| Forum |
| Buying Advice Sub-section for Buying Advice queries. |
#4 (permalink) |
If you want solution then give more details like
Which phone? Which version of app Manager? and some details about what you tried to do..... This will help us to help you.
Crazy is what crazy does. So lets get crazy like hell. |
#5 (permalink) |
its nokia n73 i have trie ussing app manager which is pre intalled but i dosent shows them...
abt the option of going to E:/system i just got the phne 5 days bak so still looking for the correct version of fe explorer which wud install in my phne |
#6 (permalink) |
#8 (permalink) |
Posts: n/a
For a version of FExplorer for your phone check www.gosymbian.com You can also download Xplore from www.lonelycatgames.com However, as pathiks said, you cannot delete themes through these apps. Go to themes app to delete them. Or you can use a card reader.
#9 (permalink) |
Noobie Pro
http://www.thinkdigit.com/forum/buying-advice/48507-how-delete-themes-new-nokia-phones.html#post407340
here , since you said a lot of people are facing this problem , i created a new guide on how to delete themes.
www.twitter.com/alsiladka |
#10 (permalink) |
fileedit mobiexplorer fexplorer all are software for n-series google them
and main thing it has a search button rom where u can search the file with .sis extension which is basically a software or a theme file go to search and enter the name of the file u want o delete or type "*.sis" u will get the files
#11 (permalink) | |
Noobie Pro
He is talking about a common problem in the New Nokia Phones. The themes are not in Sis format, and they are not even a single file. You can delete the themes using the guide i posted
| Bookmarks |
| Thread Tools | |
| Display Modes | |
