Old 07-08-2006, 06:12 PM   #1 (permalink)
crazybutt's Avatar
Default URGENT!!! w700i problem
i recently purchased my w700i phone...and just now, it has started acting crazy...i was listenin to some music..d keys stopped working and a white light keeps shining periodically...i took out d battery, reinserted...even took out d mem card...but it keeps doing d same thing as soon as i switch it on
HELP!! HELP
Fate likes to play a little game called "up yours, moe"
crazybutt is offline
Old 07-08-2006, 09:15 PM   #2 (permalink)
csczero's Avatar
Default Re: URGENT!!! w700i problem
Hurry! go to the sony service station quick!
csczero is offline
Old 08-08-2006, 10:29 AM   #3 (permalink)
dOm1naTOr's Avatar
It might be due to the cam shutter prob. Open the shutter and manually quit the cam nd see if the problem persist.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 08-08-2006, 10:46 AM   #4 (permalink)
.:My Name is Bond:.
montsa007's Avatar
i had a similar prob in k750i
i think ur blututh might be on
try this
insert the batt
remove the memory stick
switch on
backup the mem stick on a pc
do a "fat" format and not the fat 32 one
insert in ur fone
and thats it
my current ngage neo had the same problem of freezing
I do web designing for high profile clients - PM me to get yours done~
montsa007 is offline
