Results 1 to 9 of 9
  1. #1
    Right Off the Assembly Line nixhead's Avatar
    Apr 2011
    Default Best Rough 'N' Tough Android in 6K
    So it's like this, I have Nexus S and I am very happy with it, but company is offering me an official buy for 6K. As an Android enthusiast I just want to get back with an Android only. But as I already have a mainstream android, I have diff requirements for this buy:
    • Maximum Battery power
    • Best build quality(Rough n tough)
    • No compromise with phone's internal component-quality
    • Not necessarily a touch screen phone as it will make it delicate and will eat a lot of power
    Thanks in Advance guys!
  2. #2
    Human Spambot clmlbx's Avatar
    Aug 2006
    Indore
    Default Re: Best Rough 'N' Tough Android in 6K
    I don't think you can get those features under 6K
    well anyway check this thread
    Athlon II X4 635 @ 2.9Ghz Gigabyte GA-MA785GMT-US2H Kingston 2x2 Gb 1333Mhz DDR3 WDC 500Gb Green Palit GTS 250 512mb Tagan 500W Samsung B2030 Lg DVD Writer
  3. #3
    Explorer aroraanant's Avatar
    Mar 2011
    Aligarh>>>Delhi
    Extend your budget and get Explorer for 8k
    That is the best you can get
    HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
    Sony 5.2ch Component home Entertainment System HT-M5
  4. #4
    Tech is my oxYgen techofreako's Avatar
    Jun 2012
    Your budget is too low for android phone..
    In 6k u can get micromax a52, dual sim android phone
  5. #5
    making future better Vyom's Avatar
    May 2009
    New Delhi
    Rough 'N' Touch?
    Buy a brick then!
    It's a crime to buy an Android phone less then Rs. 8K, and then repent later.
    Wait till you can extend budget to a little more, or buy something else than Android.
  6. #6
    Feb 2012
    Amritsar
    Thumbs up Re: Best Rough 'N' Tough Android in 6K
    Add 800 Rs. and get Galaxy Y.Don't buy anything from the 'desi' companies above Rs. 1000.Also if you can wait for some time,and increase your budget in that time, go for Sony Xperia Tipo(9k as per the rumours).I am also waiting for the phone.
  7. #7
    Apr 2011
    Thanks all for reply!
    See I have a smart phone(NEXUS) with me already.
    But my company is reimbursing a phone of amount 6K.
    So I want a supportive phn which is tough and have good battery backup and preferably an Android(However if other better deal is there, I don't have any issue)
  8. #8
    May 2009
    New Delhi
    ^^ Lol, it you already have a good Android, then why not buy a Nokia phone or something, which would give you a better battery life!
    Refer this thread to have some good phones at the mentioned price: http://www.thinkdigit.com/forum/buyi...ne-2012-a.html
  9. #9
    Apr 2012
    Noida,India
    Yes as u already have a good android phone ...go for a Nokia phone ...preferably go for one in the Asha series ...they are long lasting and durable as well and also you will get a long lasting battery phone
  1. Best Rough 'N' Tough Android in 6K
    By nixhead in forum Mobiles and Tablets
    Last Post: 19-06-2012, 04:56 PM
  2. tough cleaning
    By arpanmukherjee1 in forum QnA (read only)
    Last Post: 31-07-2009, 08:38 AM
  3. It's tough to be a Man
    By s18000rpm in forum Chit-Chat
    Last Post: 26-04-2008, 06:55 PM
  4. too tough to decide??
    By Optimus Prime in forum Mobiles and Tablets
    Last Post: 09-11-2007, 12:17 PM
  5. AMD in rough waters..!!
    By prasad_den in forum Technology News
    Last Post: 12-03-2007, 08:57 AM
