Old 28-12-2006, 08:51 AM   #1 (permalink)
CBZ is better than Pulsar
panacea_amc's Avatar
Cool == which fone to buy? ==
hello peopl,
i have around Rs 11000-13000. i need a fone with following features
1. sliding fone
2. Good quality speakers.
3. memory storage of at least 30 mp3 songs@ 128kbps
4. good battery life.
5. minimium of 1.3 megapixel camera
so, after i did some amount of searching, i found the following fones
1. SE w550i = this fone has all the features i want, but i ve learnt tht SE fones has joysyick problems....is this true? and wht about the battery life??
2. MOTOrazr = plz give ur comments abt this fone
3. samsung d500 = peopl advised me not to buy this fone...i dont know why??
4 if any newer fones u might have come across, plz mention it.
WILL BE OF GR8 HELP!!! THANX
panacea_amc is offline
Old 28-12-2006, 08:56 AM   #2 (permalink)
De@d
outlaw's Avatar
Default Re: == which fone to buy? ==
what about nokia 6270 and 5300 ??? both are sliding and emphasises on music !, with 1.3 mp cam comes under your price range
Man's greatest living fear - When you die, they will find your porn"
Most people are only alive because it is illegal to
shoot them.
outlaw is offline
Old 28-12-2006, 08:57 AM   #3 (permalink)
Sup' dude, Sup'
Why don't you go for W810i for Rs.14,500.
walkman phone with mega bass
2MP cam.
bluetooth, ir, quad band.
not a 3G phone.
comes with 512MB card. you can store 120-140 mp3 songs @128kbps.
ambandla is offline
Old 28-12-2006, 09:44 AM   #4 (permalink)
Google Bot
Pathik's Avatar
r u sure u need a sliding fone?? If not consider d 5500,6233 n 6270
Pathik is offline
Old 28-12-2006, 09:49 AM   #5 (permalink)
thanx peopl,
Ambandla, w810i s good, but i want specifically sliding ones. actually my mom needs one n she's made her mind for slidin fones.
outlaw, can u tell which sound quality is better = w550i or nokia 5300?
and can anyone enlighten me about the joystick problems of SE fones...
THANX!!!
Old 28-12-2006, 10:07 AM   #6 (permalink)
krazyfrog
Posts: n/a
5300 and W550i have the same sound quality. Only thing is that the W550i comes with better quality default headphones. If you connect better quality headphones to 5300 through the provided adaptor the sound quality will be just as good as W550i.
Yes, some SE phones do have joystick problem, but W550i does not have a joystick.
Overall, i'd suggest you go for 5300. It comes for 11.5k. It has a QVGA screen, memory card slot, EDGE and is a slider compared to W550i which is a swivel design. Its much better overall when compared to W550i. Forget about your other options (V3i, D500).
Old 31-12-2006, 12:44 AM   #8 (permalink)
W550 have Dual Speakers so loud MP3 volume!
Stick is offline
Old 31-12-2006, 10:29 AM   #9 (permalink)
assasin's Avatar
Even though 5300 has a single speaker still sound output is equal to W550i
assasin is offline
Old 01-01-2007, 10:06 AM   #10 (permalink)
Great! what is price for 5300?
Stick is offline
Old 01-01-2007, 10:18 AM   #11 (permalink)
Tech Geek's Avatar
15K
Tech Geek is offline
Old 01-01-2007, 01:17 PM   #12 (permalink)
Originally Posted by Tech Geek
15K
I come to know from some forum that the price floating between 11.5k to 13.5k
Stick is offline
Old 01-01-2007, 04:55 PM   #13 (permalink)
assasin's Avatar
Price of Nokia 5300 is 11.1k with bill.Accessories included 256MB microSD,datacable,stereo headset,3.5mm stereo adaptor(doesnt hav microphone support,u wont be able to receive call thru headset when adaptor is connected).OS = s40 3rd edition
U can also consider the nokia 5500.Its sound quality is gr8.
Price = 12.5k.Accessories included 512MB microSD,data cable,stereo headset,3.5mm stereo adaptor( with mic),handstrap,carrying case.
OS = s60v3 (9.1)
assasin is offline
Old 01-01-2007, 06:27 PM   #14 (permalink)
dude if u need loud music like w550 and big screen then take 6270
5300 is nice but cheap looks and vry small screen and 1.3 camera
but hey listen 6270- cost about 14500 with 1 gb ram
and adapter
hackers2005.3721 is offline
Old 01-01-2007, 06:59 PM   #15 (permalink)
D PrankMaster
prankie's Avatar
Samsung makes pretty good phones... and i dont think u'll face any problem with the D500....
Phone looks decent, has a good speaker and an excellent lcd...
since the phone is for ur mom.. so i wont recommend W550i, as it looks too funky...
u can also try Moto razr V3i... has a good sound but average ui...
D500 review:
http://www.mobile-review.com/review/...-d500-en.shtml
Moto Razr V3i review:
http://www.mobile-review.com/review/...a-v3i-en.shtml
My Rig: AMD Phenom II 550BE | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is offline
Old 01-01-2007, 09:29 PM   #16 (permalink)
whatever you do buy a Nokia, it is the absolute best. I have put tons of apps/games on my cell!
NahSoR is offline
Old 01-01-2007, 10:32 PM   #17 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Wink Re: == which fone to buy? ==
i think u go for nokia ph bcoz nokia balance in every thing.
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 01-01-2007, 10:49 PM   #18 (permalink)
dhan_shh's Avatar
Nokia 5300 is technically a better choice,as it is one of the rare phones that support A2DP (Advanced Audio Distribution Profile) whereby we can listen 'Stereo Music' in specially designed BT headsets (like SE HBH-DS 970 or Motorola HT-820 or Nokia BH-501 or 12W).
Right Choice!
dhan_shh is offline
