View Poll Results: Nokia 5200
Good - Go for it ..... 2 25.00%
hmmm - Look for other things in this (tight) budget .... 6 75.00%
Voters: 8. You may not vote on this poll
Old 03-03-2007, 06:15 PM   #1 (permalink)
Smile Nokia 5200 - Suggestion Required
Hey people,
i am new to the mobile world & recently gng for mobile phone buying.
I have zeroed my search on - Nokia 5200 with 1 GB mem card. (budget 7-8k)
I would like to have some suggestion from you kind people -
- should i go for it or look for another thing.
Hope to get kind guidance from yourselves.
Thanx
utsavhanda is offline
Old 03-03-2007, 06:26 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Nokia 5200 - Suggestion Required
its a good fone... also consider the se z550i... and w550i..
Pathik is offline
Old 03-03-2007, 06:34 PM   #3 (permalink)
well man its gud fone wid gud sound and value for money.....but wid only one prb its not having gud screen or camera...its only a vga.....but if dats ur budget go for d fone
shikhar_kapoor143 is offline
Old 03-03-2007, 06:39 PM   #4 (permalink)
Tech.Masti's Avatar
^^Also heard that 5200 plastic body is not so good.... Got the news from mobile-review.com
Tech.Masti is offline
Old 03-03-2007, 06:43 PM   #5 (permalink)
Low Budget Sliding phones have Slider problem after 6 months, some where read on forum while searching mobile for me.
Stick is offline
Old 03-03-2007, 07:16 PM   #6 (permalink)
Wire muncher!
infra_red_dude's Avatar
well for this budget i'd suggest u go for z550i.
infra_red_dude is offline
Old 03-03-2007, 09:01 PM   #7 (permalink)
assasin's Avatar
other dan slider prob 5200 has a whole lot of other probs.
assasin is offline
Old 03-03-2007, 09:22 PM   #8 (permalink)
Stalker's Avatar
consider z550
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 04-03-2007, 12:53 AM   #9 (permalink)
dhan_shh's Avatar
With the price of 7.6K,this is definitely worth buying! Features like
32MB flash memory with 16MB RAM,
E-Mail support for attachments,
Bluetooh A2DP support,
IM,
Push-to-Talk,
Infrared,
Mini USB,
Firmware update on the air(FOTA),
GPRS/EDGE class 10,
JAVA MIDP V2.0
Plus regular features,
this is a GR8 phone,no hesitation,
jus GO.........GET IT.........You will never REGRET.....
dhan_shh is offline
Old 04-03-2007, 01:45 AM   #10 (permalink)
Tech.Masti's Avatar
^^^do you already use the phone???
Old 04-03-2007, 01:49 AM   #11 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Post Re: Nokia 5200 - Suggestion Required
but it is based on S40
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 04-03-2007, 11:36 AM   #12 (permalink)
Google Bot
Pathik's Avatar
E-Mail support for attachments, -Needs Igprs
Bluetooh A2DP support, -Needs a BT headset
IM, -Needs Igprs
Push-to-Talk, -Not 4 India
Infrared, -IR sux
Mini USB, -thats good
Firmware update on the air(FOTA), -Needs Igprs
GPRS/EDGE class 10, -hmmm
JAVA MIDP V2.0 - yeah good but cant compare it to s60...
Pathik is offline
Old 04-03-2007, 07:06 PM   #13 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
but not supported dix player,smart movie this type of software
Dell 15z + WD 2TB
iPhone 4 32 GB
Old 04-03-2007, 07:34 PM   #14 (permalink)
Google Bot
Pathik's Avatar
yp... we know... its s40 .. remember???
Pathik is offline
Old 04-03-2007, 07:38 PM   #15 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
but there is some theme and game which supported S40 5200 is not supported why
Dell 15z + WD 2TB
iPhone 4 32 GB
Old 04-03-2007, 07:47 PM   #16 (permalink)
Google Bot
Pathik's Avatar
well all java apps and games shd work on 5200...
the themes differ from cell to cell...
Pathik is offline
Old 04-03-2007, 09:53 PM   #17 (permalink)
i m using 5200 it is coooooooooooooooooooooool man go for it .
mughal is offline
