View Poll Results: Which One of these..?..Pls mentions reasons also..
SE W810i
15 |
65.22% |
SE W300i
0 |
0% |
SE K750i
6 |
26.09% |
Samsung D820
0 |
0% |
Nokia 6230i
0 |
0% |
Nokia 6680
0 |
0% |
Nokia 6270
0 |
0% |
Nokia 6233
0 |
0% |
Nokia 6131
0 |
0% |
Nokia 6630...yucks..i hate this one..
4 |
17.39% |
15-08-2006, 09:08 PM
#31 (permalink)
I have Yolks not Brains!
Re: Final Call... Suggestions Pls..Cell Under 16.5K
Except edge, is there anyother reason, why it should be preffered over k750i? Plz tell
Btw, congo Dipen.you got yourself a bombshell
Y U NO ALLOW PICTURES IN SIGNATURES?
15-08-2006, 09:12 PM
#32 (permalink)
D PrankMaster
Originally Posted by pathiks
AFAIk s40 = symbian series 40
No it's not... S40 is nokia developed os..
its definetly not symbian..
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
#33 (permalink)
18 Till I Die............
Yes, the walkman player.
http://www.bash.org/?258908
15-08-2006, 09:57 PM
#34 (permalink)
The Devil's Advocate
in that case s60 is also not symbian
http://beingmanan.com
15-08-2006, 10:04 PM
#35 (permalink)
D PrankMaster
s60 is symbian..but s40 is not.. well i'm quiet sure not completly though
will check anyways.
15-08-2006, 10:05 PM
#36 (permalink)
As had been explained earlier in some thread. series 40, series 60, etc aren't Operating Systems. They refer to UI by Nokia. So, they have nothing to do with being Symbian and non-Symbian. But, generally it has been seen in the past that Nokia hasn't put Symbian OS in series 40 phones.
15-08-2006, 10:08 PM
#37 (permalink)
D PrankMaster
Ok ok... its symbian.... i just googled..
15-08-2006, 10:09 PM
#38 (permalink)
s40 is just a user interface, but symbian is a well known OS which is used not only in Nokia but others like SE,seimens etc(p910i etc).
G3: XPS M1530 |
FZ 16.
15-08-2006, 10:21 PM
#39 (permalink)
D PrankMaster
hmmm. may be..
but search "symbian s40" on google and u'll find many results.
15-08-2006, 10:22 PM
#40 (permalink)
Hey ppl...thanx a lot..
btw Cell is really good...Cam is cool...and Soud qual is also good...Well bundled software are too less... so ill have to search getjar..and some others..
i even activated Mobile Office.. damn speed is pathetic yaar...2-3kbps...(even with EDGE) on PC..and its showin "E (EDGE)" on the Range Towers also..!!
Dunno...problem with Airtel i guess..!! Called Hutch..they said..theyll be starting GPRS in 15 days.. os mebbe ill shift to HUTCH..
I love walking in Rain ,because no-one knows i am Crying :|
16-08-2006, 12:13 AM
#41 (permalink)
Congrats for your W810i.
If you use bluetooth dongle with native XP bluetooth drivers, then FMA is the first software you should get. Originally made for SE T610, it still works well for all SE phones.
1 aadi + 1 aadi = 1 full ;)
16-08-2006, 04:13 PM
#42 (permalink)
@Aadipa:- I am using USB Cable... and my PC is old..so its USB 1.1..btw when i asked my other frend having some Nokia Cell with EDGE..that how is the service??...he told me he is gettin 20-21kbps....at nite...cmon whats problem with my cell / my connection / my PC then...
many of other frends are also gettin around 12-13 thru GPRS..
i think it as only 1 possibility...and that mite be RANGE..but RANGE is full...and its also showing E as i said earlier....so what mite be the prob.is that i am using IE..and d/lding without DAP..or any other Accelerator..or what..!!
will have to call again to Cust care...
16-08-2006, 04:45 PM
#43 (permalink)
Google Bot
IE sux use opera /Ff and fdm
@dipen did u try ur frends cell in ur pc and ur cell in his pc... try all the combos an tell the speed..
Reason: Automerged Doublepost
18-08-2006, 11:58 PM
#44 (permalink)
Damn...
I have been so dumb...
last nite i was thinkin..what must be diff... EDGE cell...Airtel Connection...everything perfect..why i aint gettin speeds..
Just 4 a fluke i thought lets try service packs....as its mentioned everywhere...but i never installed bcoz my RAM was 64...so i reinstalled my XP..and installed Spacks..1 and 2...
and VOILA...
solid chal raha hain...well not that solid but yeah...quite a good improvement..dunno d/l speed is still less...coz i ain using flashget or anything..and still browsing using IE...
will have to install firefox..
btw..any more updates..which can tweak my connction further..
31-08-2006, 05:19 PM
#45 (permalink)
It doesn't matter!
It's got similar features as that of w700i(the one released inthe begining).
It's stylish. It's got plenty of followers, developers who provide applications/softwares for it.
31-08-2006, 07:59 PM
#46 (permalink)
I would advice you to go for..SE 810i......see...its more compact than the Nokia phones like N70, you got all the options you need for a good phone....theres walkman.....vc....etc.....so go for it buddy before you get anymore reviews and again cofuse yourself
31-08-2006, 09:08 PM
#47 (permalink)
Still...Thanx a lot PPL...
