Old 02-12-2006, 12:13 AM   #1 (permalink)
Default Suggest a best mobile with FM under 5000
Hi friends,
I want to buy a new mobile with FM.My budget is around 5000.Kindly Suggest a best mobile.But the battery can withstand 2 days.Thanks for your timing
-Sasidhar.
sasidhar is offline
Old 02-12-2006, 12:54 AM   #2 (permalink)
montsa007's Avatar
Default Re: Suggest a best mobile with FM under 5000
C168,3200,w220
montsa007 is offline
Old 02-12-2006, 01:31 AM   #3 (permalink)
Hulo's Avatar
Try Samsung X210
Join IGNOU MCA Students' Forum -- http://www.santanu.in
Hulo is offline
Old 02-12-2006, 01:55 AM   #4 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
nokia 6030
codename_romeo is offline
Old 02-12-2006, 05:53 AM   #5 (permalink)
caleb's Avatar
Originally Posted by sasidhar
Hi friends,
-Sasidhar.
Like codename_romeo suggested...Nokia 6030...it is well within your budget. It is retailing for around Rs.4000 (depending on the place you purchase, it may vary by a couple of hundred).
My earllier cellphone was Nokia 6030 (I still have it as my wife uses it now) it has a great FM radio with AMAZING battery life...it got the BEST BUY award in it's class. It'll easily last you for 2 days with good amout of FM usage & some talktime. Also you can get a data cable seperately (only in grey market) for around Rs.250 to download ringtones, wallpapers, games etc from your PC to Nokia 6030.
caleb is offline
Old 02-12-2006, 07:33 AM   #6 (permalink)
krazyfrog
Posts: n/a
I would suggest you go for SE J230i instead of 6030. J230i has stereo fm radio instead of mono in 6030. The sound quality is also better. Rest all features are same. It comes for around 3k.
Old 02-12-2006, 11:08 PM   #7 (permalink)
Hi,
thank u guys for gave me a good suggestion.
sasidhar is offline
Old 03-12-2006, 12:23 AM   #8 (permalink)
Tech.Masti's Avatar
@krazyfrog...
all features of j230i & 6030 are not same...
but yes, 6030 has mono radio....
Tech.Masti is offline
Old 03-12-2006, 10:02 AM   #9 (permalink)
Wire muncher!
infra_red_dude's Avatar
yes, the features are definitely better in j230i but handling the two phones, i feel the 6030 is sturdier than j230i!
infra_red_dude is offline
Old 03-12-2006, 10:18 AM   #10 (permalink)
krazyfrog
Posts: n/a
I've had huge problems with 6030's navigation keys. I always tend to accidently press the centre ok key instead one of the navigation keys. Also the fm volume in 6030 is also very low and impossible to hear in crowded places (general opinion, not just mine). No such problems in J230i.
@Tech.Masti, the differences between the two are quiet negligible.
Old 03-12-2006, 03:36 PM   #11 (permalink)
Tushar.bar's Avatar
j230i is best(i use it with no prob). butnow a days market says some bad news about its batt.
Tushar.bar is offline
Old 04-12-2006, 01:50 PM   #12 (permalink)
busyanuj's Avatar
two phones: motorola c168 and nokia 6030 which sell a lot due to the less than 5k tag + fm radio.
of these, nokia 6030 is built sturdier and outlasts the motorola counterpart.
So, I'll recommend nokia 6030.
busyanuj is offline
Old 04-12-2006, 01:57 PM   #13 (permalink)
Tech Geek's Avatar
Nokia 6030
Tech Geek is offline
Old 04-12-2006, 02:09 PM   #14 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Even I have Nokia 6030 with me and I think it's the best mobile in the sub 4k range. I think it must cost around Rs 3,900 or so.
Yes, the battery life is great. I listen to FM for almost 1-2 hours daily and still I charge the battery once in 3 days only.
Regarding the FM radio, the sound is little low and it's not good for using on the move.
drgrudge is offline
Old 04-12-2006, 02:18 PM   #15 (permalink)
Tech Geek's Avatar
Can we play songs in the Nokia 6030(transfered from comp.)
Old 04-12-2006, 02:32 PM   #16 (permalink)
krazyfrog
Posts: n/a
No, 6030 does not support music files like mp3/aac. Actually this feature is totally absent in phones below 5k. Understandable considering their low price.
Old 04-12-2006, 02:36 PM   #17 (permalink)
though mobiles less than 5k dont support music files, u can record sounds and use them. of course, the sound quality will b poor.
sarandigit is offline
