Old 24-11-2005, 08:42 PM   #1 (permalink)
Default Suggest Please : Urgent
Suggest me a mobile which is fm enabled and from which you can read
plain txt files which are transferred using USB.Text files are of maximum 2 mb in size.
Computer.
Whats that.
Is it some kind of frog.. turr turr turrr...
con_tester is offline
Old 25-11-2005, 01:22 AM   #2 (permalink)
First of all .. next time do remember to post your price range ..
and ans to ur question: 3230
mobilegeek is offline
Old 03-12-2005, 09:34 PM   #3 (permalink)
Aniruddh's Avatar
yea exactly pal from nxt time dont forget to tell ur budget as its not possible to suggest anythin widout budget.if u can spend 13-14k than betta get 6630 its better than 3230 in evry aspect.
Aniruddh is offline
