Old 15-03-2007, 01:09 AM   #1 (permalink)
Question mp3 player problem??
hi , i am facing an unique mp3 player problem . i have 4 gb mp3 player (china made). when i connect it to pc using usb it shows 2 drives ... when i try to play songs from it it only plays for 10 secs n gets stops .. when i try deleting songs from it using pc it says file corrupted . when i try to format it , it says unable to format it ... i think it has problem with its memory ..what do u think ..p[ls reply...
NagpurDaMunda is offline
Old 15-03-2007, 01:25 AM   #2 (permalink)
24online's Avatar
Arrow Re: mp3 player problem??
dont do format...
"30 DAYS WARRANTY.NO WARRANTY ON DATA LOSS/MEMORY LOSS DUE TO FORMATTING." as seen on rediff.com
also use proper mp3 format songs...with text...if not work, contact technical person...
i recommend buy any mp3 player of good brand or non-brand supports atleast 6-months or 1 year warrenty...
**#(o)#**
24online is offline
Old 15-03-2007, 07:42 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: mp3 player problem??
MP3 memory has got bad sector.Get replaced it soon.And never buy such things of local company.
www.9zap.com/forums -> Indian Webmaster Forum
whost.in - Web Hosting Offers
thinkdigit.com/forum/showthread.php?t=109137
TechTin.com
ravi_9793 is offline
Old 15-03-2007, 09:26 AM   #4 (permalink)
kumarmohit's Avatar
The problem was that you had set the playmode to preview which plays for 10 seconds and goes to next song. By formatting you may ruin the player.
For further help you may visit - www.mympxplayer.org
kumarmohit is offline
Old 15-03-2007, 11:33 AM   #5 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
i have mp3 players and i usually format them( one transend, another orchid(local with gurrentee)) and nothing happened still now.. already 1yr passed.. who told formating ruines mp3 player???.. The firmware used by the player remains in some other place and not in the place wher user formats..
its a "local band" problem.. many faced the same.. see if u can replace else throw as it cant be repaired except the company itself
Blogging @ http://classictutorials.com
the.kaushik is offline
Old 15-03-2007, 04:22 PM   #6 (permalink)
yes u r right but i m unable to restore it
Old 16-03-2007, 11:07 AM   #7 (permalink)
kumarmohit's Avatar
Just poke around the player with the M button in the music player. and the volume button. RTM if u have one in english.
