looking for an android jellybean tablet less than Rs. 10k with call facility
Results 1 to 14 of 14
Thread: looking for an android jellybean tablet less than Rs. 10k with call facility
  1. #1
    Apr 2010
    Question looking for an android jellybean tablet less than Rs. 10k with call facility
    hi all
    I am looking for a tablet with call facility under 10k. it should fulfill the following criteria :
    1. should have jellybean
    2. should have 4gb or more internal usable space
    3. should be 7inch
    4. should be in price range below 10k, preferably 5-7k
    5. should have 3g
    6. should have sim slot not port for dongles
    I am not picky about brands right now as long as it fulfills the above criteria i would be happy.
    I am really confused which one to pick from the hundreds available online.
    can any one help?
    Thanks
    Shanx
    Popular Gadget Deals
  2. #2
    Being Human shreymittal's Avatar
    Aug 2012
    Mathura -->> NCR
    Default Re: looking for an android jellybean tablet less than Rs. 10k with call facility
    Increase your budget and this Samsung Galaxy Tab 2 P3110 - Samsung: Flipkart.com although you will not get 3G facility
    BTW this is wrong section
    MODS post this thread in appropriate section
    [url=http://www.speedtest.net/result/3174273798.png]My Speedtest Result[/url] | [url=http://s1285.photobucket.com/user/shreymittal/library/My%20iems]SoundMagic E10[/url] | Sony MDREX220LP
    E7500 | G41M-ES2L | 4GB | 500GB | HD4360 | A520 5.1 | Samsung SyncMaster 22" | XPERIA C | LENOVO TAB A3000 | XPERIA M | XPERIA L | TP-Link W8961 | TP-LINK TL-WR740N | Windows 7 HB | Ubuntu 12.04
    Vaio VPCEB36FG : i3-370M | 4 GB | HM55 Express Chipset | 500 GB| HD 5650 | Windows 7 HP
    Steam : [url=http://steamcommunity.com/profiles/76561198042992568/]shreymittal[/url]
  3. #3
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    Get Galaxy Tab 2 311 for Rs.12500 appx. Great tablet for the price.
    Follow me on Twitter:http://twitter.com/wuodland
    Have a look at my Photography page: http://bit.ly/N2aMTi
  4. #4
    May 2012
    Wicked Leak wammy desire is one of best budget released.Check the review here WickedLeak Wammy Desire Review
    Downsides-No Bluetooth & no sim slot[3G available via dongle]
    ..owns a Dell XPS 15Z,Samsung Hero E2230 & Nokia Asha 206...[B]Web is my passion....[/B]
  5. #5
    Aug 2012
    Mathura -->> NCR
    Quote Originally Posted by pratheeshps View Post
    Still Galaxy Tab 2 311 is better choice
  6. #6
    May 2012
    Quote Originally Posted by shreymittal View Post
    His budget is 10k or less.So it is better than 311 [useless without a 3G].Tab2 310 is a good choice if he can add 5k more
  7. #7
    Aug 2012
    Mathura -->> NCR
    Its better than what you suggested in earlier post
  8. #8
    May 2012
    Hey, Tab2 311 is less poweful than the Wammy desire.It has 1.5 GHz dual core while tab2 has only 1.0 Ghz.Resolution is the same.Only difference is a slightly powerful battery [1000mah more].Tab2 is not VFM ,for Bluetooth,a slightly better battery ,it is twice as costly to wammy desire.That is too much non-sense
  9. #9
    Jan 2013
    Default looking for an android jellybean tablet less than Rs. 10k with call facility
    I would suggest
    Ainol novo 7 crystal 2 cost around 7k
    Go to ainolindia.com
    You can preorder this tab under their offer for first 50 customers.
    Discount Rs 1000
    Accessory free worth Rs 1000
    It got everything except bluetooth and sim card slot.
  10. #10
    Jan 2013
    For call functionality samsung galaxy tab 2 is the best.
  11. #11
    Apr 2010
    Quote Originally Posted by Darkshadowbeast View Post
    I would suggest
    Discount Rs 1000
    how good is customer care for this?
    Tab 2 is around 16k and a little out of my budget
    tab 2 311 is a wifi only device which is of no use to me. if i wanted that i could have taken nexus 7 if i had that budget.
    well it pushes most of the right buttons .... how are zync and byond tabs by the way?
  12. #12
    Alpha Geek theterminator's Avatar
    Mar 2013
    Los Santos
    Quote Originally Posted by shanx View Post
    zync has got a pretty impressive lineup of tablets. check out its website. though i haven't tried any yet so i cannot give a review. there's a 7",8" and a 9.7" tablet. the last two are above 10k but the seven incher is of rs. 6000
  13. #13
    May 2012
    You can also check iball tablets..They are reviewed as good products by Digit & tech2 in their previous reviews.Don't forget to consider them..
  14. #14
    Jan 2013
    I don't know about Ainol customer care but read sum of the reviews don't it bad.
    But i would suggest you don't settle with cheap chinese tablets buy only branded tabs...wait if u can
    Branded tabs -
    1. good service backup
    2. Good quality tabs
    3. Expensive
    4. Long lasting
    Chinese tabs -
    1. bad service backup
    2. Quality varies
    3. Cheap
    4. Lucky if it runs a year or 2
