Results 1 to 7 of 7
Thread: Buying advice
  1. #1
    Jul 2012
    Default Buying advice
    Choice of handset between samsung s2 and xolo x900. I am inclined towards apps,dispaly(size n quality both) and sound.
    Can you suggest me any other handset within the same range as a better choice(android only)?
  2. #2
    Explorer aroraanant's Avatar
    Mar 2011
    Aligarh>>>Delhi
    Default Re: Buying advice
    In that budget its better to get Xperia S
    Or can extend the budget a lil bit and can get One X or Note
    HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
    Sony 5.2ch Component home Entertainment System HT-M5
  3. #3
    Apr 2012
    Noida,India
    Xolo for 22k and S2 for 25k ...S2 is better
    please tell your budget as Xperia S is for 28-29k while HTC ONE X is for 33k
  4. #4
    In The Zone Nighthawk12's Avatar
    Jan 2012
    From where u can get s2 for 25k?
  5. #5
    Apprentice Professor X's Avatar
    Jun 2012
    Quote Originally Posted by Nighthawk12 View Post
    Try some local electronics market where you can bargain, my friend bough recently for 26k.
  6. #6
    Apr 2012
    Noida,India
    yeah right ....checkout local stores and shops in your city ....its easily available for 25k if u bargain
  7. #7
    Jan 2012
    There are saying 27k..no less ;(
  1. Buying Advice of buying a Fridge in 17K ?
    By Sainatarajan in forum Consumer electronics and everything else
    Last Post: 27-05-2012, 09:36 PM
  2. Buying advice
    By n64freak in forum Laptops and Netbooks
    Last Post: 27-05-2012, 08:33 PM
  3. PC buying Advice 45k
    By dinu630 in forum PC Components / Configurations
    Last Post: 18-04-2012, 11:25 AM
  4. Buying Advice
    By The Conqueror in forum PC Components / Configurations
    Last Post: 25-04-2011, 10:21 PM
  5. Buying advice for cpu in 8k
    By soumya.b in forum PC Components / Configurations
    Last Post: 13-04-2011, 08:01 AM
