Results 1 to 20 of 20
Thread: Need a phone in 15k..
29-06-2012, 09:27 PM #1Gamer
- Join Date
- Jul 2011
- Location
- Bhubaneswar
- Posts
- 602
I need a phone within the specified budget.. the best that is available within this or for slightly more.. The thing is my brother will be buying it from dubai.. so you can suggest some in the price range for that country if possible.. thanks.
Gaming Rig:
29-06-2012, 09:39 PM #2
A bit offtopic:
Will you get proper warranty here if you buy in Dubai? Also I heard that things are expensive there. Dunno if its true.Spoiler:
29-06-2012, 09:45 PM #3Gamer
- Join Date
- Jul 2011
- Location
- Bhubaneswar
- Posts
- 602
Re: Need a phone in 15k..
Bro said would be cheaper.. I'm confused now..
Gaming Rig:
29-06-2012, 10:01 PM #4
I would play it safe and buy it here. Check Neo V and Motorola Defy plus. Or you can buy the HTC One V of you can get it for 16-17k.
And a bit of advice. Always try to play with a device in shops like croma before buying any phone.Spoiler:
30-06-2012, 02:30 PM #5Gamer
- Join Date
- Jul 2011
- Location
- Bhubaneswar
- Posts
- 602
I'll keep that in mid. What are your views about Xperia U ?
Gaming Rig:
30-06-2012, 08:16 PM #6In The Zone
- Join Date
- Apr 2012
- Location
- Noida,India
- Posts
- 394
30-06-2012, 09:57 PM #7Gamer
- Join Date
- Jul 2011
- Location
- Bhubaneswar
- Posts
- 602
Then what do you suggest ?
Gaming Rig:
30-06-2012, 10:24 PM #8In The Zone
- Join Date
- Apr 2012
- Location
- Noida,India
- Posts
- 394
Spend a little more and go for HTC ONE V
01-07-2012, 10:41 AM #9Gamer
- Join Date
- Jul 2011
- Location
- Bhubaneswar
- Posts
- 602
Its single core right ? I can live with the 4gb limitation but I need the dual core
Gaming Rig:
01-07-2012, 12:03 PM #10
01-07-2012, 12:24 PM #11Gamer
- Join Date
- Jul 2011
- Location
- Bhubaneswar
- Posts
- 602
Has it got any issues except the memory limit ? I won't store any song/videos in the phone..
Gaming Rig:
01-07-2012, 12:51 PM #12
Not really. but you might want to check out the phone before buying.
01-07-2012, 02:24 PM #13Broken In
- Join Date
- Jul 2010
- Posts
- 101
01-07-2012, 03:07 PM #14
Have you considered Nokia Lumia 710?
Neo TDF > TDF 6.5
Ignorance of FORUM RULES is no defence.
01-07-2012, 03:14 PM #15Gamer
- Join Date
- Jul 2011
- Location
- Bhubaneswar
- Posts
- 602
I need a mobile with Android.. although if Lumia is very good in this budget against any other android.. ill consider that phone too..
Gaming Rig:
01-07-2012, 04:36 PM #16In The Zone
- Join Date
- Apr 2012
- Location
- Noida,India
- Posts
- 394
I dont suggest windows mobile now ..coz they wont be updated to windows 8
If you need a dual core why no go for Xperia Sola ...it even doesnt have memory problem like Xperia U as it has a micro SD slot ....its around 18-18.5 here ..so maybe u can get a little cheaper there? ....coz i believe it better to spend some money more and go for a much better phone
01-07-2012, 06:53 PM #17Gamer
- Join Date
- Jul 2011
- Location
- Bhubaneswar
- Posts
- 602
^^ Amen to that. I'll ask there if its any cheaper..
Gaming Rig:
02-07-2012, 10:51 AM #18Apprentice
- Join Date
- Jul 2008
- Location
- Chennai
- Posts
- 80
Or take a look at this.. New deals from ebay
eBay.in Tech Carnival 2012- Get unbeatable price on Mobiles, Laptops, TVs, Tablets and more.
Arc s for oly 15k
02-07-2012, 06:43 PM #19In The Zone
- Join Date
- Apr 2012
- Location
- Noida,India
- Posts
- 394
Arc S is a bit old
02-07-2012, 11:28 PM #20
First of all you won't get warranty on phones bought from Dubai.
Neo V and Sola seems to quite good options for you.
One V is having some software otherwise its a great phoneHTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
Sony 5.2ch Component home Entertainment System HT-M5
Now, Windows 7 on a phone! And ViewSonic is set to launch WinXP phone…
By NewsBytes in forum Technology NewsReplies: 4Last Post: 19-11-2009, 06:19 AM -
Please suggest a phone !! No, not a mobile phone. Normal Corded Phone
By din in forum Chit-ChatReplies: 7Last Post: 11-09-2008, 12:09 PM -
Forget the cell phone, here comes the DELL phone!
By koolbluez in forum Technology NewsReplies: 24Last Post: 26-02-2007, 11:44 PM -
Which 1...mp3 player+cell phone (or) Wlkman Phone...
By deepakprabhakaran in forum Mobiles and TabletsReplies: 8Last Post: 20-10-2006, 09:26 PM -
Looking for a cell phone withing Rs. 12K. SE w300i, Moto RAZR V3i or any other phone
By mehulved in forum Mobiles and TabletsReplies: 15Last Post: 19-07-2006, 01:27 PM
LinkBack URL
About LinkBacks
