Old 08-02-2006, 08:03 AM   #1 (permalink)
Official Techie's Avatar
Default My new mobille phone
I bought a new nokia 6020 yesterday only
It has an inbuilt camera so i thought of transfering the files on to my pc so i asked for a data cable he gave me a dku-2 cable and a cd
when i browsed the cd i saw that therer was no support for 6020.
so i thought to get it from the net
I downloaded all pc suites and drivers but it never showed connection between mobile and pc
Game Khelwanu Magazine Padhwanu Majjani Life
http://sudiptatech.blogspot.com/
http://sudiptamondal.blogspot.com/
Official Techie is offline
Old 08-02-2006, 10:29 AM   #2 (permalink)
Searching...
Did you checked properly whether you ticked on the right port of your DKU-cable ? !!
Dell Studio 15 -- Core 2 Duo T6400 , 3GB DDR 2 800MHz RAM, 320 GB, ATI Raedon HD 3400 256 MB Graphics Card, 15.4" WLED display, 8x DVD writer, Bluetooth Mouse, WiFi, Ruby Red Color, Creative EP-630
amol48 is offline
Old 09-02-2006, 12:51 AM   #3 (permalink)
yes i checked the connction
but my pc never showed conncted
Old 09-02-2006, 08:29 AM   #4 (permalink)
Searching...
do one thing then ... go to the http//:softwares.nokia.com and look for the PC suite and drivers of your cell there. It should be solved then i guess
amol48 is offline
