Old 04-02-2007, 11:24 PM   #1 (permalink)
Noobie Pro
alsiladka's Avatar
Default How To : Delete themes in New Nokia Phones
Supported SmartPhone Models -
Nokia -
3250, 5500 Sport, 6290, E50, E60, E61, E62, E70, E71, N73, N75, N76, N80, N91, N92, N93, N93i, N95
A lot people seem to be having trouble uninstalling themes on the newer S60v3 Nokia phones.
Here is a guide on how you can delete those theme files and recover valuable space on your Memory Card.
I had used a different method of Trial and Error a long time back, but since then as the problem was global, a lot of people have come up with easy guides to do this. Since i own a Nokia 3250, most of this guide is based on Nokia 3250, which works even on all other phone model with a little bit of change.
1. Connect the Phone to the Computer using the Data Transfer mode. The mode where you can access the Memory Card as a Removable Drive mode.
2. Make sure that Hidden Files and Folders are visible. If they are not, heres how you can enable this option.
Open My Computer and Navigate to
Tools > Folder Options > View > Show hidden files and folders
Check that option and click on apply.
3. In my computer Navigate to your Memory card drive. In the Memory Card, there will be a Hidden folder called Private. Inside that, there will be many folders named with differend numbers and letters. One of these folders contains all the themes inside a folder names import. On 3250, the theme folder is 10207114. Maybe it may be the same folder on the other phons also, if this is not the folder, just search for "Import" and Navigate to that folder.
My Computer > Removable Disk (the memory card) > Private (it's a hidden folder) > 10207114 > Import
4. Inside the Import folder, you will find various folders with names like dc60815d47351ce2. Each of there folder corresponds to one theme.
5. Open each folder and you'll see in the contents 4 files: a settings file, a .mbm file, a .mif file and a .skn file. The 4 files have in their title the theme name.
6. Find the theme you want to delete, and delete the Folder containing the theme.
7. Delete all the themes you want to delete, Eject your Drive .
Thats it, those themes have been deleted now. You have recovered your Space .
If any of you are having any problems deleting the themes, feel free to clear your doubts.
www.twitter.com/alsiladka
alsiladka is offline
Old 06-02-2007, 09:35 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: How To : Delete themes in New Nokia Phones
Nice tut
Tech Geek is offline
Old 07-02-2007, 08:45 AM   #3 (permalink)
gdatuk's Avatar
Cant use the fexploer to do this???
anyway great info....reps to u
Twitter @cgiridhar
Moto Milestone | Rooted | Froyo | CM 6.1.0
AMD Phenom2 720 x3 BE | Gigabyte MA78G | WD 500Gb+Seagate 1TB ext | PSU Corsair vx450 | Corsair 2x2gb RAM | Bose Companion 5
gdatuk is offline
Old 07-02-2007, 08:59 AM   #4 (permalink)
Noobie Pro
alsiladka's Avatar
Fexplorer for S60v3 is currently in a closed Beta testing stage. You have other File managers available like Y-Browser, but you cannot access the Private folder while the Phone is in Online mode.
The only way as of now is using the phone in offline mode
Old 07-02-2007, 02:34 PM   #5 (permalink)
D PrankMaster
prankie's Avatar
Thanx a lot....
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is online now
Old 07-02-2007, 04:35 PM   #6 (permalink)
tuxfan's Avatar
I go to theme browser and press the delete key! It doesn't delete the default themes that way but deleted all the other themes that I installed!!
tuxfan is offline
Old 07-02-2007, 06:26 PM   #7 (permalink)
D PrankMaster
prankie's Avatar
Dude, this method does'nt work on symbi v9.1 fones....
for deletin themes u either have to goto application manager or have to do what alsiladka described...
Old 10-02-2007, 09:28 AM   #8 (permalink)
Walking, since 2004.
mail2and's Avatar
Prankie is right. From Symbian 9.1 onwards, everything has to be uninstalled from the App Manager.
However, this App Manager is still quite buggy.
Mumbai, I miss you. :(
mail2and is offline
Old 10-02-2007, 09:36 AM   #9 (permalink)
Noobie Pro
alsiladka's Avatar
About the themes, you can say that they needed something different to make them visible in the App. Manager than the older version themes, which the theme makers must not have been aware of previously.
Babi's every new theme can be uninstalled from the App. manager.
Old 10-02-2007, 10:55 AM   #10 (permalink)
Google Bot
Pathik's Avatar
wats babi???
Pathik is offline
Old 10-02-2007, 02:00 PM   #11 (permalink)
Noobie Pro
alsiladka's Avatar
Originally Posted by pathiks
wats babi???
She is a very famous theme creator for Nokia Symbian Phones. Her themes are some of the best themes around.
Check them out over here
www.babinokia.com
Old 11-02-2007, 03:29 AM   #12 (permalink)
It is not a problem with my themes
3rd editon has this bug: if you install more than 4 or 5 themes they will no visible on application manager.. I try my themes before post them and I can delete them from application manager...I hope that nokia will fix this bug but for the moment is better if you install only some themes for times.... or delete one before you install another theme...
Sorry for my english.. I'm Italian...
babi is offline
Old 11-02-2007, 04:00 AM   #13 (permalink)
sauravktr's Avatar
Know this already.Anyway thanks 4 the post
sauravktr is offline
Old 11-02-2007, 09:01 AM   #14 (permalink)
mail2and's Avatar
www.babinokia.com
Check out Aero's themes, too.
mail2and is offline
Old 11-02-2007, 09:01 AM   #15 (permalink)
Noobie Pro
alsiladka's Avatar
OMG babi you are actually here!!! Simply cannot believe it!!!
How did you come to know about this forum and that too that we were discussing about you only?
Welcom to Digit Forums, hope you are hang around often
- by tv6952
