Results 1 to 6 of 6
Thread: micromax a56 or micromax a73
29-08-2012, 12:52 PM #1bishes!!!
- Join Date
- Mar 2011
- Posts
- 329
my friend wants to buy a phone and he ended with these two to select from, which one is good?
a56 has aisha and 800 mhz proccey and 3mp camera
a73 has 650mhz, 2mp rear but also a front camera also it supports wifi tethering to make wifi hotspot.
please suggest guys, he wants to buy it in a day or two.
my last question, is aisha any different from iris? mean can he have the same feature on a73?
29-08-2012, 01:11 PM #2
Re: micromax a56 or micromax a73
I'll suggest A73 beacause :
1. You get a proximity sensor which is absent in A56.
2. With a slightly less battery (1300 mAh as compared to 1400 mAh) its sleek and elegant.
3. Wifi tehering can be achieved by app.
I'll strongly recommend to go for A73.
\m/
29-08-2012, 09:00 PM #3bishes!!!
- Join Date
- Mar 2011
- Posts
- 329
whats proximity sensor?
nevermind googled it.. than x for the suggestion.
btw can you plz answer..
30-08-2012, 10:25 AM #4Alpha Geek
- Join Date
- Jun 2008
- Location
- 26.6932 n , 88.423 s. Locate me on google maps
- Posts
- 795
Micromax A75 is available for Rs 5999 in homeshop18 , maybe you can take a look at that also.
also saw an ebay listing about A57 on ebay. seems similar to A56 , but with 1GHZ processor.
30-08-2012, 11:21 AM #5
10-09-2012, 03:03 PM #6bishes!!!
- Join Date
- Mar 2011
- Posts
- 329
so he bought a73.. he is very satisfied with the product.
LinkBack URL
About LinkBacks
