| Forum |
| Buying Advice Sub-section for Buying Advice queries. |
#1 (permalink) |
1. bluetooth 2. good mp3 and wma and video player 3. atleast 1.3 megapixel 4. good processor so no slow experience when i expand the memory to 1 gigs. 5. tri band or more I thought of 3250 phone but dont know how much it cost... So all you Agent 001 over there please help me with it... budget from 8k to 16k.. but the phone must be value for money and not only features packed...... thnaking in advance
Passwords are like underwear... Change them often... |
#3 (permalink) | |
GUNNING DOWN TEAMS
and as i see u ur not a newbie,......so was that a mistake or haste :roll:
The moment U stop learning ......u stop improving |
#5 (permalink) |
Nokia 6630 shud fit the bill and since its series60 u can always get new softwares to get extended ability in fone
The real and only freedom is Public Domain. Everything else in unfree! Even those who claim to be the self styled evangelists of freedom are not free because freedom cannot be forced by any means! |
#6 (permalink) |
I suggest you get a w550i.
It has a great sound quality and can nearly be used as an MP3 player. Its only drawback is that it does not hv an expandable memory. :roll: :roll: It easily fits in ur budget. It costs 12.5 k here in Kolkata in the original showroom. Its a great phone. I would hv suggested 6680 or 6630 but w550i's sound quality is MUCH MUCH better. TRUST ME!!!! go get a w550i immediately..... |
#7 (permalink) | |
The Frozen Nova
I dream of a better tomorrow... where chickens can cross roads and not have their motives questioned. www.nerdweed.blogspot.com |
#11 (permalink) |
No..W550i is not a symbain fone..it comes wid the essential softwares like media player etc...
U can install only java based softwares in it..which arent much compared to Symbian ones...but the built in ones do suffice for most tasks...
If u think u r right...u r a bad thinker! |
#12 (permalink) |
hey guyz, wich of the two u think is better - 6630 or w550i.
I myselfare confused. w550i's sound quality is EXCELLENT but it does not hv expandable memory whereas 6630 has no FM radio,its sound quality is OK BUT has an expandable memory. |
#13 (permalink) |
Go for 800i then if u can spare some 1000 bucks more...
It has the same audio clarity of a 550i (Through the headphones) Has Expandalble Memory, Crystal Clear 2.0 MP Camera and loads of other feaures...
Sh@riq <size=24>P R ! V ! L E G E</size> |
#14 (permalink) |
i was thinking about nokia 3250... i know it will entend my budget a bit... but is it nice...... can it convert my mobile into
1. mp3 plaver 2. video player 3. okie camera 4. 1gb data capable.... what you say.....
#15 (permalink) | |
U cud go for 800i, 6630, 3230 or 6600. But 6600 has become too common. 800i is a good phone, u cud go for it if u can extend ur budget a wee bit more
~YOU LEARN FROM UR FAILURES , OTHERS LEARN FROM YOUR SUCCESS... |
#17 (permalink) |
D PrankMaster
@jay4u wrote
U can go for N3250. i bought it for 18.5K.... But only one prob. being based on a new platform u'll face incompatibilty prob (like i am facing)..... Well procci is xtreemly fast... the fone came with 512MB microSD card... Music qlty is awesomme.... (can match W800i).... Regards... |
#18 (permalink) | |
#19 (permalink) |
6630 suits ur needs .. 1GB .. mp3 .. camera etc. but u dont get radio in it
3250 is good but a little bulkies but the features it offers .. its a worth a buy as far softwares .. there are always new versions coming .. but do u really need all those sw .. dont worry on that account. have a look at N70, Moto RokrE2, W810i for options take 3250 - if your budget allows to 18.5K if yes then enjoy |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
