Results 1 to 14 of 14
30-04-2012, 10:44 AM #1
Which is better??Nokia 701 or Samsung Omnia W??
Hi folks,
I am soon going to buy a Smartphone and want to get the best one under 16k-18k. I've narrowed to Nokia 701 and Samsung Omnia W!
The mobile phone should be Future proof for somewhat 2 years!
30-04-2012, 11:19 AM #2Right Off the Assembly Line
- Join Date
- Feb 2012
- Posts
- 3
Re: Which is better??Nokia 701 or Samsung Omnia W??
Omnia W as it has a better screen (super amoled) and a front camera. And most probably you wont like to use any of them till two years as none of the current devices can upgrade to wp8 due to a major kernel change and all of them already use dated hardware. Even a galaxy s with ics scores more in browser benchmarks.
30-04-2012, 11:32 AM #3
Omnia W.Period.
HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
HP ENVYM6 | Intel i5 3210M 2.5 GHz | 8GB DDR3 1600 Mhz | AMD Radeon 7670M | 1TB
Samsung Galaxy Tab 2 |7.0 P31000
30-04-2012, 11:54 AM #4Sage of the Six Paths
- Join Date
- Sep 2011
- Posts
- 925
Lumia 710.
30-04-2012, 12:17 PM #5Alpha Geek
- Join Date
- Jun 2008
- Location
- 26.6932 n , 88.423 s. Locate me on google maps
- Posts
- 795
dont go by specifications alone . nokia 701 (not lumia 710) have extremely vibrant and bright screen. its one of the best screen under direct sunlight and remains perfectly legible . also this phone is quite fast, camera is crazy fast , have great multimedia capability.
that said ,IMO the best phone in that budget will be HTC one V. both Omnia W and 701 have OS that will be outdated in 6-12 months. omnia W wont get windows phone 8 and 701 dont have very good app supports . go with One V , i'm pretty sure it'll be good for 1-2 years atleast , until Andriod jelly bean catches up.
30-04-2012, 12:18 PM #6
If you want t o get a windows phone then get Omnia otherwise I would suggest you to get android phone, you have a got a lot of options in your budget like Incredible S, Desire S, Neo V and One V
HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
Sony 5.2ch Component home Entertainment System HT-M5
30-04-2012, 12:19 PM #7
701 is pathetic with Symbian OS.
30-04-2012, 02:50 PM #8
Is omniaw better than nokia 701 in terms of gaming performance?
30-04-2012, 02:52 PM #9Make Way the LORD is Here
- Join Date
- Dec 2005
- Location
- Old Trafford - The Theatre of Dreams
- Posts
- 2,237
For games , omniaw
Go for Omnia w overall
30-04-2012, 03:13 PM #10
Samsung Omnia W is obviously the better choice
30-04-2012, 03:25 PM #11
Is there any way to jailbreak omnia w
30-04-2012, 03:32 PM #12Right Off the Assembly Line
- Join Date
- Apr 2012
- Posts
- 4
Samsung Omnia W. Recently my friend got it and I checked it out. Awesome display and very smooth OS. Also the windows marketplace is growing at a fast pace and MS will surely pump enough money into this.
Thanks,
Subu.
30-04-2012, 04:49 PM #13
Omnia W has a better OS... better than Symbian, not Android...
There are a few games, but not really on par with Android or iOS. I have a Samsung Focus. Need for Speed on that phone runs very smoothly, but graphics leave much to be desired...
You have Angry Birds, Fruit Ninja and a few other famous games...
As for jailbreaking, I have interop unlocked my Samsung Focus. Don't know if that same method might work for Omnia W...Swimming is not a sport. Swimming is a way to keep from drowning. That’s just common sense!
--- George Carlin
30-04-2012, 07:16 PM #14
Thanks all for clearing my doubts
Nokia Lumia 800 or Samsung Omnia W
By sambitshankar in forum Buying AdviceReplies: 13Last Post: 20-05-2012, 12:56 PM -
Samsung Omnia or Defy Plus??
By Suman in forum Buying AdviceReplies: 34Last Post: 10-05-2012, 08:13 AM -
By pratyush997 in forum Mobiles and TabletsReplies: 13Last Post: 30-04-2012, 07:16 PM -
Samsung Omnia W or Nokia Lumia 710
By pratyush997 in forum Buying AdviceReplies: 3Last Post: 25-04-2012, 12:08 AM -
Samsung Omnia
By sujoyp in forum Mobiles and TabletsReplies: 17Last Post: 23-08-2008, 09:19 PM
LinkBack URL
About LinkBacks
