Old 01-07-2006, 12:37 PM   #1 (permalink)
maharajadhiraj's Avatar
Default Real Media Player problem in 6630
Hey guyz, sometimez my real media player stops working. I have to restart my phone freqently to get it working. I think this has been happening since one of my friends had transfered a 3gp file via bluetooth. Actually that file didn't open and then the rest of my vids stopped working. After deleting that file and restarting my fone twice wud my Real media player work. Wat exactly is my problem????? and will reinstalling RMP help?????
maharajadhiraj is offline
Old 02-07-2006, 04:14 PM   #2 (permalink)
deathvirus_me's Avatar
Default Re: Real Media Player problem in 6630
the 3gp file may have corrupted a necessary file for real player ... or a virus maybe .. format thy phone ...
deathvirus_me is offline
Old 06-07-2006, 08:08 PM   #3 (permalink)
There must be a way to reninstall only real player instead of complete format ..isnt it ?
cyrux is offline
Old 11-07-2006, 09:06 AM   #4 (permalink)
i think the real player is that one comes with the phone. i suggest you to install real player advanced .
!! www.khin007.com !! the technology portal
khin007 is offline
Old 11-07-2006, 10:32 AM   #5 (permalink)
!FREEWARES!
Akshay's Avatar
I faced the same prb with my n6600. After trying out all d poss. sol., i feel formatting is d safest and best sol. I had installed other players den but later even dey had codecs prb. So I suggest formatting...
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 11-07-2006, 11:21 AM   #6 (permalink)
Google Bot
Pathik's Avatar
try real adv. HELIX..
Pathik is offline
- by bhaskar
- by Soumik
