| Forum |
| Buying Advice Sub-section for Buying Advice queries. |
#1 (permalink) |
please help thanks |
#2 (permalink) |
Uninstall the bluetooth s/w in PC and reinstall it. Search for PC bluetooth device on Phone. Then select the PC bluetooth device in the phone and click 'connect'. Now PC will prompt for pairing the mobile. Give a pin code in PC and then the same pin code in mobile too. Once you do this PC & mobile will be able to communicate to eachother.
Kiran Kumar R |
#3 (permalink) |
to connect to nokia pc suit u need to let windows connect to the devices. to do that uninstall the bluesoleil software. and run the bluetooth service. then from control panel select bluetooth option and pair with the phone. then open nokia pc suit and connect to the phone.
Change is Nature, the part that we can influence; and it starts when we decide. Where you going? With Luck forward. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
