Old 19-12-2005, 04:42 PM   #1 (permalink)
rajat22's Avatar
Default Nokia PC Suite 6.70.22 (New)
Nokia PC Suite is a package of Windows-based PC applications developed especially for use with Nokia phones. Depending on your phone model, Nokia PC Suite lets you edit, synchronize and back up many of your phone's files on a compatible PC through a cable or wireless connection.
Key features :
· Automatic, secure data, information, pictures, and music transfer from phone to phone or phone to PC
· Fast, easy connection to the Internet
· Connect wirelessly or via cable
· Connect by using your phone as a modem
· Manage messages, contacts, images, and music
· Synchronize your phone and PC calendars
· Install Java™-based applications in your phone
· Convert ringing tone formats
· Play multimedia messages and videos
· Send text messages from the PC
· Back up and restore phone files
· Over 30 languages
Connection method compatible with your Nokia mobile phone:
- Infrared (IrDA) port
- Bluetooth via a supported stack: Digianswer Bluetooth Software Suite,
- Microsoft Windows XP Bluetooth, or WIDCOMM Bluetooth for Windows 1.4
- Nokia Connectivity Cable DKU-2 (USB) or Nokia Connectivity Adapter Cable DKU-5 (serial)
Changes in version 6.70.22:
* Bug fix for version 6.70.22 Windows XP SP1 and File Manager application
* Manage your text messages and phonebook easily with File Manager
* Automatic notifications when a new version of PC Suite is available
* Improved back-up and Image Store features
Homepage - http://europe.nokia.com/nokia/0,,72014,00.html
Nokia Lt - http://www.nokia.lt/support/software/
Freeware
Download
http://nds2.nokia.com/files/support/...rel_22_eng.msi
rajat22 is offline
Old 20-12-2005, 12:47 PM   #2 (permalink)
alib_i's Avatar
The biggest problem with Nokia PC Suite is that it runs a little too many services on background. There should be an option to switch OFF all services related to it from the software only.
That's I use Oxygen Phone Manager only .. just one exe file runs .. and only when I want it to ..
plus it has better features
alibi
-Metallica
alib_i is offline
Old 25-12-2005, 09:35 PM   #3 (permalink)
dOm1naTOr's Avatar
@ alib_i
Just remove those startup files of PC suite on msconfig.
This would remove the startup problem. PC suite is way better than Oxygen.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 26-12-2005, 01:12 AM   #4 (permalink)
mobilegeek's Avatar
Very true man ...
just remove it from run>msconfig ..
PC Suite is always better than Oxygen
mobilegeek is offline
Old 27-12-2005, 02:05 AM   #5 (permalink)
alib_i's Avatar
Well ... feature-wise Oxygen is far far better than Nokia PC suite.
It can show various kind of details about the phone when connected - alarm settings, network strength and details, battery, load on memory,etc, call register, logos, ringtone setup, folder manager, profile details and numerous other settings. It's backup functions are more detailed. You can do so much more in Oxygen than PC Suite.
Nokia scores only in looks ... nothing else.
That's why (we can say) Oxygen is shareware and Nokia PC suite free. It has too less features.
@aravind ..
I know I can do that .. but then when I connect my phone .. PC suite doesnt detect the phone .. and gives various other problems .. I have to start ALL the required services .. Only then it works.
Oxygen is so much better .. no background services .. nothing useless .. just one file .. start it when needed and then close it.
Hope you got my point.
alibi
-Metallica
alib_i is offline
Old 27-12-2005, 04:11 AM   #6 (permalink)
mobilegeek's Avatar
There is no PC Suite Vs. Oxygen here ... I agree that things that you pointed are certainly better featured in oxygen.
Its your personal chioce which ever you wanna use
I need the modem & other drivers that bunduled with it so no-need to run for them
But hey dude dont say this .. Shareware Freeware is not a Criteria to judge
I dont need that much detail .. so PC Suite works for me fine.
There is no denying that Oxygen is good too ..
Regards
mobilegeek
Old 27-12-2005, 09:31 AM   #7 (permalink)
mAYHEM's Avatar
When using Messaging feature of PC-Suite on N3230,7710 i cant connnect to gprs from my computer using DKU-2 cable in v6.7 after uninst SMS syn from my phone all works fine.Anbody having same problem on DKU-2
mAYHEM is offline
Old 27-12-2005, 02:58 PM   #8 (permalink)
mobilegeek's Avatar
That should ... bcoz the phone is being used by PC Suite
There is nothing wrong in it ... the windows require the phone to be freed.
Old 27-12-2005, 04:36 PM   #9 (permalink)
mAYHEM's Avatar
Well i never used two parllel connections on Data Cable{using GPRS and Messaging at same time}.Im mean after installing SMS syn soft from PC-Suite v6.7
mAYHEM is offline
Old 27-12-2005, 05:59 PM   #10 (permalink)
alib_i's Avatar
My comments were directed towards aravind who, as you may scroll up and read, suggested that PC Suite is better than Oxygen.
Very true .. but then this is why forums are there. We discuss things and even change each other's views.
If you think it's personal choice, then it's good for you. Let aravind come back and give his views about what I said. It's not a fight, just plain talking.
It isnt the entire criteria .. but the idea reflects. I know a went a little too far with that comparison.
alibi
alib_i is offline
Old 28-12-2005, 11:58 AM   #11 (permalink)
Posts: n/a
is it compitible with series 40 or 60 ?
Old 28-12-2005, 05:24 PM   #12 (permalink)
alib_i's Avatar
(I think) yeah ... there's a separate Oxygen for series 60
alibi
-Metallica
alib_i is offline
Old 29-12-2005, 04:27 AM   #13 (permalink)
mobilegeek's Avatar
alib_i
Absolutely currect .. Dude .. need any help from me let me know .. for now you guyz r free to discuss ..
and HNY 2006 8)
Regards
mobilegeek 8)
- by bhaskar
- by Soumik
