Old 10-08-2006, 11:44 PM   #1 (permalink)
tech geek
abhineet's Avatar
Question PROBLEM in Nokia 6260
i am using nokia 6260 coffee black colour phone for the last 6 months.
the problem is that whenever i switch on my phone it displays "2 messages received" but when i click on the open option there are no messages actually.
it happens everytime i switch on my mobile phone.
what can the problem be???
HELP!!!
abhineet is offline
Old 11-08-2006, 12:09 AM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: PROBLEM in Nokia 6260
i am not sure but being a s60 fone there is a chance that if u installed an application to hide sms such as mum sms .... it might b on .... which does not show the msgs
http://beingmanan.com
iMav is offline
Old 11-08-2006, 03:43 PM   #3 (permalink)
Google Bot
Pathik's Avatar
delete all msg related apps...... and hav u tried msvdrive on 6260..?????
Pathik is offline
Old 11-08-2006, 10:54 PM   #4 (permalink)
tech geek
abhineet's Avatar
what msvdrive are you talking about dude.
abhineet is offline
Old 12-08-2006, 11:42 AM   #5 (permalink)
.:My Name is Bond:.
montsa007's Avatar
while bootin make sure ur mmc is kept out
if u receive msgs select exit
insert ur mmc
wait a few seconds
go to inbox and if u see the sms delete them if u dont then recollect the apps u had previously installed on the fone
and if urs is a 2nd hand 1 then best option is to restore factory settings and not reset
I do web designing for high profile clients - PM me to get yours done~
montsa007 is offline
Old 12-08-2006, 02:17 PM   #6 (permalink)
Google Bot
Pathik's Avatar
if nothing works try the 3key format....
Pathik is offline
Old 13-08-2006, 07:28 PM   #7 (permalink)
tech geek
abhineet's Avatar
thnxs guys,the problem was with the mumsms software.
now it is working properly.
abhineet is offline
Old 13-08-2006, 10:53 PM   #8 (permalink)
iMav's Avatar
.... i remember i too faced the same problem when i installed mum sms .... hence i thought u too must hv doen something similar
iMav is offline
