Old 01-11-2005, 03:08 PM   #1 (permalink)
Default NOKIA 6610i?????PLZ help now .I am buying today..
hello ,
i am planning to buy NOKIA 6610i .Anybody with any experience of that phone.Should i buy it.Basically i am looking for a PHONE+RADIO.Is there any problem with the phone.[/b]
Windows XP Pro Service Pack 2 build=2600
Mobo- MSI PM8M-V
GenuineIntel Intel(R) Pentium(R) 4 CPU 2.40GHzRAM : Installed : 512 * 2 MB DDR RAM (TRANSCEND)
XFX FX5200 128 MB
medigit is offline
Old 01-11-2005, 03:21 PM   #2 (permalink)
and what is this Infrared Port.How to connect Phone with PC using IR port.What is IR port.PLZ help...
Mobo- MSI PM8M-V
XFX FX5200 128 MB
medigit is offline
Old 01-11-2005, 06:12 PM   #3 (permalink)
dhan_shh's Avatar
If U want only phone+FM then go for Nokia 6030,it is a good phone and economical too.If u feel like having camera also,then N6610i is a better phone.
Expect the Unexpected !
dhan_shh is offline
Old 01-11-2005, 06:35 PM   #4 (permalink)
what about user experience of 6610i.How is the mobile .how reliable is it??
Mobo- MSI PM8M-V
XFX FX5200 128 MB
medigit is offline
Old 01-11-2005, 07:20 PM   #5 (permalink)
Simpsons rox
It's quite good but u might think of sheelling out a few thousand more and buy a higher end phone though this phone works for most
But u wouldnt want to think after a few months that for 2-3 thousand i cud have lots of features ANOTHER THIONG THE CAM TAKES ONLY PICS NO VIDEOS
T.G. Praveen
A computer program does what you tell it to do, not what you want it to do.
Visit my site at www.praveen.co.nr
tgpraveen is offline
Old 01-11-2005, 07:56 PM   #6 (permalink)
If you want the decent economical phone with a good camera then stretch your budget a little bit and go for Nokia 6020!
vishalbhatia is offline
Old 01-11-2005, 09:49 PM   #7 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Yeah, 6610i is old. But it's only 6500 or less. Add some 15-20% more and get 6020/6030.
It's a very good phone, with no problems but for the IRDa compactibility issue. See the below portion for more...
Infra red (IR):
The phone IR option for communcation between the phone and pc and another phone. We can do a host of things like trasferring files to sending business cards. W need to have a IR dongle for the same. And there may be some line of sight(LOS) issues with IR and the line between the phone's IR port and the IR reciever should be in the same line.
The above has been taken from one of my reviews posted here.
IRDa in 6610i:
It got a IR and can be used to "wireless communication between phone and a compatible PC and other compatible infrared devices" according to nokia but it has limited IR functionalities. We can only transfer business cards via IR. This was the case in the 6610 also.
drgrudge is offline
Old 01-11-2005, 10:13 PM   #8 (permalink)
but no radio in 6020/6030
Mobo- MSI PM8M-V
XFX FX5200 128 MB
medigit is offline
Old 01-11-2005, 10:16 PM   #9 (permalink)
drgrudge's Avatar
Who told?
6030 has radio.
drgrudge is offline
Old 01-11-2005, 10:31 PM   #10 (permalink)
yes 6030 has radio .just got from the net.It is priced at rs 5235.and it has less features than 6610i.So why buy it .
Mobo- MSI PM8M-V
XFX FX5200 128 MB
medigit is offline
Old 01-11-2005, 11:33 PM   #11 (permalink)
18 Till I Die............
If you need the infrared functionality 6610i is pretty much useless. I had 6610 in the past it cud only send and receive business card, memos and reminders but you could transfer images and tones from your computer using PC suite. But, if you are keen on infrared you'd rather skip this one. Even 3200 introduced before this was better in infrared.
mehulved is offline
Old 01-11-2005, 11:50 PM   #12 (permalink)
The 6610i is really an old phone...and the infrared would be pretty useless i guess coz the PC suite gave me lots of probs..not like Sony Ericsson phones ..where we can tranfsre files directly
Also..the camera is of very poor quality..only .3 megapixed i guess(not sure abt it tho)
Sicne u might have already bought it by now..i dont think i have to go into other drawbacks
Jatin_T is offline
Old 02-11-2005, 02:47 AM   #13 (permalink)
mobilegeek's Avatar
6610i was one of the best selling phones ... but its a old now ...
it has a very bad built quality <Its panel is not properly fixed>
My friend only came to know after he bought it
..And I have made many rounds with him to the 3 nokia service centres in Delhi ..
no use ..
Also .. 6610i IrDa is just for writting in the features column ..
practically .. it has no use as drgrudge has mentioned above
other options are:
6021, 6030, 3220, 6020,
Moto E398, SE K508i, SE K300i
mobilegeek is offline
- by bhaskar
- by Soumik
