Results 1 to 9 of 9
16-04-2012, 01:29 AM #1Right Off the Assembly Line
- Join Date
- Apr 2012
- Posts
- 1
A good mobile phone under Rs. 18000.
Hi guys.
I'm looking for a good reliable mobile phone under Rs 18000.
My main priorities are:
Android/Windows Phone
3.7"+ screen
FRONT-FACING CAMERA (MUST - Many phones lack this one)
Fast and Fluid UI
If android, then Ice Cream Sandwich update should be available in the future.
A good camera.
I've seen a lot of phones which are good and well in price namely:
HTC One V (but lacks a front camera)
Micormax A85 (ICS is unlikely)
LG Optimus Black (Terribly slow UI, IDK if ICS would make it faster)
LG Optimus Sol (Descent Build Quality, but is faster than Black. In consideration)
Sony Ericsson Xperia Neo V (Looks wierd, but is a good choice. In consideration)
Samsung Omnia W (Less Apps, but nice phone. In consideration)
So, what I shortlisted are :
Optimus Sol, Xperia Neo V, Omnia W. Is there any other present out there? i would love to know. Which one would you prefer in these phones (with reason)?
Thanks.
16-04-2012, 05:40 AM #2
Re: A good mobile phone under Rs. 18000.
Since you want a fast and fluid UI get the Omnia W
Windows Phone 7.5 is a great OS and gives a good fluid enduser experience. There are a few constraints though like you cannot transfer files over bluetooth. Otherwise the phone is very good.
16-04-2012, 07:49 AM #3
LG's stock Android ROMs are buggy and unoptimized. Also, their updates are very slow (ICS for OBlack is in Q3 2012 I believe). So unless you're ready to flash custom ROMs, look elsewhere. SE Xperia Neo V seems to your best bet. Good hardware, proper support, plus upcoming official ICS update. If not wanting Android, then go for the Samsung Omnia W.
"War doesn't determine who's right: only who's left." - Bertrand Russell
"I may disagree with what you say, but I will defend to my death your right to say it." - Voltaire
"All that is necessary for evil to succeed is for good men to do nothing." - Edmund Burke
16-04-2012, 01:18 PM #4
Stay away from Neo V... I have personally used it.. its a bang for the buck with all the features and the attractive price.. but terrible build quality...
Check this thread...
Hardware problems with the Xperia Neo V?
16-04-2012, 01:24 PM #5
Samsung Ominia W is gr8 windows phone
HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
HP ENVYM6 | Intel i5 3210M 2.5 GHz | 8GB DDR3 1600 Mhz | AMD Radeon 7670M | 1TB
Samsung Galaxy Tab 2 |7.0 P31000
16-04-2012, 01:46 PM #6Right Off the Assembly Line
- Join Date
- Apr 2012
- Location
- Pune/Jamshedpur
- Posts
- 7
Sony Ericsson Neo V is a good choice but if you want to use front cam for 3g video calling it does not support that...you can only do video chat via gtalk/skype... same goes with windows phone
For Neo V Sony has already announced ICS update...seeding in foreign countries now...maybe in 4-6 weeks it will land in India too..
check for other phones also whether they allow 3g video calls over the network...
17-04-2012, 02:22 AM #7
I would like to suggest you Incredible S for 18-19k or One V for 18k.
And if you are ok with the windows phone after knowing all its pros and cons then Omnia W is a very good option that too for 15kHTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
Sony 5.2ch Component home Entertainment System HT-M5
17-04-2012, 02:48 AM #8
HTC One V is of 17.4k at buytheprice.com
17-04-2012, 12:00 PM #9
Well, at your budget, only two phones hold good IMO, those are SE Neo V and Omnia W. I have used both. Neo V's build quality is good, the back is a fingerprint magnet, has a front facing cam and primary cam is 720p recording capable. But if you want Windows Phone, then go for Omnia W. Here's a link which will make you take the decision easily. \
Samsung Omnia W vs Sony Xperia neo VReview : Samsung Galaxy S3 I9300
How well will this game run on my Graphics Card
Gaming Rig
AMD Phenom X4 960T | Gigabyte GA970A-UD3 | Corsair XMS3 4GB | Gigabyte HD7850 OC | Caviar Blue 500GB | Seasonic S12II 520W | Dell ST2320L | Corsair 300R
By isimmy.1994 in forum Mobiles and TabletsReplies: 5Last Post: 16-04-2012, 01:46 PM -
Android phone below 18000
By abhishek12 in forum Mobiles and TabletsReplies: 17Last Post: 14-11-2011, 07:28 PM -
Please Suggest me a Good Mobile Phone
By The Conqueror in forum Buying AdviceReplies: 12Last Post: 16-10-2008, 03:26 PM -
suggest me good mobo+cpu+GFX=18000
By avi_avadhut in forum Graphic cardsReplies: 6Last Post: 17-05-2005, 05:16 AM -
PDA phone under RS.18000
By Shikhar in forum Mobiles and TabletsReplies: 2Last Post: 28-03-2005, 08:55 PM
LinkBack URL
About LinkBacks
