Originally Posted by Tech.Masti
Please anyone suggest some good phone for using MOBILE OFFICE (under 7K)?Must have USB charging. FM radio and Camera preferred. Thanks in advance.
As he said you cant get everything in one ..
If you want Good Speed GPRS ... Then first check .. what your Service provider supports. for good speed you can go for edge ph. provided ur SP is giving the same. Only 3200 is the one. or you can take 3220 + a fm add-on.
6020 & 6021 are also good options.
