Results 1 to 8 of 8
Thread: Bluetooth
  1. #1
    ★★★★★★★★★ pritish_kul2's Avatar
    Aug 2006
    in a house
    Default Bluetooth
    How do i know if my computer supports bluetooth and how to switch it on?
    My computer model - HP Pavilion t730i
  2. #2
    Google Bot Pathik's Avatar
    Aug 2005
    Default Re: Bluetooth
    u mus hav got bt drivers wit it if it supports bt.. Goto device manager and check 4 any bt devices
  3. #3
    Right Off the Assembly Line techno tublai's Avatar
    Aug 2004
    Kolkata
    Do you have a bluetooth dongle supplied with your PC? If yes you have got the BT. Else I have heard that some motherboards bundle an onboard bluetooth adapter with it, though I dont remember. Only way to verify is through the device manager or control panel.
    I fight, because I choose to.
  4. #4
    Aug 2005
    hey i jus checked ... almost all hp pavilions hav internal bt adapters... or onboard ones... jus install the drivers n get going..
  5. #5
    Jan 2007
    even if u don have inbuilt bluetooth u can get a bluetooth dongle (approx Rs.200) .. plug it thru ur usb and voila ur comp is bluetooth enabled....
    Phani
  6. #6
    Aug 2006
    in a house
    where can i get the drivers from?
  7. #7
    Aug 2005
    normally u get them in ur drivers cd u got from ur pc.... u can also use the inbuilt xp drivers...
    if u take a bt dongle u ll get a cd wit it..
  8. #8
    ಠ_ಠ s18000rpm's Avatar
    Mar 2006
    it should be clearly printed in the Instruction Manual of your PC about the BT, so read it & you'll know how to turn it on/off.
    ASUS K53SV SX520D + BF3
  1. Bluetooth in desktop computer and Bluetooth headphones?
    By SeenuGuddu in forum Consumer electronics and everything else
    Last Post: 16-03-2012, 02:57 AM
  2. Keep Bluetooth OFF
    By Pravas in forum Mobiles and Tablets
    Last Post: 06-07-2007, 11:57 AM
  3. Bluetooth ! ! !
    By ax3 in forum Mobiles and Tablets
    Last Post: 30-12-2005, 05:29 PM
  4. bluetooth sms
    By champ_rock in forum Mobiles and Tablets
    Last Post: 15-11-2005, 11:38 PM
  5. Bluetooth!!
    By KoRn in forum Buying Advice
    Last Post: 15-06-2005, 06:51 PM
