Old 03-09-2006, 09:05 PM   #1 (permalink)
cooldip10's Avatar
Exclamation Suggest a mobile
Suggest a mobile with BT and MP3 player , expanable memory (to store the music files, around 20 songs will do) ...camera no criteria... around 6 K
Everything is Possible
cooldip10 is offline
Old 03-09-2006, 09:48 PM   #2 (permalink)
Anand_RF's Avatar
Default Re: Suggest a mobile
Moto L6 or L7. L6 should fit in your budget, I am not too sure about the L7's price.
Btw, I own L7 and it's nice. No problems absolutely, except it can't play mp3s over 192kbps bitrate.
Anand_RF is offline
Old 03-09-2006, 10:09 PM   #3 (permalink)
Google Bot
Pathik's Avatar
2nd hand ngage qd 4 4k..
Pathik is offline
Old 04-09-2006, 02:25 AM   #4 (permalink)
Tech.Masti's Avatar
only L6 fit in your budget..... in 6k, here lots of phone have MP3 support,but they all misses BT.....
ohh, LG has a model S5000 costs 6.4k, and has BT and MP3 support, but only 4MB internal Memory.....
i things MOTO L6 is better than LG....
Tech.Masti is offline
Old 04-09-2006, 03:01 AM   #5 (permalink)
go_gamez's Avatar
the best..thing is to just exetend u r budget slightly..and get a ngage qd..its a good phone with good sound quality. or else go for a second hand n gage qd !
Intel P4 2.47 ghz with 1 MB L2 cache-HIS 845GVM mobo
512 MB DDR RAM .
Gainward 6600 gt golden sample edition(ultra 1960xp)
80 GB Seagate Barracuda 7200 rpm HDD
Sony QW -120A Dual Layer DVD writer.
go_gamez is offline
Old 04-09-2006, 04:57 PM   #6 (permalink)
cooldip10's Avatar
If i don't need BT then what??
I searched upon K310i.. i need comment on that cell...
- by bhaskar
- by Soumik
