Results 1 to 4 of 4
  1. #1
    May 2009
    Exclamation Best smartphone under 20,000?
    I am looking to buy a smartphone under Rs. 20,000.
    1)I'm looking for a phone which looks stylish.
    2)It should have a big screen.
    3)It should be full touch i.e. no qwerty keypads.
    4)It should have a nice camera.
    5)It should have a nice processor (preferably dual core).Does dual core processor matter that much?
    6)It should have a nice battery life.
    7)It is preferable if it has the latest android version (ice cream sandwich).Does the android version really matter that much?
    8)The phone should not be too old.It should not be older than 2011.
    So please give your expert opinion guys and help me buy a nice phone
  2. #2
    Alpha Geek masterkd's Avatar
    Feb 2011
    Kolkata
    Default Re: Best smartphone under 20,000?
    HTC Incredible S @19k
    or If you can afford a little bit more then HTC Sensation @22k
    i5 2500K|P8Z68 V PRO|560Ti Hawk|G Skill 8GB 1600MHz|SG 500 GB|WD Passport 1TB|TX850V2|690II Advanced|BenQ G2420HD|Razer Cyclosa Bundle|Razer Goliathus|APC 1.1 KVA|TP LINK WR841N WiFi Router|Windows 7 X64|XBOX 360 wireless controller
    Samsung Galaxy Note
    Steam: masterkdxp
  3. #3
    Explorer aroraanant's Avatar
    Mar 2011
    Aligarh>>>Delhi
    If you can extend your budget by just 2k then Sensation and Xperia P are very good options
    HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
    Sony 5.2ch Component home Entertainment System HT-M5
  4. #4
    Sony Loverboy randomuser111's Avatar
    Jul 2011
    I think your best bet would be Xperia P. But you would need to stretch your budget by 2k.
    It has a brilliant 8mp camera, much better than the Incredible S and Sensation cameras.
    Also looks much better with aluminum unibody
  1. A Smartphone under 12k ?
    By Abhishek_Z in forum Buying Advice
    Last Post: 22-07-2012, 03:43 PM
  2. Need a smartphone around 25k
    By Nighthawk12 in forum Buying Advice
    Last Post: 06-07-2012, 01:14 PM
  3. Why did you buy a smartphone?
    By Sarath in forum Chit-Chat
    Last Post: 03-12-2011, 12:11 PM
  4. A smartphone around 10k??
    By Dustin879 in forum Buying Advice
    Last Post: 13-11-2010, 11:05 PM
  5. want to buy an smartphone
    By coolhisham4u in forum Buying Advice
    Last Post: 09-06-2010, 11:47 AM
