View Poll Results: Best cell in 10k to 14k budget
Nokia 6630 7 19.44%
Nokia 6681 2 5.56%
Nokia 6233 5 13.89%
Nokia 6270 0 0%
SE K750i 10 27.78%
SE W550i 2 5.56%
SE W700i 7 19.44%
Motorola RAZR V3i 3 8.33%
Voters: 36. You may not vote on this poll
Old 09-09-2006, 09:03 PM   #1 (permalink)
krazyfrog
Posts: n/a
Default Best cell in 10k to 14k budget
As i've observed, the 10k to 14k price range is one of the hottest in the market and is within reach of quiet a lot of people and everyone trying to get their hands on the models lying in this budget. The list of available models in this range itself is quiet impressive, ranging from smartphones to music phones. So i thought i'll conduct a poll to find out once and for all who rules this segment. It'll also be helpful for those who want to buy a new cell in this particular price bracket. I've only included the popular ones, so don't be mad if your favourite cell is not here.
Old 09-09-2006, 09:38 PM   #2 (permalink)
Default Re: Best cell in 10k to 14k budget
STYLE- MOTOROLA V3i and SLVR L7.
MUSIC - SONY W300i and W700i.
Productivity - Nokia E50, etc.
Hope this helps you
sai_cool is offline
Old 09-09-2006, 10:06 PM   #3 (permalink)
Google Bot
Pathik's Avatar
In s60 6630,in s40 6233,in se k750i
Pathik is offline
Old 10-09-2006, 09:07 AM   #4 (permalink)
Mobile Freak
reddick's Avatar
6681 RULEZ
Hope 4 d best n Do d right :)
reddick is online now
Old 10-09-2006, 10:20 AM   #5 (permalink)
kumarmohit's Avatar
For style go for v3i else go for 6630 or 6681
kumarmohit is offline
Old 10-09-2006, 11:04 AM   #6 (permalink)
if u r gonna install lot of softwares, then 6681 else 6233 is ur best bet..
check out www.gsmarena.com
Shwetanshu Srivastava
shwetanshu is offline
Old 10-09-2006, 04:47 PM   #7 (permalink)
urvish_acharya's Avatar
Wink Re: Best cell in 10k to 14k budget
go for 6233 budy...13500/- cool piece
urvish_acharya is offline
Old 10-09-2006, 07:19 PM   #8 (permalink)
18 Till I Die............
Which one is the best depends upon what you really want to use your cell phone for. I'd prefer a symbian phone cos of the wide availablility of 3rd party software. Someone who wants music will opt for Nokia 6630 out of these.
Those prefering music or camera as their first priority will definitely go in for a SE.
Moto Razr V3i definitely for style buffs.
http://www.bash.org/?258908
mehulved is offline
Old 10-09-2006, 08:01 PM   #9 (permalink)
Google Bot
Pathik's Avatar
btw 6681 isnt 3g nd has real low ram..
Pathik is offline
Old 12-09-2006, 01:02 PM   #10 (permalink)
nokia 6630 and sony k750i
neerajvohra is offline
Old 13-09-2006, 08:20 PM   #11 (permalink)
navneeth_snr's Avatar
Nokia 6630 or Sony Ericsson W700i
Navaneeth
My Phones: Motorola T180, Nokia 2600, SE J300i, SE W810i
navneeth_snr is offline
Old 13-09-2006, 08:24 PM   #12 (permalink)
Google Bot
Pathik's Avatar
6630... Or if u r wanting to go 4 k750i then also see the 6233
Pathik is offline
Old 13-09-2006, 10:19 PM   #13 (permalink)
mohammed_intekhab's Avatar
Sonyericssion k750i is the best phone price they give you more than price ,,
Its camera is as good as digital camera
I warned you but you didn't listen now face the consequences
Specifiacation of k750
The camera settings look the following way:
Automatic camera off. When not used the camera turns off automatically in 30 seconds, 1, 2 or 3 minutes.
Shutter sound. You can choose on of the three shutter sounds but not turn the sound off.
Spot photometry. The function is unusual for a mobile phone.
White balance. A possibility to choose between an automatic mode or Incandescent, Fluorescent, Daylight, Cloudy.
Light. Backlighting activation, also may be turned on by shifting a left-side cover.
Effects. Several effects may be applied to the photos, they are Negative, Solarize, Sepia, Black & White.
Timer is activated for a certain time period for self shooting.
Night mode is for shooting in the dark. Noises raise on a photo, exposition is increased (you shouldn't move the device in order not to get a blurry photo).
Shooting mode. Normal mode, that is taking usual photos. A multiple mode (Burst 4) allows taking four photos for a series. Landscape is a very interesting mode that allows taking rather unordinary photos, has no rivals for the moment. The last mode is taking photos with frames, photo resolution decreases automatically.
Macromode allows turning the mode automatically.
The screen may serve as a viewfinder when in the shooting mode. The picture moves very smoothly and everything is clearly seen. Number keys help in switching between various functions and shooting parameters quickly that fastens work greatly.
Autofocus works well in the majority of cases and yields only to fast moving objects, for instance, cars. The picture often comes merged then. At the same time, a running man is always well seen, the picture is clear.
Processing a photo after shooting is a peculiarity of the phone. Before shooting you see a very sharp picture on the screen and half-pressed shutter button calls focusing like in usual cameras. When pressing it you take a photo and that is when the picture looses its sharpness. The explanation is the phone's processing algorithm; it spends no time to draw a picture on the screen and makes a rough sketch that takes less time. If entering a folder with photos and show a single photo on the screen you'll see it is sharp and the picture is quite saturated.
Let's acquaint with the photos taken in various conditions. We have chosen Samsung P750 equipped with a 2MP camera with a CCD matrix (all the pictures taken with the device are of the maximum resolution and quality). I'd like to say in advance, the Sony Ericsson product proved better though having a CMOS matrix. Let's start with the photos taken in the street.
By mohammed intekhab khan
previews
by khan mi khan
Thank
mohammed_intekhab is offline
Old 14-09-2006, 03:20 PM   #14 (permalink)
krazyfrog
Posts: n/a
Thumbs up Re: Best cell in 10k to 14k budget
Thank you guys all for your votes and replies.
BTW mohammed, the k750i camera description seems to be taken from Mobile-Review.Com. In such case you should mention the source.
Old 14-09-2006, 11:31 PM   #15 (permalink)
k750i is too good
EVERYBODY WANTS TO GO TO HEAVEN BUT NOBODY WANTS TO DIE
mandar5 is offline
Old 16-09-2006, 02:12 PM   #16 (permalink)
Originally Posted by mandar5
k750i is too good
yes its...my brother sold his nokia 6630 and purchased sony k750i
camers is too awesome....specially the panorama effect...ie add 3 images into one automatically !
Old 16-09-2006, 02:59 PM   #17 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Cool Re: Best cell in 10k to 14k budget
But there is only one flaw in Sony Ericsson K750i,
Memory can be expanded to maximum 1 GB
techtronic is offline
Old 16-09-2006, 03:18 PM   #18 (permalink)
krazyfrog
Posts: n/a
Thats not true. SE website says that k750i's memory can be expanded to upto 2gb. There are even 2gb cards available in indian market(at around 2.5k). Some people even say it can go upto 4gb
Old 16-09-2006, 10:00 PM   #19 (permalink)
crazywolf
Posts: n/a
nokia 6233 rockz!!!
Old 16-09-2006, 11:22 PM   #20 (permalink)
gxsaurav
Posts: n/a
2 GB memory stick duo which is compatible with k750i costs 6k or more, 256 MB comes for Rs 2100 in Sony world lucknow
Old 17-09-2006, 02:45 AM   #21 (permalink)
El mooooo
eddie's Avatar
Since we are talking about K750i, I would like to talk about a competitor here. Probably no one heard it but just check out BenQ-Siemens S88
http://img.gsmarena.com/i/pics/benqs...ens-s88-00.jpg
http://www.mobilmania.cz/Files/Obraz...ensS88//05.jpg
A friend of mine has this phone and I can tell you, it looks great and cam has some real quality. The OLED screen that it has (instead of usual TFT) is really bright and is a serious asset to this thing. Good battery life and everything. The only negative point is that it has just a 16MB MMC and doesn't come with an additional one. You need to buy one separately. Otherwise, it looks stunning and works great. Gives K750i some real competition.
eddie is offline
Old 19-09-2006, 08:29 PM   #22 (permalink)
there is no resale price of sony h/s..so think twice before purchasing coz anyway we change our handset atlest once in 6 months...even software compatibility is major issue..the softwares which are easily available for NOKIA, is not available for SONY..so think budy
Old 19-09-2006, 09:32 PM   #23 (permalink)
BUY k750i and be futureproof 4 1,2yrs as u wont get bored of this BLACK BEAUTYEven some of hot chicks in my class r floored with it n resale value of SE fone is increasing
mandar5 is offline
Old 25-09-2006, 01:04 PM   #24 (permalink)
Cool G5's Avatar
Smile Re: Best cell in 10k to 14k budget
I think the SE K750i is the best.If u are a music listener go for W700i.
Cool G5 is offline
- by bhaskar
- by Soumik
