Old 26-12-2006, 04:37 PM   #1 (permalink)
Default Suggest a PDA
Please suggest a PDA for my friend. His requirements are,
1. Keyboard
2. Touchscreen
3. Creating/Editing Word, Excel files
4. Sending Emails through Outlook
5. Browsing internet sites (EDGE enabled)
6. Price range around INR 30,000
In my first research I have understood that, it will take a PDA with Microsoft Windows Mobile 5.0. We first got our eyes on i-mate JAMin.... but that device has lots of stability issues.
Please suggest some good PDA that one can rely on...
nirubhai is offline
Old 26-12-2006, 07:34 PM   #2 (permalink)
Default Re: Suggest a PDA
dude
i jst o2neo today only for19500 mear a shop frm alfa and its rocks man its balck in colur will a dedicated musc key tooo and grt headd phones tbut no mp3 righttome bass and every thing is same as imatejamin
hackers2005.3721 is offline
Old 03-01-2007, 04:59 PM   #3 (permalink)
O2 XDA Neo does not have keyboard. pocket pc without keyboard would sure cost around 20k.
btw, he needs that phone for work... rahter than entertainment...
i found k-jam quite suitable. but more suggestions are welcome...
nirubhai is offline
Old 03-01-2007, 05:36 PM   #4 (permalink)
dhan_shh's Avatar
U can try 'O2 XDA Trion' or 'O2 XDA Zinc',They r similar to K-Jam but with new features.I don't know whether available in India!
Right Choice!
dhan_shh is offline
Old 03-01-2007, 06:32 PM   #5 (permalink)
Google Bot
Pathik's Avatar
u can try the o2 xda mini or o2 xda neo
Pathik is offline
Old 03-01-2007, 10:55 PM   #6 (permalink)
dhan_shh's Avatar
If you are open minded,I would suggest you to go for Nokia E61,excellant device with all necessary features:
-Works well with office applications,
-Wonderful Outlook for Email management,even you have 'flashing light' indicator for new incoming mails(Gr8 Push Email facility),
-QWERTY keypad may initially look cramped but once practiced,very easy to follow,
-Built-in two browsers,one for beautiful HTML browsing and the other for xHTML(WAP) browsing
-Easy to view all mail attachments,supports almost all formats,
-Exclusively supports all leading E-mail clients viz.,Blackberry etc.,
-Future proof with 3G enabled,EDGE+,Wi-Fi (b and g) enabled,Bluetooth,IR & USB data cable connectiviy,
-Symbian OSv9.1,supports 3rd party applications as well
-Memory Slot:supports 2GB miniSD easily,
-Very Decent Pricing: 19.2K,
Now,Missing specs:
Absence of Touch Screen,
Absence of Camera
No miniUSB support
If you are intersted, there so many features,space is limiting
DEFINITELY WORTH TRYING!
Right Choice!
dhan_shh is offline
