 28-04-2007, 02:19 PM   #13 (permalink)
nix
Senior Member
nix's Avatar
acutally the motorola W208, W209 seem to be quite good...problem is they are released newly and no one has written a complete review yet...no one knows how it performs...so i suggest you wait for some time until these two sets are reviewed and then make a choice...
btw, if anyone have use either of those two sets (W208, W209), please give ur opinions on them...
nikhilspoliticalblog.wordpress.com- Common man bows to amitabh
nix is offline
Old 28-04-2007, 08:29 PM   #14 (permalink)
Tech.Masti's Avatar
^^Both lacks GPRS, Motorola claiming that it features long battery life......
Got that info from Motorola AD.
Looking for a cell phone withing Rs. 12K. SE w300i, Moto RAZR V3i or any other phone mehulved Mobiles and Tablets 15 19-07-2006 01:27 PM
SUGGESTIONS : Pls Suggest a MOBILE phone under 8K Vishal Gupta Buying Advice 20 06-04-2006 09:02 PM
C++/C to Basic Shikhar Programming 2 24-03-2006 01:48 PM
Help me buy a Basic UPS (what VA)? dragonball QnA (read only) 2 17-07-2005 10:01 PM
Basic in 3d max rajat22 Tutorials 1 19-05-2005 12:59 PM
