Old 12-01-2006, 08:25 PM   #1 (permalink)
Default need a new mobile connection
I have a Reliance FWP at home with 'free calls to any Reliance CDMA' enabled.
Now i need to buy a new mobile for myself.
It will be used for incoming only (90%). I am student so my monthly expense must remain as low as posible. Dad is not helping here, its on my pocketmoney.
so plz suggest a plan ( Reliance is prefered, then TATA and then GSM) and a handset too.
I tried to get info from friends, but they all confused me.
One said Airtel is good for internet as it charges Rs.12 / day for 150Kbps and unlimited time, MBs. Is it true? prepaid or postpaid.
I pay 400 bucks a month to cablewallah for 64Kbps unlimited.
If u guys have a better solution then plz suggest.
But plz remember that once i purchase it i'll be stuck with it for atleast 3 yrs (plan + handset). Having to spend additional 100 bucks every months is big deal for me.
ashnik is offline
Old 15-02-2006, 03:17 PM   #2 (permalink)
Go for any lifetime validity plans.
It would be best as most of ur calls are incoming only.
Smart GSM by Reliance @775 will be most economical for you.
As for handset unles and until you specify ur reqs and budget it wud be difficult to suggest.
sanzay is offline
- by bhaskar
- by Soumik
