Old 18-11-2005, 09:07 PM   #1 (permalink)
Default MMC Reading problems...
I have a Nokia-Game (NOT QD) & I have a 1GB MMC card in it. The MMC has been working perfectly well for the last 2 months, & my problem started only yesterday. The problem is somewhat very queer & has peeved me a lot. The MMC can be read without any problems on my handset. I can also successfully read the card on my laptop(which has an in-built card reader). The problem however comes when I try to read the card with the help of a USB-intefaced card reader. In this case, the handset screen shows the card as being read by the PC, although the computer fails to read it. This has happened in 4 different computers so far & I have failed to understand the reasons as to why this is happening...
I also tried formatting the card in all the 3 ways possible (NTFS, FAT & FAT32), but by problem wasnt solved & the computer still fails to read the card...
Looking forward to replies. Thanx,
e-peace
h_kunte is offline
Old 19-11-2005, 12:18 PM   #2 (permalink)
tweety_bird_bunny's Avatar
if ur mmc has a password set,,,then pc card reader will not be able to read it...remove the password ,,, then it will be read properly.....
i had the same prob...
if that also doesn't help then just pray!!!
tweety_bird_bunny is offline
