Old 02-04-2006, 03:14 PM   #1 (permalink)
Default Big Problem(Urgent)
hi guys i have n6630 and im having problem because i want t o play midtown madness on it the game requirs much memory.so i decided to restart the device and when i restarted it gave a error
phone startup failed.contact the retailer.
plz dont reply that contact the retailer bcoz i want to solve it my self.
plz help me plz help me.
imported_shivam is offline
Old 02-04-2006, 04:13 PM   #2 (permalink)
D PrankMaster
prankie's Avatar
No, the game is'nt such a mem hogger....
i have N6600, and it plays the game quite smoothly...
i think formatting the fone will do the trick...
turn ur phone on and when white screen appears(before nokia logo) press and hold "*" , "3" ,& "call button" untill formatting menu comes...
(i'm not sure whether this code will work on ur fone, it works on mine)
prankie is offline
Old 03-04-2006, 10:44 PM   #3 (permalink)
GaurishSharma.com
gary4gar's Avatar
u can also have viruses on ur fone
gary4gar is offline
Old 10-04-2006, 12:08 PM   #4 (permalink)
.:My Name is Bond:.
montsa007's Avatar
remove the mmc switch off the fone
switch it on then insert the mmc after its completely on
I do web designing for high profile clients - PM me to get yours done~
montsa007 is offline
