Results 1 to 9 of 9
Thread: Need a tablet.
29-08-2012, 07:28 AM #1
Need a tablet.
Hey guys, my bro is looking for a tablet under 20K.
Purpose is entertainment n browsing.
Features needed: usb modems/data cards, Wi-fi, good screen quality..
Which one to opt for?i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
29-08-2012, 12:33 PM #2
Re: Need a tablet.
ipad 2 is a very good option in that budget but unfortunately you don't get any option to connect your usb modem or data card in that.
And how about samsung tab 2, it is also quite good but I don't whether we can connect usb modem or data card in that or not.HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
Sony 5.2ch Component home Entertainment System HT-M5
29-08-2012, 01:58 PM #3
29-08-2012, 02:09 PM #4
Re: Need a tablet.
Tab 2 has a slot for sim. You can use 3g from sim.
29-08-2012, 06:45 PM #5Right Off the Assembly Line
- Join Date
- Aug 2012
- Location
- Chennai
- Posts
- 27
Re: Need a tablet.
Check this link Know How to Connect USB Modem To Android Tablet
29-08-2012, 09:58 PM #6
Re: Need a tablet.
yeah with TAB 2 7.0.. you can insert SIM and use internet.. u wudn't need a USB modem in that case..
I'd explain it to you, but your brain would explode... Trust me
i5 760, Asus P7P55D-EVO, Zotac GTX 460, VX550, Win7 64bit,4GB RAM @1600MHz, WD 500GB+1.5TB Caviar Black, NZXT Phantom
04-09-2012, 02:49 PM #7
Re: Need a tablet.
Guys, the requirements has changed.. He needs a tablet with SIM slot within 15K.. Tab 2 is out of the budget..
How is BSNL Penta IS703C ?
Does funbook n funbook pro support usb 3g dongle like Huawei E1750 ?
Guys, need some help here...!i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
04-09-2012, 11:58 PM #8
Re: Need a tablet.
@ Megamind
For your budget and requirements, one tab fits your bill. Its HCL Me Y2. Comes with a 1ghz A9, 1GB DDR3 Ram,Gpu- mali 400mp, 32gb expandable + 8gb ROM, 3g sim slot with call feature, Microusb which can be used for dongles as well as external storage drives like flash and hdd's & most importantly an IPS panel with a res of 1024x800.
At 14.8k (available at lesser prices locally), its unbeatable for the features it provides and also comes with android 4.0.3 (ICS).
Grab it and you won't be dissapointed.
P.S( You have to root the device in order to install google play).Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
11-09-2012, 12:29 AM #9Banned
- Join Date
- Sep 2012
- Posts
- 30
Re: Need a tablet.
Never buy the crap HCL ME Y2 first of the UI is super laggy and it comes it without play store. And if you want root the device it will lag like a hell. HCL done a trick to promote their own store. I think HCL tab are super flop and no genuine review of Y2 is there in net.
Instead you easily buy Ainol Nova 7 Fire from veedee or mp4nation.net
here's the specs
Ainol Novo 7 Fire Android Tablet PC Dual Core 1.5GHz WIFI HD 2160P Dual Camera Bluetooth 16GB
LinkBack URL
About LinkBacks
