Results 1 to 23 of 23
  1. #1
    Oct 2012
    Kolkata
    Default Is Karbonn A15 worth buying?
    So I'm thinking of getting my sister a Karbonn A15. Is it worth buying? Has anyone used it here? Any kind of feedback would be really appreciated.
  2. #2
    Broken In a-raam's Avatar
    Dec 2012
    Default Re: Is Karbonn A15 worth buying?
    Never heard of it.. do you by any chance, mean the Karbonn A18??
  3. #3
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    @OP What is your maximum budget ?
    Quote Originally Posted by a-raam View Post
    Atleast do a basic google search before posting a random comment.
    Karbonn A15 review and unboxing – the Micromax Ninja 4 killer
    Follow me on Twitter: http://twitter.com/wuodland
  4. #4
    Wise Old Owl Rockstar11's Avatar
    Jul 2006
    India
    which mobile company is best Karbonn or micromax?
    Sony HX20V 20x optical zoom
  5. #5
    Oct 2012
    From what I have heard.. Both are somewhat equal.. But I would prefer Micromax anyday.. 4-5 friends of mine are using Micromax..
  6. #6
    Nov 2011
    The Dire
    I also want to opt for this phone, but confused between MMX A68, and this one. My budget is 6K .
    SteamId - FierySoul
  7. #7
    sam
    sam is online now
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    Karbonn A15 Micromax A68 Verdict
    Android 4.0 Android 4.0 same
    4.0" 4.0" IPS same
    480X800 480X800 same
    3MP 5MP + LED A68 wins
    Qualcomm MSM7627A (cortex A5) + Adreno 200 Mediatek MTK6515 (cortex a9) + PowerVR SGX531 A68 wins
    512MB 512MB same
    4GB 2GB A15 wins
    1420 mah 1600 mah A68 wins
    3G no 3G A15 wins
    5.9k 6.5k A15 wins
    camera quality won't be great even with 5MP + flash but the processing side, its a big hit. Similarly, A15 has 3G and lower pricetag.
  8. #8
    Wise Old Owl Nerevarine's Avatar
    Feb 2011
    Bhubaneshwar, Orissa, India
    also you missed one thing, no GPS on Micromax.. Personally id go a bit higher and buy A110.. No 3G is a fail
    My Speedtest results
    i3 2120|Transcend 4GB DDR3|ASUS P8H61 M LX|ASUS DRW5ST DVD RW|Corsair VS450|Zebronics Ronak Cabinet|Dell IN2030M|Phillips SHP1900|Seagate Barracuda 250GB + WD Scorpio Blue 160 GB + Iomega external HDD 500 GB|Dell Wireless Mouse/KB combo|Intex Protector 600va UPS| ASUS HD 7770
    Life's a glitch, deal with it :P
  9. #9
    Oct 2012
    Kolkata
    Quote Originally Posted by thetechfreak View Post
    6.5k max. Yeah, the A110 is a good buy for a bit higher price, but it's ppi is really low. Is there a similarly specced phone with ~4 inch screen? No 3g nowadays is a joke, the Mmx A68 loses out for that. And no GPS? Seriously, what were Mmx thinking?
  10. #10
    Feb 2011
    Karbonn A9+ is available for 8.2 K on flipkart.. Anything cheaper and you will miss out the dual core processor
  11. #11
    sam
    sam is online now
    Jan 2010
    Guwahati
    Quote Originally Posted by lr7745 View Post
    3G still cost 2-5 times as much as 2G so A68 is aimed at those who use only 2G.
    check Lava XOLO A700. Highest ppi under 10k.
  12. #12
    Aug 2011
    Aligarh
    Quote Originally Posted by Nerevarine View Post
    its 8.4k on flipkart mate
  13. #13
    Jul 2006
    India
    Quote Originally Posted by astrokidvaibhav View Post
    thanks.
    yesterday just bought Micromax superfone ninja 4.0 for wife..
  14. #14
    Oct 2012
    Quote Originally Posted by Rockstar11 View Post
    thanks.
    So how's the performance.. Are you happy with the buy? Ninja 4 is one of the very good models from Micromax..
  15. #15
    Aug 2011
    Aligarh
    thanks.
    do a review mate
  16. #16
    Jul 2006
    India
    fone is good.. but The battery life is very poor and the charging to 100% takes a very long time!
    Pro...
    1 Ghz Processor which support almost all android aplications
    Large Screen with excellent resolution.
    Excellent white back cover
    3G & WiFi Hotspot options..
    Cons..
    Poor RAM,
    Camera is only 2 MP
    Battery life is not good
  17. #17
    Oct 2012
    Kolkata
    So, what do you guys think? Should I go for the A15? Anyone know how the after sales service of Karbonn in Kolkata is, or is Mmx better? (And I'm def gonna need good after sales service if my experience with the Mmx A60 (loved it while it worked- the only indian droid to have quite decent dev support) is anything to go by.)
  18. #18
    Feb 2011
    for 8k , there's also Huawei X5 Pro on Flipkart.. Snapdragon S2 can be oced to 1.9 ghz with quadrant score of 6K+
  19. #19
    Oct 2012
    Kolkata
    I know, I posted about it on another thread myself. But my budget is 6.5k only.
  20. #20
    Oct 2012
    Ebay has some good CDMA phones for you to buy if you are on a tight budget. Problem is you will have to port your number to Reliance CDMA.
  21. #21
    Oct 2012
    Kolkata
    I don't want to use CDMA, so that option is out.
  22. #22
    Oct 2012
    Import a gsm phone and get it unlocked..
  23. #23
    Oct 2012
    Kolkata
    Okay guys, thanks a lot for your help. Got my sister's old phone (Wave 533) repaired so won't be buying the phone now.
