Tablet (Zync Z990 Plus VS Micromax Funbook)
Results 1 to 14 of 14
Thread: Tablet (Zync Z990 Plus VS Micromax Funbook)
  1. #1
    Jul 2012
    Guwahati
    Post Tablet (Zync Z990 Plus VS Micromax Funbook)
    Hi guys n Guru's of TDF
    i want to buy Cum advice a tablet for my friend by 2day or give order by Online so advice is required fast n Reliable
    Budget under Rs7000
    My 1st Choice is Zync Z990 Plus at Rs(6790-6990)
    Screen Resolution 800 * 480 pixels
    Internal Memory 4 GB
    Processor Speed 1.5 GHz
    RAM 1 GB
    Battery Capacity 3600 mAh
    Operating System Google Android 4.0
    Touchscreen (Capacitive)
    Front Camera 0.3 Megapixel no back camera
    USB Support Yes
    WiFi Yes
    Gpu dont know exactly bt I heard of Mali400
    3g Usb dingle supported but only Huawei cant say about other manufacture modems (info 4m Customer care)
    I asked the CC about Service center and she told me that 1st i will get a through phone troubleshoot and if not then will arrange a pick up and drop service
    My 2nd Choice is Micromax Funbook at Rs(6200-6499)
    Processor Speed 1.2 GHz
    RAM 512 MB
    Battery Capacity 2800 mAh
    USB Support Yes
    WiFi Yes
    GPu Mali400
    3g Usb dingle supported but only Tata Photon plus
    From the spec it is clear that Zync Z990 Plus is winner in terms of
    Processor
    Ram
    Battery
    I have no idea of Zync
    a reliable company or not
    am not sure about the Gpu in Zync
    all 3g modems supported or not
    If any one used this product or any other Zync Tablet plz write
    How is the screen
    User Interface
    overall Layout
    display quality
    built quality
    and over all If it is a value for Money or Not?
    plz help Me out guys as soon as possible coz if get good remarks or reviews i ll buy 2day only at Rs6990
    Popular Gadget Deals
  2. #2
    Alpha Geek funskar's Avatar
    Sep 2011
    India
    Default Re: Tablet (Zync Z990 Plus VS Micromax Funbook)
    [SPOILER] [B]||i5-2500K[/B]|[B]Ga Z68xp-Ud4[/B]|[B]Ripwas X 8gb[/B]|[B]Vx550[/B]|[B]Seagate 1Tb+500Gb+250gb[/B]|[B]Asus Xonar Dx 7.1[/B]|[B][/B]|[B]Xbox 360 Controller[/B]|[B]Haf 922[/B]|[B]Ps3[/B]|[B][U]Zotac GTx 670 Amp [/B][/U] [/SPOILER]
  3. #3
    Jul 2012
    Guwahati
    @Funskar
    it is good but my friend cannot extend more than that
    Under Rs. 10,000 tablet comparison
    got a great Website that cleared my all questions
    have asked my friend 2 go 4 Micromax Funbook at RS 6299 4m Saholic
    Max 6 days with Cash on delivery
  4. #4
    Jul 2010
    Mumbai
    There is no point in buying cheap tablets < 6-8K IMO.
    Core-i5 2400 | Intel DH67BL | G.Skill 8GB DDR3 1333Mhz | 500GB Segate | CM 430 | Corsair VX550 PSU| BENQ V2410 eco LED Monitor | Genuine windows 7 & 8 64-bit | Google Galaxy Nexus, Samsung Galaxy S & boring Nokia Lumia 800 , iPad 4 | Lumia 520
  5. #5
    Broken In ankit.kumar010203's Avatar
    May 2012
    Dhanbad, Jharkhand
    Smile Re: Tablet (Zync Z990 Plus VS Micromax Funbook)
    GO FOR Ainol Novo 7 Elf II...
    CLICK HERE TO KNOW DETAIL Ainol Novo 7 Elf II 7 Inch Capacitive Touchscreen Dual Core 1.5GHz Android Tablet
    ABOUT ME- [url]http://about.me/ankitagrahari[/url]
    Please Like My Facebook Page-- [url]https://www.facebook.com/pages/Technology-Worm/144774892328288[/url]
    And Visit My Blog-- [url]http://technologyworm.blogspot.in/[/url]
  6. #6
    Jul 2012
    Guwahati
    @ Noob n @ ankit
    my friend cannot extend more than 7k so wht iz point of reffering upper range Tablets
    n a new conter i found iz
    IRA THINK2 at Rs6500
    all spec same as Funbook only diff is 1.2Ghz processor n 1.3 mp camera n dnt knw about dual mali 400 graphics
  7. #7
    Jul 2008
    Chennai
    If ur budget is quite tight then go for ainol mars ..
    Ainol Novo 7inch Mars HD Display Android 4.0 4.0.3 Tablet Cortex A9 1GB RAM 8GB | eBay
    Better resolution(1024x600),better battery life (3700mAh),1 gb ram n 8 gb internal memory but lacks hdmi ..
  8. #8
    May 2012
    Dhanbad, Jharkhand
    Quote Originally Posted by aAdirulz View Post
    @ Noob n @ ankit
    WISHTEL IRA THING2 Is ALSO GOOD TABLET....YOU SHOULD ALSO HEAD OVER THIS....I HAVE ONE MORE TAB THAT IS BSNL Penta Tablet T-PAD IS703C Android ICS
  9. #9
    Sep 2005
    I bought Zync 990 and its firmware was buggy. it keeps on restarting. customer care seldom picks up phone. it took 3 months to get it repaired. finally after 3 months of purchase i had working tablet. display is poor. 1.2 GHz processor and 1 GB RAM doesn't give performance it is supposed to give.
  10. #10
    Jul 2012
    Zync Tabs are good. I have heard that minor hanging issues are with every Indian tablet in the market. By comparison of Value for money, Zync tablets are slightly better than the rest.
    I own a Zync Z990 and if used as a tablet and not ruggedly as a Laptop (most of us tend to do so with Tablets), then these devices work efficiently.
    Tablets are not meant for doing those hardcore stuff, especially tabs in the sub 8k range. Micromax and Zync are equally good, but I chose Zync because of free Screen Guard and free Carry pouch with it which reduce the actual cost a little with obviously a little more specs than Micromax.
  11. #11
    Jul 2012
    Guwahati
    Guys help me i took the Funbook from my friend and i was installing some apps from the google play store after some (15min) when i tried to make the screen on it did not so i used the reset option at last but after that only micromax thumb logo comes and stay that way. i kept it that way till the morning and the battery died. and when i plug in the charger it shows the same thumb logo
    m very upset as it was of my friend so ny1 facing yhe problem plz help
  12. #12
    Racing 24X7 NitrousNavneet's Avatar
    Apr 2011
    Indore (M.P.)
    >>Intel dual core 2.20 GHz >>Asus P5GC-MX/1333 >>2*2 Gb Ram >>500Gb Seagate >>Sapphire 6670 ddr3 1gb>>Windows 7 ultimate X64
    [URL="http://www.thinkdigit.com/forum/bazaar/171481-1-month-old-pug-dog.html#post1861903"][U][I][B]PUG DOG FOR SALE[/B][/I][/U][/URL]
    [I][B][U][URL="http://www.thinkdigit.com/forum/hardware-q/165060-no-sound-intex-2600-watt-speakers.html"]NEEDED HELP [/URL][/U][/B][/I]
  13. #13
    Aug 2011
    check this link..it covers most of the tablets under 10k that come with warranty..
  14. #14
    Jul 2012
    Guwahati
    hey Guys My Micromax Tablet was Dead within a week n same with my M2 both 4m Micromax n online SAHOLIC. submitted the product at micromax care by 2ndAUG bt till now no +ve till now when i talk to them they say this week and after that next week so n so. at last when I contact the Micromax care (18605008286) they said it will take another 20 more days coz it was A CHANGE OF BOARD. so when i asked about a new one he said that if the borad is changed its completely new only n when i asked about the extended warnty he said contact at micromaxinfo.com r so plz help r give me a solution
  1. Micromax Funbook
    By Tenida in forum Mobiles and Tablets
    Last Post: 30-06-2013, 10:17 PM
  2. Micromax Funbook
    By testuser in forum Buying Advice
    Last Post: 29-06-2012, 08:39 PM
  3. Zync Z909 Android Tablet
    By mayanksahni in forum Reviews
    Last Post: 15-10-2011, 01:49 PM
