Old 16-02-2007, 02:42 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
piyush gupta's Avatar
Default Best phone in Range of 15K
Guys suggest me a phone in range of 15K
piyush gupta is offline
Old 16-02-2007, 03:07 PM   #2 (permalink)
Wandering in time...
Ankur Gupta's Avatar
Default Re: Best phone in Range of 15K
Nokia N70 ME suits your budget perfectly...
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 16-02-2007, 03:10 PM   #3 (permalink)
dude yesterday only i brought n72 i think it the best celll man i dont like n70 bc it doesnt have looks as n72 and if r going for n72 then buy a 1 gb card and the adapter and save money adn then nxt time buy a huge budget cell man i brought n72 frm nokia prority for 12600
hackers2005.3721 is offline
Old 16-02-2007, 03:12 PM   #4 (permalink)
Google Bot
Pathik's Avatar
go for a n70/n70me or a w810i..
Pathik is offline
Old 16-02-2007, 03:16 PM   #5 (permalink)
Tech Geek's Avatar
N72
W810i
Tech Geek is offline
Old 16-02-2007, 03:28 PM   #6 (permalink)
How much N73ME costs
whats the diff btw N72ME and N73ME
Old 16-02-2007, 03:29 PM   #7 (permalink)
18 Till I Die............
Don't you have anything to say about the kind of usage and what you prefer?
N70ME seems a really good phone in the range.
http://www.bash.org/?258908
mehulved is offline
Old 16-02-2007, 03:35 PM   #8 (permalink)
Google Bot
Pathik's Avatar
n73me shd be arnd 20k...
n get a n70 rather than a n72...
n70 is a os8.1 fone n n73 is a os9.1 fone...
Pathik is offline
Old 16-02-2007, 03:55 PM   #9 (permalink)
My first preference is music
i love and us eonly Altec lansing Speakers coz i m very curiuos about soft & sweet music
my next preference is good camera for video and photos
other are normal stuffs GPRS bluetooth etc.
also it should have gud memory s i m very found of music
Old 16-02-2007, 04:21 PM   #10 (permalink)
krazyfrog
Posts: n/a
Go for Sony Ericsson W810i
Old 16-02-2007, 04:23 PM   #11 (permalink)
Tech Geek's Avatar
I heard that its camera is not that good.Is it true??
Old 16-02-2007, 04:27 PM   #12 (permalink)
Google Bot
Pathik's Avatar
it has a decent cam... just as good or mebbe better than k750i..
Pathik is offline
Old 16-02-2007, 04:42 PM   #13 (permalink)
krazyfrog
Posts: n/a
Its camera is absolutely fine. No problems. Its just as good as K750i/W800i. Its just that it doesn't have a lens cover like K750i/W800i.
Old 16-02-2007, 04:43 PM   #14 (permalink)
i want to go for only nokia coz my usage is more than usual and i dont wanna to face battry prob like in Moto and Sony
Old 16-02-2007, 04:48 PM   #15 (permalink)
krazyfrog
Posts: n/a
Rest assured there are no battery problems in either Moto or SE.
Old 16-02-2007, 05:02 PM   #16 (permalink)
i m talking about battery backups
i think nokia provides best battery backups
Old 16-02-2007, 05:26 PM   #17 (permalink)
K750i/W800i and W810i battery name among one of the most long lasting.
Nokia phone in your budget have only Max1GB Memory while with sony you can add up to 2 gb.
What you like? Music and cam than forget about Nokia within 15k, only N73ME shows equal report compare to W810i on Music and Camera front.
For more info on W810i visit gsmarena.com
Stick is offline
Old 16-02-2007, 06:43 PM   #18 (permalink)
n72 man
Old 16-02-2007, 07:00 PM   #19 (permalink)
Google Bot
Pathik's Avatar
Originally Posted by hackers2005.3721
n72 man
dude gimme 1 good reason to take a n72 wen he can afford a n70 n maybe even a n70me... ???
Pathik is offline
Old 16-02-2007, 09:25 PM   #20 (permalink)
Stalker's Avatar
go 4 n70 / w810i
how different is an n70 from a n70ME?? is the n70ME better than the w810i??
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 16-02-2007, 11:48 PM   #21 (permalink)
Wire muncher!
infra_red_dude's Avatar
the best reason wud be saving in cash! when n72 has everything he needs why pay more for features that you don't need even tho u can afford it??? he put the saved cash elsewhere!
infra_red_dude is offline
Old 16-02-2007, 11:52 PM   #22 (permalink)
Google Bot
Pathik's Avatar
@stalker if u r interested in music and cam quality alone then get the w810i.. If u want all round decent features and excellent software support then go 4 n70 or n70me
Pathik is offline
Old 17-02-2007, 12:09 AM   #23 (permalink)
w810i is a really good and u can add upto 4gm and camera is fine only corns is that it dont have much color varitey
when compared to n70 i like w810i
kunaltech is offline
Old 19-02-2007, 04:07 PM   #24 (permalink)
Ok
i think i have two options
W810i and N73ME
can anyone tell me adv. of W810i
which is more reliable
Old 20-02-2007, 01:16 AM   #25 (permalink)
You gave been GXified
gxsaurav's Avatar
Ok
W810i and N73ME
Why don't you look at the comparision yourself. I find W810i better cos it's easier to use one handed, though you will miss applications installation like in Symbian phone.
N73 ME has 3G which you won't be able to use in India anyway, it's heavy compared to W810i. Also has edge & a screen resolution of 320X240 with such video playback & bigger screen
If you want a slim trim phone get W810i, else get N73ME. Choice is yours
about.me/gxsaurav
gxsaurav is offline
Old 20-02-2007, 08:04 AM   #26 (permalink)
Google Bot
Pathik's Avatar
get a n73me... But its abt 21k.. While w810i is 14k
Pathik is offline
Old 20-02-2007, 08:29 AM   #27 (permalink)
Wise Old Crow
blueshift's Avatar
W810i would be the best option in this range.
http://twitter.com/blueshift155
blueshift is offline
Old 20-02-2007, 10:03 AM   #28 (permalink)
W810i @11.5k Grey Market and No Speakers.
Stick is offline
Old 20-02-2007, 12:55 PM   #29 (permalink)
thanx guys
i will go for SE W810i
Old 20-02-2007, 03:26 PM   #30 (permalink)
gxsaurav's Avatar
21 K , what the hell r u buying. Phone or a Casual PC...dude you have made a nice decision of buying W810i, you can very well get a fridge & washing machine in 21k
about.me/gxsaurav
gxsaurav is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/buying-advice/49671-best-phone-range-15k.html
Thread New cell phone needed in 10k-15k range. | Digit Forum | BoardReader This thread Refback 12-12-2010 12:47 AM
