Old 28-12-2006, 10:18 AM   #1 (permalink)
Wise Old Crow
blueshift's Avatar
Default Suggest me a mob too.
I need just a low cost dual band basic mob. Must have polyphonic ringtones and GPRS. thats it!
Edit: Are there low cost mobs that support mp3 ringtones? I mean below 3000 range.
http://twitter.com/blueshift155
blueshift is offline
Old 28-12-2006, 02:53 PM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: Suggest me a mob too.
Go for Motorola C168 for 2.5k.
Old 28-12-2006, 04:44 PM   #3 (permalink)
Wise Old Crow
blueshift's Avatar
thanks krazyfrog.
I need more options too in other brands mostly SonyErricson.
Old 28-12-2006, 04:58 PM   #4 (permalink)
Sup' dude, Sup'
what is your budget?
try any of these
1) Nokia 6030 Rs. 3.5k
2) Nokia 6020 Rs. 4.5k
3) Sony Ericsson K320i Rs.5.5k (no gprs)
4) Sony Ericsson Z300i Rs. 3.5 with gprs
5) Motorola L6 Rs. 5.5k (bluetooth, vga cam, gprs, mini usb, extremely slim) <- my phone
6) Motorola C261 for 3.5k
I recommend motorola L6
ambandla is offline
Old 28-12-2006, 05:18 PM   #5 (permalink)
Wise Old Crow
blueshift's Avatar
those are still a bit high priced. I need mobs for less than 2.5-3K.
Thanks for your effort ambandla.
Old 28-12-2006, 06:33 PM   #6 (permalink)
Google Bot
Pathik's Avatar
hmmm 4 3k u shd get a nokia 2310...
Pathik is offline
Old 28-12-2006, 08:41 PM   #7 (permalink)
krazyfrog
Posts: n/a
If you want a Sony Ericsson mobile at 3k, look no further than J230i. (Actually if you'd mentioned your budget earlier, i'd suggested this phone instead of C168 )
Old 29-12-2006, 01:10 PM   #8 (permalink)
Tech'ing life seriously!!
sude's Avatar
go 4 an nok6030. i am using it for 2.5 yrs now. no probs... but remember one thing.... if u want to use ur phone for gprs use nokia only and nokia use nokia 6030....
-SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Old 29-12-2006, 03:08 PM   #9 (permalink)
Sup' dude, Sup'
for under 3k, 6030 is the best. But I would suggest you to stretch the budget to 4k and get L2. L2's bigger screen is a definite adv. when compared to 6030.
ambandla is offline
Old 29-12-2006, 07:51 PM   #10 (permalink)
Wire muncher!
infra_red_dude's Avatar
also if u buy gprs phone, just check if the phone has a built in modem. it'll come handy when u wanna connect to ur pc and surf.
infra_red_dude is offline
Old 29-12-2006, 08:33 PM   #11 (permalink)
Wise Old Crow
blueshift's Avatar
thank you all of you guys for your suggestions.
Old 01-01-2007, 05:47 PM   #12 (permalink)
Wise Old Crow
blueshift's Avatar
Didn't want to create a sepaprate topic for tis.
__________
Please help.
