Results 1 to 21 of 21
Thread: New Android Phone
31-01-2012, 06:18 PM #1
New Android Phone
finally i am gonna have an android....
so i need help of you guys...
1. Budget?
9k
2. Display type and size?
Touchscreen only and 3.2inch or more preffered
3. Form Factor? bar, slider, flip?
no preference
4. Preferred choice of brand?
no pathetic Indian companies please
5. Preferred input method (QWERTY, touchscreen, numpad, touch-n-type).
touchscreen
6. What camera option you want? Please specify need for flash, autofocus, front facing camera.
front facing camera will be a bonus
7. Preferred operating system? (Android, Symbian, iOS, Windows Phone etc).
android only
8. Preferred connectivity options (3G, Wifi etc)Please specify clearly.
3G needed...
9. Preferred applications (Flash, Swype, GPS, etc)?
GPS and flash
10. Primary use of handset (multimedia, camera, mails, internet, gaming etc)?
everything, from gaming to internet, songs videos and blah blah blah
11. Any specific mobile phones in consideration?
not yet
12. Any other info that you want to share
please try not to tell any phone above 10k (upto 9k preffered)...Intel Core 2 Quad Q8400 |Asus EAH4350 HD| WD blue 500GB | Intel DG41RQ | 2GB DDR2 | HP DVD-RW | Creative 2.1 | SAMATRON 55V |
Samsung Galaxy Y|| XOLO A700
Garena id- pramudit
My coil Gun
31-01-2012, 06:55 PM #2
Re: New Android Phone
You should increase your budget and get a Motorola Defy. If you are lucky, you might be able to bag one for around 12k-13k range... A friend of mine bought Defy a few months ago for 13.5k, so I believe the price should have come down even more... That phone is totally VFM premium phone, and you won't need any other upgrade for more than a year...
But if you just cannot increase your budget, then I would recommend HTC Explorer. Its on Sulekha @9.8k...Swimming is not a sport. Swimming is a way to keep from drowning. That’s just common sense!
--- George Carlin
31-01-2012, 07:07 PM #3
Garena id- pramudit
My coil Gun
31-01-2012, 07:35 PM #4
I don't think u will get gaming, front camera, flash support android phone at this price range. try HTC Explorer or LG Optimus Net. or Increase your budget.
To Much Ego Can Kill Your Talent! :)
31-01-2012, 07:39 PM #5
I can leave front camera but flash is really a requirement...
Garena id- pramudit
My coil Gun
31-01-2012, 08:04 PM #6
officially flash is possible on HTC Explorer. LG Optimus One/Net or similar mobiles can't run flash content. though unofficially it is very much possible.
get HTC Explorer. don't be fooled by the 600Mhz processor. it can match 800Mhz clocked Wildfire S. else Optimus Net is the only viable option.
31-01-2012, 08:21 PM #7
Ok, i was earlier thinking for galaxy Y but i dont't like its camera and small screen....
just one more question, both these phone have unlocked bootloader or not because i will be installing custom roms....Last edited by pramudit; 31-01-2012 at 08:41 PM.
Garena id- pramudit
My coil Gun
31-01-2012, 08:50 PM #8
HTC, Motorola & even SE = locked bootloader.
Samsung, LG = unlocked bootloader.
31-01-2012, 08:55 PM #9
@op,I can understand your situation bro.
You have read a lot about Android,some of your friends have Android phones,which they flash at the slightest of opportunity.
Now,you want your share of Android.
Now,as an elder brother I will try to give you some friendly advice....you can always ignore them if you want to.
1.Do not expect anything magical in Android,just like Symbian it is just another mobile o.s.
Your old Nokia probably has all the basic functionalities of Android.
Along with them Android has SOME useful and LOADS OF USELESS features and 3rd party apps.
2.Just imagine how will Windows7 HP behave in a Pentium 4 system with 512 MB of memory.
Budget Android phones are like that.
Sub 10k phones are sluggish like snail with screen quality slighhtly better than those of those Micromax transreflective screens.
Gaming and watching videos is a torture in these devices.
3.You will be amazed how bad these phone sounds compared to your 5k Nokia through headphones.
Now do you want such a phone?
Ask yourself.
There are a couple of decent Android phones like ZTE blade or Optimus Net which you can buy,but I will suggest you to wait and save up a little more(from your pocket money),till you have around 15-16k.
If you love portable gaming...ditch smartphones for a psp(I did that,when I was a kid...and that was the best decision I have ever made)
P.S. Me not an Android hater,learning and working on Android since Eclair.Macbook Air 11"2011,Iphone 4S 16GB,Ipad2,Sennheiser HD-25 1-II,HD650,FiiO(E11,E17...yeh! I know!I need an upgrade)
31-01-2012, 09:03 PM #10
@sam now i am really confused between samsung galaxy Y, htc explorer and optimus net...
which one to go...?
@red dragon i am not even in a college yet, so a budget smartphone will be enough for me to do androiding... Also i like computer to play games rather than the consoles...Intel Core 2 Quad Q8400 |Asus EAH4350 HD| WD blue 500GB | Intel DG41RQ | 2GB DDR2 | HP DVD-RW | Creative 2.1 | SAMATRON 55V |
Garena id- pramudit
My coil Gun
31-01-2012, 09:30 PM #11
Since your budget permits get optimus net. It is a better phone overall than galaxy y
Follow me on Twitter: http://twitter.com/wuodland
Have a look at my Photography page: http://bit.ly/N2aMTi
01-02-2012, 10:56 AM #12siddhipatelGuest
As per your requirement I think Samsung Galaxy Y, Samsung Galaxy Pop, Samsung Galaxy Fit are some of the options available to you. You can choose the one which suits your requirement the best.
01-02-2012, 02:51 PM #13
@thetechfreak thanx...
@siddhipatel that galaxy fit has pathetic screen, i've used it and it appears that pixel are really far away and images become a dot matrix print...
Hows acer liquid, i know its difficult to find but is it better than net or explorer...?Intel Core 2 Quad Q8400 |Asus EAH4350 HD| WD blue 500GB | Intel DG41RQ | 2GB DDR2 | HP DVD-RW | Creative 2.1 | SAMATRON 55V |
Garena id- pramudit
My coil Gun
01-02-2012, 03:01 PM #14Apprentice
- Join Date
- Sep 2011
- Posts
- 67
Have a look at motorola fire-xt......saw somewhere it is available at 5.7k with 6.5 inch screen 800 Mhz processor and 512 mb ram and with gingerbread update i guess or you can update it too....at this specs its a really good choice....imho !!
Desktop : Core 2 duo E7300 @ 2.67 GHz / 3 gb ddr2 800 MHz / Asus GTS450 directcu 1GB DDR5 :doublethumb: / Corsair VX450 / 500 GB 7200 seagate barracuda / Gigabyte GA-G31M-S2L
Notebook : Samsung NP300E5Z-S01IN - Intel I3-2330 / Intel HM 65 / Nvidia GT 520MX 1 GB ddr3 :chucks: / 4gb ddr3 / 640 gb HDD
01-02-2012, 03:12 PM #15
Garena id- pramudit
My coil Gun
01-02-2012, 04:24 PM #16
--- George Carlin
01-02-2012, 11:11 PM #17
Ohk then...
I'll try to find htc explorer(its hard to found htc in my area)...
If not then i'll go for optimus net dual although i dont need a dual sim but its only 500rs more for dual sim support and higher 3g speed than net(from gsmarena)...
If not net dual then please tell the reason why...!
Also one more question, acc to gsmarena net has ARMv6 cpu while net dual has ARM 11, so which cpu has better instruction set...?
(sorry for lot of questions but this my first android and also i wont be getting any new phone for next 2yrs, so i just wanna make sure that i dont make wrong choice)Intel Core 2 Quad Q8400 |Asus EAH4350 HD| WD blue 500GB | Intel DG41RQ | 2GB DDR2 | HP DVD-RW | Creative 2.1 | SAMATRON 55V |
Garena id- pramudit
My coil Gun
01-02-2012, 11:31 PM #18
10-02-2012, 11:47 AM #19
Bought galaxy y... Lg not found....
Garena id- pramudit
My coil Gun
10-02-2012, 03:30 PM #20
congrats
10-02-2012, 05:50 PM #21
Thanks sam.....
Garena id- pramudit
My coil Gun
Want an android phone around 17K
By parul in forum Buying AdviceReplies: 23Last Post: 14-02-2012, 06:07 PM -
Is it possible to install android on non-android phone
By saurabh595 in forum Mobiles and TabletsReplies: 17Last Post: 08-12-2010, 01:43 PM -
10 reasons why Meego powered Nokia phone can outrun any Android powered phone
By onlyabhi in forum PeripheralsReplies: 19Last Post: 24-11-2010, 01:27 AM -
Android Phone or Android Tablet
By tarundham in forum Laptops and NetbooksReplies: 4Last Post: 14-10-2010, 01:02 PM -
Best android phone under 10k
By rhk217 in forum Buying AdviceReplies: 8Last Post: 14-05-2010, 09:51 PM
LinkBack URL
About LinkBacks
