Old 20-10-2005, 11:18 PM   #1 (permalink)
Default Problem in nokia 6630 while installing quick office
i own a nokia 6630 i accidently deleted the quick office which was provided in the mmc card by default when purchased. i downloaded the quick office from nokia site but when i try to install it ,it asks for "online Check application Validity" i have airtel connection and it does not allow any wap setting to access. when i continue the installation without online confirmation it responds "certificate Revoked for this application " and the installation terminates.
pls help me to install the quick office without connecting to any online sites.
maximus_3007 is offline
Old 21-10-2005, 09:47 AM   #2 (permalink)
thrash_metal's Avatar
Go to the nokia shop and tell the guy what happened . He can help you .. atleast helped me !!!!
a good computer + a great gaming rig + a blasting music workstation + a recliner = LIFE !!!
thrash_metal is offline
Old 21-10-2005, 09:51 AM   #3 (permalink)
He took my mmc card and installed it on for me ... dunno what he did there but didnt charge me a paisa !!
or
You could try to get the installation file from any of the P2P networks !
Old 21-10-2005, 04:15 PM   #4 (permalink)
can you gimme the url frm which you downloaded the software??
kaysquare is offline
Old 21-10-2005, 04:27 PM   #5 (permalink)
champ_rock
champ_rock's Avatar
the p2p thing will be illegal thrash_mittal
Registered Linux user number 400618
champ_rock is offline
Old 21-10-2005, 08:28 PM   #6 (permalink)
yup it is Illegal 100% ... i just gave him a solution .. now its upto the individual to follow it or not !!!!
Old 22-10-2005, 08:46 PM   #7 (permalink)
Just open application manager -> settings ->online certi. check -> off
Thatz it!
siddhesh is offline
Old 22-10-2005, 10:06 PM   #8 (permalink)
thanks guys but the solution siddhesh did gave worked out....
Old 23-10-2005, 07:18 AM   #9 (permalink)
666
solomon_paulraj's Avatar
GOTO TOOLS--> APPS MANAGER --> SETTINGS -->
SOFTWARE INSTALLATION = ON
ONLINE CERTIFICATE CHECK = OFF
DEFAULT WEB ADDRESS = "DELETE ANY WEB ADDRESS"
THATS IT.
solomon_paulraj is offline
- by bhaskar
- by Soumik
