Page 1 of 30 1 2 3 4 5 6 7 8 9 10 11 21 ... LastLast
Results 1 to 30 of 892
  1. #1
    sam
    sam is offline
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    Default Mobile Buying Guide: May 2013
    Buying a new mobile? All the info you'll ever need at your fingertips.
    IMPORTANT:
    • Mobiles are listed in alphabetical order and doesn't mean the first one is the best and last one the least desired.
    • Any mobile that is rebranded and sold through a local brand is excluded even if the same is manufactured by International company.
    • The database also has an integrated pricelist. Just click the mobile name and you'll be redirected to 91mobiles.com which have latest price offered by different online shops.
    • Whenever i see any major price change or mobile launches, i'll update this thread. So new month doesn't mean addition of new mobiles.
    • Mobile hardware coloured red is old/slow and not recommended at that price while green means better than expected quality.
  2. #2
    sam
    sam is offline
    Jan 2010
    Guwahati
    Android Buyers Guide: Planning to get an Android mobile but confused between various options? Go through the 4 points below to know what to get and what to avoid:
    Display:
    1. Avoid any Android mobile with QVGA resolution (240X320) as most apps as well as games no longer support it.
    2. Avoid mobiles with odd resolution like (768X1024 or 600X1024) as it'll lead to same problem as above.
    3. Try to go for the mobile with highest PPI (pixel per inch) as lower PPI means blurry images and text.
    4. AMOLED/IPS doesn't mean that display will be better rather AMOLED means better black level whereas IPS means better viewing angle.
    5. Gorilla Glass is prone to scratches so a scratch guard is always recommended.
    Processor:
    1. Avoid any Android mobile with ARM11 processing core as those are no longer supported by majority of the apps or by Google itself.
    2. Clockspeed doesn't matter. You can get 1Ghz processor based Android for just 3k which mayn't even support the basic games.
    3. All Android mobile processor has a GPU integrated into the processor/chipset.
    4. Irrespective of mobile or manufacturer, if chipset is same then GPU will be same as well.
    5. Performance wise Cortex A5 < Scorpion < Cortex A7 < Cortex A9 < Krait < Cortex A15. Performance scales equally with increase in cores.
    Memory:
    1. To run smoothly Android mobile need 512MB or more ram depending on the display resolution and processor. Less ram means slowdown.
    2. You get roughly 50% free ram for use once your mobile boots up as GPU & Android system requires system ram.
    3. Rom memory is not same as internal memory. Rom memory is the total memory whereas the free memory is the internal memory.
    4. Mobiles with more than 5GB storage have multiple partition: apps memory (dedicated to apps) as well as user accessible memory.
    Battery:
    1. Check that the mobile ships with at least 1500mah battery else get ready to charge 2 times per day.
    2. Bigger display will require more battery so if screen size is 4.5"+ check that battery is more than 2000mah.
    3. AMOLED is a real battery saver so expect more battery backup.
    4. Try to avoid mobiles with integrated battery as if there is any kind of problem, turning off mobile can be a bit difficult.
    [OPTIONAL] Community support:
    1. Rooting, custom recovery or unofficial Android (custom rom) will break your warranty.
    2. Not all mobiles get same kind of community support so be sure (check XDA, Modaco or Android forum) if you care about custom roms.
    3. Android from Indian brands rarely get any kind of community support.
    Spec Summary:
    Mobiles Lowend Midrange Highend
    Price Below 15k Below 25k Above 25k
    Processor Cortex A5 dualcore/Cortex A9 dualcore Cortex A9/Scorpion dualcore Cortex A9 quadcore/Cortex A15/Krait dualcore
    Ram 512MB 1GB 1GB+
    Display WVGA/FWVGA resolution, 200+ ppi qHD/HD resolution, 250+ ppi HD resolution, 300+ ppi
    Internal Memory 1GB+ 5GB+ 15GB+
    Added Notes: If you want extra stuff like camera with HD video recording or front facing camera or latest Android, check it yourself. My guide covers almost everything.
  3. #3
    sam
    sam is offline
    Jan 2010
    Guwahati
    FROM 2-5K:
    Feature Phone:
    Mobile Display Resolution Input Type Camera Dual Sim Connectivity
    LG Cookie Smart T375 3.2" 240X320 Capacitive Touchscreen 2MP YES WiFi
    Nokia 110 1.8" 128X160 Keypad VGA YES NO
    Nokia 112 1.8" 128X160 Keypad VGA YES NO
    Nokia 114 1.8" 128X160 Keypad VGA YES NO
    Nokia Asha 202 2.4" 320X240 Touch&Type 2MP YES NO
    Nokia Asha 206 2.4" 240X320 Keypad 1.3MP YES NO
    Nokia Asha 210 2.4" 240X320 QWERTY 2MP YES WiFi
    Nokia Asha 305 3.0" 240X400 Resistive Touchscreen 2MP YES NO
    Nokia Asha 306 3.0" 240X400 Resistive Touchscreen 2MP NO WiFi
    Nokia Asha 308 3.0" 240X400 Capacitive Touchscreen 3.2MP YES NO
    Nokia Asha 309 3.0" 240X400 Capacitive Touchscreen 3.2MP YES WiFi
    Samsung E2202 1.8" 128X160 Keypad VGA YES NO
    Samsung E2252 2.0" 128X160 Keypad VGA YES NO
    Samsung Rex 60 2.8" 240X320 Resistive Touchscreen 1.3MP YES WiFi
    Samsung Rex 70 3.0" 240X320 Capacitive Touchscreen 2MP YES WiFi
    Samsung Rex 80 3.0" 240X320 Capacitive Touchscreen 3.2MP YES WiFi
    Android Smartphone:
    Mobile Operating System Display Resolution Camera Dual Sim Processor GPU Ram Internal Memory 3G Connectivity
    Alcatel One Touch 4005D Android 2.3 3.5" 320X480 (165ppi) 3.2MP YES 1Ghz 512MB 1.4GB NO
    Alcatel One Touch 4010E Android 2.3 3.5" 320X480 (165ppi) 2MP YES 1Ghz 256MB 1.4GB YES
    Huawei Ascend Y210D Android 2.3 3.5" 320X480 (165ppi) 2MP YES Qualcomm MSM7227A 1Ghz (Cortex A5) Adreno 200 256MB 150MB YES
    Samsung Galaxy Star duos Android 4.1 3.0" 240X320 (133ppi) 2MP YES 1Ghz 512MB 4GB NO
  4. #4
    sam
    sam is offline
    Jan 2010
    Guwahati
    FROM 5-10K:
    Android Smartphone:
    Alcatel OT 5020E Android 4.0 4.0" 480X800 (233ppi) 5MP (flash, 480p) YES 1Ghz dualcore -- 512MB 1.4GB
    Huawei Ascend G510 Android 4.1 4.5" IPS LCD 480X854 (218ppi) 5MP (flash, 720p) YES Qualcomm MSM8225 1Ghz dualcore (Cortex A5) SGX 531 512MB 4GB
    Huawei Ascend Y300 Android 4.1 4.0" IPS LCD 480X800 (233ppi) 5MP (flash, 480p) NO Qualcomm MSM8225 1Ghz dualcore (Cortex A5) Adreno 203 512MB 1GB
    HTC Desire C Android 4.0 3.5" 320X480 (165ppi) 5MP NO Qualcomm MSM7225A 600Mhz (Cortex A5) Adreno 200 512MB 4GB
    Lenovo A690 Android 2.3 4.0" 480X800 (233ppi) 3MP YES Mediatek 6575 1Ghz (Cortex A9) SGX 531 512MB 512MB
    LG Optimus L3 II Android 4.1 3.2" IPS LCD 240X320 (125ppi) 3MP YES Qualcomm MSM7225A 1Ghz (Cortex A5) Adreno 200 512MB 1.75GB
    LG Optimus L5 II Dual Android 4.1 4.0" IPS LCD 480X800 (233ppi) 5MP (flash, 480p) YES Mediatek MT6575 1Ghz (Cortex A9) SGX 531 512MB 4GB
    Samsung Galaxy Chat Android 4.1 3.0" 240X320 (133ppi) 2MP NO Broadcom BCM21654 850Mhz (Cortex A9) VideoCore 4 512MB 2GB
    Samsung Galaxy Y Plus Android 4.0 2.8" 240X320 (143ppi) 2MP YES Broadcom BCM21654 850Mhz (Cortex A9) VideoCore 4 512MB 4GB
    Samsung Galaxy Music Duos Android 4.0 3.0" 240X320 (133ppi) 3.2MP YES Broadcom BCM21654 850Mhz (Cortex A9) VideoCore 4 512MB 3.7GB
    Samsung Galaxy Young Android 4.1 3.3" 320X480 (176ppi) 3MP YES Qualcomm MSM7227A 1Ghz (Cortex A5) Adreno 200 768MB 2GB
    Sony Xperia E Android 4.1 3.5" 320X480 (165ppi) 3.2MP NO Qualcomm MSM7227A 1Ghz (Cortex A5) Adreno 200 512MB 2GB
    NON-Android Smartphone:
    Mobile Operating System Display Resolution Camera Processor GPU Ram Internal Memory
    Blackberry Curve 9220 BlackBerry OS 7.1 2.4" 320X240 (164ppi) 2MP Marvell PXA940 800Mhz NA 512MB 512MB
    Nokia Lumia 520 Windows Phone 8 4.0" IPS LCD 480X800 (233ppi) 5MP (720p) Qualcomm MSM8227 1Ghz dualcore (Krait) Adreno 305 512MB 8GB
    Feature Phone:
    Nokia Asha 302 2.4" 240X320 QWERTY 3.2MP NO 3G, WiFi
    Nokia Asha 310 3.0" 240X400 Capacitive Touchscreen 3.2MP YES WiFi
    Nokia Asha 311 3.0" 240X400 Capacitive Touchscreen 3.2MP NO 3G, WiFi
    Samsung Rex 90 3.5" 320X480 Capacitive Touchscreen 3.2MP YES WiFi
  5. #5
    sam
    sam is offline
    Jan 2010
    Guwahati
    FROM 10-15K:
    Android Smartphone:
    Mobile Operating System Display Resolution Camera Processor GPU Ram Internal Memory Battery
    Alcatel One Touch Idol Android 4.1 4.7" IPS LCD 540X960 (236ppi) 8MP (flash, 720p) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 4GB Li-Ion 1800 mAh
    Alcatel One Touch Scribe Easy Android 4.1 5.0" 480X800 (187ppi) 5MP (flash, 720p) Qualcomm MSM8225 1Ghz dualcore (Cortex A5) Adreno 203 512MB 2.3GB Li-Ion 2500 mAh
    HTC Desire V Android 4.0 4.0" 480X800 (233ppi) 5MP (flash, 480p) Qualcomm MSM7227A 1Ghz (Cortex A5) Adreno 200 512MB 1GB Li-Ion 1650 mAh
    HTC Desire X Android 4.0 4.0" S-LCD 480X800 (233ppi) 5MP (flash, 480p) Qualcomm MSM8225 1Ghz dualcore (Cortex A5) Adreno 203 768MB 4GB Li-Ion 1650 mAh
    Huawei Ascend G600 Android 4.0 4.5" IPS LCD 540X960 (245ppi) 8MP (flash, 480p) Qualcomm MSM8225 1Ghz dualcore (Cortex A5) Adreno 203 768MB 3.7GB Li-Ion 1930 mAh
    Lenovo P770 Android 4.1 4.5" IPS LCD 540X960 (245ppi) 5MP (flash, 720p) MediaTek MT6577T 1.2Ghz dualcore (Cortex A9) SGX 531 1GB 4GB Li-Ion 3500 mAh
    Lenovo A800 Android 4.0 4.5" IPS LCD 480X854 (218ppi) 5MP (720p) MediaTek MT6577T 1.2Ghz dualcore (Cortex A9) SGX 531 512MB 4GB Li-Ion 2000 mAh
    LG L7 II Dual Android 4.1 4.3" IPS LCD 480X800 (217ppi) 8MP (flash, 480p) Qualcomm MSM8225 1Ghz dualcore (Cortex A5) Adreno 203 768MB 1.8GB Li-Ion 2460 mAh
    Samsung Galaxy Fame Android 4.1 3.5" 320X480 (165ppi) 5MP (flash, 480p) Broadcom BCM21654G 1Ghz (Cortex A5) Videocore IV 512MB 4GB Li-Ion 1300 mAh
    Samsung Galaxy S Duos Android 4.0 4.0" 480X800 (233ppi) 5MP (flash, 480p) Qualcomm MSM7227A 1Ghz (Cortex A5) Adreno 200 768MB 4GB Li-Ion 1500 mAh
    Samsung Galaxy S Advance Android 4.1 4.0" S-AMOLED 480X800 (233ppi) 5MP (flash, 720p) ST-Ericsson U8500 1Ghz dualcore (Cortex A9) Mali 400 768MB 11.3GB Li-Ion 1500 mAh
    Sony Xperia E dual Android 4.0 3.5" 320X480 (165ppi) 3.2MP (480p) Qualcomm MSM7227A 1Ghz (Cortex A5) Adreno 200 512MB 2GB Li-Ion 1530 mAh
    Sony Xperia J Android 4.1 4.0" 480X854 (245ppi) 5MP (flash, 480p) Qualcomm MSM7227A 1Ghz (Cortex A5) Adreno 200 512MB 2GB Li-Ion 1750 mAh
    Sony Xperia Go Android 4.0 3.5" LED-backlit LCD 320X480 (165ppi) 5MP (flash, 720p) ST-Ericsson U8500 1Ghz dualcore (Cortex A9) Mali 400 512MB 4GB Li-Ion 1305 mAh
    Sony Xperia U Android 4.0 3.5" LED-backlit LCD 480X854 (280ppi) 5MP (flash, 720p) ST-Ericsson U8500 1Ghz dualcore (Cortex A9) Mali 400 512MB 6GB (non-expandable) Li-Ion 1320 mAh
    Sony Xperia Sola Android 4.0 3.7" LED-backlit LCD 480X854 (265ppi) 5MP (flash, 720p) ST-Ericsson U8500 1Ghz dualcore (Cortex A9) Mali 400 512MB 5GB Li-Ion 1320 mAh
    BlackBerry Curve 9320 BlackBerry OS 7.1 2.5" 320X240 (164ppi) 3.2MP (flash, 480p) Marvell PXA930 806Mhz NA 512MB 512MB
    Nokia Lumia 620 Windows Phone 8 3.8" 480X800 (246ppi) 5MP (flash, 720p) Qualcomm MSM8627 1Ghz dualcore (Krait) Adreno 305 512MB 8GB
    ANDROID BUYERS NOTE:
    HTC Desire V, Lenovo A770, Lenovo P770, LG L7 II Dual, Samsung Galaxy Fame, Samsung Galaxy S Duos and Sony Xperia E dual are dual sim mobiles.
  6. #6
    sam
    sam is offline
    Jan 2010
    Guwahati
    FROM 15-20K:
    Android Smartphone:
    Alcatel One Touch Idol Ultra Android 4.1 4.6" AMOLED 720X1280 (316ppi) 8MP (flash, 1080p) MediaTek MT6577T 1.2Ghz dualcore (Cortex A9) SGX 531 1GB 16GB (non-expandable) Li-Ion 1800 mAh
    HTC Desire SV Android 4.1 4.3" S-LCD2 480X800 (217ppi) 8MP (flash, 480p) Qualcomm MSM8225 1Ghz dualcore (Cortex A5) Adreno 203 768MB 4GB Li-Ion 1800 mAh
    Lenovo S720 Android 4.0 4.5" IPS LCD 540X960 (245ppi) 5MP (flash, 720p) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 4GB Li-Ion 2000 mAh
    Lenovo S890 Android 4.1 5.0" IPS LCD 540X960 (220ppi) 8MP (flash, 720p) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 1GB 4GB Li-Ion 2250 mAh
    LG Optimus L9 Android 4.1 4.7" IPS LCD 540X960 (234ppi) 5MP (flash, 1080p) TI OMAP4430 1Ghz dualcore (Cortex A9) SGX 540 1GB 4GB Li-Ion 2150 mAh
    Samsung Galaxy Grand Duos Android 4.1 5.0" 480X800 (187ppi) 8MP (flash, 1080p) Broadcom BCM28155 1.2Ghz dualcore (Cortex A9) VideoCore 4 (dualcore) 1GB 8GB Li-Ion 2100 mAh
    Samsung Galaxy Win Android 4.1 4.7" 480X800 (199ppi) 5MP (flash, 720p) Qualcomm MSM8625Q 1.2Ghz quadcore (Cortex A5) Adreno 203 1GB 8GB Li-Ion 2000 mAh
    Sony Xperia L Android 4.1 4.3" 480X854 (228ppi) 8MP (flash, 720p) Qualcomm MSM8230 1Ghz dualcore (Krait) Adreno 305 1GB 5.8GB Li-Ion 1750 mAh
    HTC Windows Phone 8S Windows Phone 8 4.0" S-LCD 480X800 (233ppi) 5MP (flash, 720p) Qualcomm MSM8627 1Ghz dualcore (Krait) Adreno 305 512MB 4GB
    Nokia Lumia 720 Windows Phone 8 4.3" IPS LCD 480X800 (217ppi) 6.1MP (flash, 720p) Qualcomm MSM8227 1Ghz dualcore (Krait) Adreno 305 512MB 8GB
    Desire SV, Samsung Galaxy Grand and Samsung Galaxy Win are dual sim mobiles.
  7. #7
    sam
    sam is offline
    Jan 2010
    Guwahati
    Default The 1-STOP Mobile Buying Guide: August 2012
    FROM 20-25K:
    Android Smartphone:
    HTC One X Android 4.1 4.7" S-LCD2 720X1280 (312ppi) 8MP (flash, 1080p) Nvidia AP33H 1.5Ghz QuadCore (Cortex A9) ULP GeForce 1GB 11GB (non-expandable) Li-Po 1800 mAh
    Samsung Galaxy S2 Plus Android 4.1 4.3" Super AMOLED Plus 480X800 (217ppi) 8MP (flash, 1080p) Broadcom BCM28155 1.2Ghz dualcore (Cortex A9) VideoCore 4 (dualcore) 1GB 8GB Li-Ion 1650 mAh
    Sony Xperia Ion Android 4.0 4.6" LED-backlit LCD 720X1280 (323ppi) 12MP (flash, 1080p) Qualcomm MSM8260 1.5Ghz dualcore (Scorpion) Adreno 220 1GB 12.9GB Li-Ion 1900 mAh
    Sony Xperia SP Android 4.1 4.6" 720X1280 (319ppi) 8MP (flash, 1080p) Qualcomm MSM8960Pro 1.7Ghz dualcore (Krait) Adreno 320 1GB 5.8GB Li-Ion 2370 mAh
    Nokia Lumia 820 Windows Phone 8 4.3" AMOLED 480X800 (217ppi) 8MP (flash, 1080p) Qualcomm MSM8960 1.5Ghz dualcore (Krait) Adreno 225 1GB 8GB
  8. #8
    sam
    sam is offline
    Jan 2010
    Guwahati
    Default The 1-STOP Mobile Buying Guide: September 2012
    FROM 25-30k:
    Android Smartphone:
    HTC One X Plus Android 4.1 4.7" S-LCD2 720X1280 (312ppi) 8MP (HDR, 1080p) Nvidia AP37 1.7Ghz QuadCore (Cortex A9) ULP GeForce 1GB 64GB (non-expandable) Li-Ion 2100 mAh
    Lenovo K860 Android 4.0 5.0" IPS LCD 720X1280 (294ppi) 8MP (flash, 1080p) Samsung 4412 1.4Ghz QuadCore (Cortex A9) Mali 400MP 1GB 8GB Li-Ion 2250 mAh
    LG Nexus 4 Android 4.2 4.7" IPS+ LCD 778X1280 (318ppi) 8MP (photo sphere, 1080p) Qualcomm APQ8064 1.5Ghz QuadCore (Krait) Adreno 320 2GB 16GB (non-expandable) Li-Po 2100 mAh
    LG Optimus 4X HD Android 4.0 4.7" IPS LCD 720X1280 (312ppi) 8MP (DIS, 1080p) Nvidia AP30H 1.5Ghz QuadCore (Cortex A9) ULP GeForce 1GB 12GB Li-Ion 2150 mAh
    Samsung Galaxy S III Android 4.1 4.8" S-AMOLED 720X1280 (306ppi) 8MP (DIS, 1080p) Samsung 4412 1.4Ghz QuadCore (Cortex A9) Mali 400MP 1GB 11.2GB/28GB Li-Ion 2100 mAh
    DIS: digital image stabilization
    HDR: High Dynamic Range imaging
    photo sphere: paranoma mode introduced in Android 4.2
  9. #9
    sam
    sam is offline
    Jan 2010
    Guwahati
    ABOVE 30k:
    Android Smartphone:
    HTC Butterfly Android 4.1 5.0" S-LCD3 1920X1080 (441ppi) 8MP (DIS, 1080p) Qualcomm APQ8064 1.5Ghz QuadCore (Krait) Adreno 320 2GB 11GB Li-Po 2020 mAh
    HTC One Android 4.1 4.7" S-LCD3 1920X1080 (469ppi) 4MP Ultrapixel (HDR, OIS) Qualcomm APQ8064T 1.7Ghz QuadCore (Krait 300) Adreno 320 2GB 11GB Li-Po 2300 mAh
    LG Optimus G Android 4.1 4.7" IPS+ LCD 720X1280 (312ppi) 13MP (HDR, DIS) Qualcomm APQ8064 1.5Ghz QuadCore (Krait) Adreno 320 2GB 25GB (non-expandable) Li-Po 2100 mAh
    Samsung Galaxy Note II Android 4.1 5.5" S-AMOLED 720X1280 (267ppi) 8MP (DIS, 1080p) Samsung 4412 1.6Ghz QuadCore (Cortex A9) Mali 400MP 2GB 10.4GB Li-Ion 3100 mAh
    Samsung Galaxy S4 Android 4.2 5" S-AMOLED 1920X1080 (441ppi) 13MP (HDR, DIS) Samsung 5410 1.6Ghz Octacore (Cortex A15 + Cortex A7) SGX 544MP3 2GB 16GB Li-Ion 2600 mAh
    Sony Xperia Z Android 4.1 5.0" 1920X1080 (441ppi) 13MP (HDR, DIS) Qualcomm APQ8064 1.5Ghz QuadCore (Krait) Adreno 320 2GB 16GB Li-Ion 2400 mAh
    Sony Xperia ZL Android 4.1 5.0" 1920X1080 (441ppi) 13MP (HDR, DIS) Qualcomm APQ8064 1.5Ghz QuadCore (Krait) Adreno 320 2GB 16GB Li-Ion 2370 mAh
    BlackBerry Z10 BlackBerry 10 OS 4.2" 768X1280 (355ppi) 8MP (HDR, DIS) Qualcomm MSM8960 1.5Ghz dualcore (Krait) Adreno 225 2GB 16GB
    HTC Windows Phone 8X Windows Phone 8 4.3" S-LCD2 720X1280 (342ppi) 8MP (1080p) Qualcomm MSM8960 1.5Ghz dualcore (Krait) Adreno 225 1GB 16GB (non-expandable)
    Nokia Lumia 920 Windows Phone 8 4.5" IPS LCD 768X1280 (332ppi) 8MP (Carl Zeiss, OIS) Qualcomm MSM8960 1.5Ghz dualcore (Krait) Adreno 225 1GB 32GB (non-expandable)
    OIS: optical image stabilization
    Carl Zeiss: camera Lens used in selected Nokias
  10. #10
    sam
    sam is offline
    Jan 2010
    Guwahati
    Android from Indian Manufacturers:
    UNDER 5K:
    Mobile Operating System Display Resolution Camera Processor GPU Ram Internal Memory 3G Connectivity
    Celkon A77 Android 2.3 3.5" 320X480 (165ppi) 2MP 1GHz -- 256MB 512MB NO
    Celkon A83 Android 2.3 3.2" 320X480 (180ppi) 2MP 1GHz -- 256MB 512MB NO
    Celkon A87 Android 2.3 4.0" 320X480 (144ppi) 5MP 1Ghz -- -- 512MB NO
    IBall Andi 3.5i Android 2.3 3.5" 320X480 (165ppi) 3.2MP (flash) MediaTek MT6575 1Ghz (Cortex A9) SGX 531 -- -- NO
    Intex Aqua Glow Android 2.3 4.0" IPS LCD 320X480 (144ppi) 3.2MP (flash) MediaTek MT6575 1Ghz (Cortex A9) SGX 531 256MB 82MB NO
    Intex Aqua Marvel Android 2.3 3.5" 320X480 (165ppi) 2MP MediaTek MT6515 1Ghz (Cortex A9) SGX 531 256MB 93MB NO
    Intex Aqua Star Android 2.3 4.0" 320X480 (144ppi) 3MP (flash) 1Ghz -- -- -- NO
    Intex Aqua Swadesh Android 2.3 3.2" 240X320 (125ppi) 3MP (flash) 1Ghz -- 256MB 76MB NO
    Intex Aqua SX Android 2.3 3.5" 320X480 (165ppi) 5MP (flash) 1Ghz 256MB 128MB NO
    Intex Aqua Trendy Android 2.3 3.5" 320X480 (165ppi) 3.2MP MediaTek MT6575 1Ghz (Cortex A9) SGX 531 256MB 78MB NO
    Karbonn A2+ Android 4.0 4.0" 480X800 (233ppi) 3MP 1GHz -- 256MB 202MB NO
    Karbonn A3 Android 2.3 3.5" 320X480 (165ppi) 3MP 1GHz -- 256MB 155MB NO
    Lava Iris 349 Android 2.3 3.5" 320X480 (165ppi) 2MP 1Ghz -- 256MB 113MB NO
    Micromax Bolt A27 Android 2.3 3.5" 320X480 (165ppi) VGA Spreadtrum SC6820 1Ghz (Cortex A5) Mali 400 256MB 160MB NO
    Micromax Bolt A35 Android 2.3 4.0" 480X800 (233ppi) 2MP (flash) Spreadtrum SP6820 1Ghz (Cortex A5) Mali 300 256MB 160MB NO
    Micromax Bolt A51 Android 2.3 3.5" 320X480 (165ppi) 2MP (flash) 832Mhz 256MB YES
    Micromax A54 Android 2.3 3.5" 320X480 (165ppi) 3MP Qualcomm MSM7227A 1Ghz (Cortex A5) Adreno 200 256MB 130MB YES
    Micromax A65 Android 2.3 4.3" 480X800 (217ppi) 2MP (flash) Spreadtrum SC6820 1Ghz (Cortex A5) Mali 400 512MB 190MB NO
    Spice Mi-315 Android 2.3 3.2" 320X480 (180ppi) 3MP (flash) 1Ghz -- -- 110MB NO
    Spice Mi-351 Android 2.3 3.5" 320X480 (165ppi) 3MP Qualcomm MSM7227A 1Ghz (Cortex A5) Adreno 200 256MB 100MB NO
    Spice Mi-352 Android 2.3 3.5" 320X480 (165ppi) 3MP Qualcomm MSM7227A 1Ghz (Cortex A5) Adreno 200 256MB 100MB YES
    Spice Mi-425 Android 2.3 4.0" 480X800 (233ppi) 3MP 1Ghz -- 256MB 100MB NO
    Videocon A15 Android 2.3 3.5" 320X480 (165ppi) 3.2MP (flash) 1Ghz -- 256MB 200MB NO
    Videocon A22 Android 2.3 3.5" 320X480 (165ppi) 3MP Qualcomm MSM7227A 1Ghz (Cortex A5) Adreno 200 256MB 200MB YES
    FROM 5-10K:
    Byond B65 Android 4.0 5.0" 480X800 (187ppi) 8MP (flash) 1.2Ghz dualcore -- 512MB 4GB YES
    Byond B66 Android 4.0 5.0" 480X854 (196ppi) 8MP (flash) 1.2Ghz dualcore -- 512MB 4GB YES
    Celkon A27 Android 4.0 4.6" 480X854 (213ppi) 8MP MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 4GB YES
    Celkon A67 Android 4.0 3.5" 320X480 (165ppi) 2MP MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 -- -- YES
    Celkon A98 Android 4.0 3.5" 480X800 (233ppi) 3.2MP (flash) 1Ghz 512MB 512MB YES
    Celkon A200 Android 4.0 4.3" 480X800 (217ppi) 8MP (flash) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 2.4GB YES
    Celkon A220 Android 4.0 4.6" 480X854 (213ppi) 5MP MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 4GB YES
    Celkon A225 Android 4.1 4.7" IPS LCD 480X854 (208ppi) 8MP MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 4GB YES
    iBall Andi 4.5Q Android 4.1 4.5" 540X960 (245ppi) 8MP (flash) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 2.5GB YES
    Intex Aqua 5.0 Android 4.0 5.0" 480X800 (187ppi) 5MP (flash) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 2GB YES
    Intex Aqua Flash Android 4.0 4.3" 480X800 (217ppi) 8MP (flash) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 1.56GB YES
    Karbonn A4+ Android 4.0 4.0" IPS LCD 480X800 (233ppi) 3.2MP 1GHz dualcore -- 512MB 139MB NO
    Karbonn A6 Android 4.0 4.0" IPS LCD 480X800 (233ppi) 5MP (flash) Qualcomm MSM7227A 1Ghz (Cortex A5) Adreno 200 512MB 104MB NO
    Karbonn A7 Star Android 4.0 4.5" 480X854 (218ppi) 5MP (flash) Qualcomm MSM8225 1Ghz dualcore (Cortex A5) Adreno 203 512MB 164MB YES
    Karbonn A27 Android 4.1 4.3" IPS LCD 540X960 (256ppi) 8MP (flash) Qualcomm MSM8225 1.2Ghz dualcore (Cortex A5) Adreno 203 512MB 2.8GB YES
    Karbonn A30 Android 4.0 5.9" 480X800 (158ppi) 8MP (flash) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 2.6GB YES
    Karbonn A111 Android 4.0 5.0" 480X800 (187ppi) 5MP (flash) Qualcomm MSM8225 1.2Ghz dualcore (Cortex A5) Adreno 200 512MB 4GB YES
    Karbonn S1 Android 4.1 4.5" 540X960 (245ppi) 5MP (flash) Qualcomm MSM8225Q 1.2Ghz quadcore (Cortex A5) Adreno 203 1GB 4GB YES
    Lava Iris 405 Android 4.1 4.0" 480X800 (233ppi) 8MP (flash, 720p) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 2GB YES
    Lava Iris 454 Android 4.0 4.5" IPS LCD 540X960 (245ppi) 8MP (flash, 720p) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 2GB YES
    Lava Iris 455 Android 4.1 4.5" 540X960 (245ppi) 5MP (flash, 720p) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 2GB YES
    Lava Iris 458q Android 4.2 4.5" 480X854 (218ppi) 8MP (flash, 720p) MediaTek MT6589 1.2Ghz quadcore (Cortex A7) SGX 544 512MB 2GB YES
    Lava Iris 501 Android 4.1 5.0" 480X800 (187ppi) 5MP (flash) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 4GB YES
    Lava Iris 502 Android 4.1 5.0" 480X800 (187ppi) 5MP (flash) MediaTek MT6575 1Ghz (Cortex A9) SGX 531 512MB 2GB YES
    Lava XOLO X500 Android 4.0 3.5" IPS LCD 320X480 (165ppi) 5MP Intel Z2420 1.2Ghz (Saltwell) SGX 540 512MB 4GB YES
    Lava XOLO X910 Android 4.0 4.3" IPS LCD 540X960 (256ppi) 5MP (flash) Intel Z2480 1.6Ghz (saltwell) SGX 540 1GB 4GB YES
    Lava XOLO A700 Android 4.0 4.5" IPS LCD 540X960 (245ppi) 5MP (flash) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 4GB YES
    Lava XOLO A800 Android 4.2 5.0" IPS LCD 540X960 (220ppi) 5MP (flash) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 4GB YES
    Lava XOLO B700 Android 4.0 4.3" IPS LCD 540X960 (256ppi) 5MP (flash) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 4GB YES
    Lava XOLO Q700 Android 4.2 4.5" IPS LCD 540X960 (245ppi) 5MP (flash, 720p) MediaTek MT6589 1.2Ghz quadcore (Cortex A7) SGX 544 1GB 4GB YES
    Micromax Canvas Viva A72 Android 2.3 5.0" 480X800 (187ppi) 3MP Mediatek MT6515 1Ghz (Cortex A9) SGX 531 256MB 110MB NO
    Micromax Ninja A89 Android 4.0 4.0" 480X800 (233ppi) 3MP MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 2.5GB YES
    Micromax Ninja A91 Android 4.0 4.5" 480X854 (218ppi) 5MP MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 4GB YES
    Micromax Canvas 2 Android 4.1 5.0" IPS LCD 480X854 (196ppi) 8MP (flash) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 2.5GB YES
    Micromax Canvas 3D Android 4.1 5.0" 3D LCD 480X800 (187ppi) 8MP (flash, 480p) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 2.5GB YES
    Micromax A88 Canvas Music Android 4.1 4.5" 480X854 (196ppi) 5MP (flash, 720p) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 2.4GB YES
    Spice Smart Flo Pace Android 4.0 4.0" 480X800 (233ppi) 3.2MP (flash) 1Ghz 512MB 512MB NO
    Spice Stellar Nhance Android 4.0 4.0" 480X854 (233ppi) 8MP (flash) Qualcomm MSM8225 1Ghz dualcore (Cortex A5) Adreno 203 512MB 2.5GB YES
    Spice Stellar Virtuoso Android 4.0 4.5" IPS LCD 540X960 (245ppi) 8MP (flash) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 2.5GB YES
    Spice Stellar Horizon Pro Android 4.0 5.0" 480X800 (187ppi) 5MP (flash) 1Ghz dualcore SGX 531 512MB 4GB YES
    Spice Smart Flo Ivory Android 4.0 5.0" 480X800 (187ppi) 5MP (flash) 1Ghz dualcore SGX 531 512MB 4GB NO
    Spice Smart Flo Pace 2 Android 4.0 4.5" 480X854 (196ppi) 3.2MP (flash) 1Ghz dualcore 512MB 512MB NO
    Swipe 9X Android 4.0 4.7" 480X854 (208ppi) 8MP MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX531 512MB 4GB YES
    Swipe Fablet F3 Android 4.1 5.0" 480X800 (187ppi) 5MP MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX531 512MB 4GB YES
    Videocon A27i Android 4.0 4.0" 480X800 (233ppi) 5MP (flash) 1Ghz -- 512MB 4GB YES
    Videocon A30 Android 4.0 4.0" 480X800 (233ppi) 5MP Qualcomm MSM8225 1Ghz dualcore (Cortex A5) Adreno 203 512MB 4GB YES
    Videocon A45 Android 2.3 5.0" 480X800 (187ppi) 3.2MP (flash) 1Ghz 256MB 512MB NO
    Videocon A51 Android 4.0 5.0" 480X854 (196ppi) 5MP (flash) Qualcomm MSM8225 1Ghz dualcore (Cortex A5) Adreno 203 512MB 4GB YES
    Zync Cloud Z5 Android 4.0 5.0" 480X800 (187ppi) 8MP 1Ghz -- 512MB 4GB YES
  11. #11
    sam
    sam is offline
    Jan 2010
    Guwahati
    FROM 10-15K:
    Byond Phablet PII Android 4.1 5.7" IPS LCD 720X1280 (258ppi) 8MP (flash) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 1GB 4GB 2500 mAh
    Celkon Signature HD A119 Android 4.1 5" IPS LCD 720X1280 (294ppi) 12MP (flash, 1080p) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 1GB 1.45GB 2100 mAh
    iBall Andi 4.5h Android 4.0 4.5" IPS LCD 540X960 (245ppi) 8MP (flash) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 1GB 2.5GB 1600 mAh
    iBall Andi 5L Android 4.0 5.0" 480X800 (187ppi) 8MP (flash) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 4GB 1800 mAh
    Karbonn S2 Android 4.1 5.0" 480X854 (196ppi) 8MP (flash) Qualcomm MSM8225Q 1.2Ghz quadcore (Cortex A5) Adreno 203 1GB 1.79GB 2100 mAh
    Karbonn S5 Android 4.1 5.0" 540X960 (220ppi) 8MP (flash) Qualcomm MSM8225Q 1.2Ghz quadcore (Cortex A5) Adreno 203 1GB 8GB 2000 mAh
    Lava XOLO Q800 Android 4.1 4.5" IPS LCD 540X960 (245ppi) 8MP (flash, 1080p) MediaTek MT6589 1.2Ghz quadcore (Cortex A7) SGX 544 1GB 4GB 2100 mAh
    Lava XOLO Q1000 Android 4.2 5.0" IPS LCD 720X1280 (294ppi) 8MP (flash) MediaTek MT6589 1.2Ghz quadcore (Cortex A7) SGX 544 1GB 4GB 2100 mAh
    Micromax Canvas Doodle Android 4.1 5.3" 480X800 (185ppi) 8MP (flash, 480p) Qualcomm MSM8225Q 1.2Ghz quadcore (Cortex A5) Adreno 203 512MB 1.2GB 2100 mAh
    Micromax Canvas 2 Plus Android 4.2 5.0" 480X854 (196ppi) 8MP (flash) MediaTek MT6589 1.2Ghz quadcore (Cortex A7) SGX 544 1GB 4GB 2000 mAh
    Micromax Canvas HD Android 4.1 5" IPS LCD 720X1280 (294ppi) 8MP (flash, 1080p) MediaTek MT6589 1.2Ghz quadcore (Cortex A7) SGX 544 1GB 1.77GB 2000 mAh
    Swipe MTV Volt Android 4.1 6.0" 480X854 (163ppi) 8MP (flash) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 512MB 4GB 3200mah
    ABOVE 15K:
    Lava XOLO X1000 Android 4.0 4.7" 720X1280 (312ppi) 8MP (flash, 1080p) Intel Z2480 2Ghz (saltwell) SGX 540 1GB 8GB 1900 mAh
    Spice Mi-530 Android 4.0 5.3" IPS LCD 540X960 (208ppi) 8MP (flash) MediaTek MT6577 1Ghz dualcore (Cortex A9) SGX 531 1GB 16GB 2550 mAh
  12. #12
    sam
    sam is offline
    Jan 2010
    Guwahati
    SOC REFERENCE:
    Chipset Processing Core NO of Cores GPU Instruction Set Manufacturing Node
    Broadcom BCM21654G Cortex A5 1 Videocore 4 ARM v7 40nm
    Broadcom BCM21654 Cortex A9 1 Videocore 4 ARM v7 40nm
    Broadcom BCM28155 ARM Cortex A9 2 Videocore 4 (2 cores) ARM v7 40nm
    Intel Z2420 Intel Saltwell 1 core, 2 threads SGX 540 Intel-AMD X86 32nm
    Intel Z2480 Intel Saltwell 1 core, 2 threads SGX 540 Intel-AMD X86 32nm
    MediaTek MT6575/6515 ARM Cortex A9 1 SGX 531 ARM v7 65nm
    MediaTek MT6577 ARM Cortex A9 2 SGX 531 ARM v7 65nm
    MediaTek MT6577T ARM Cortex A9 2 SGX 531 ARM v7 65nm
    MediaTek MT6589 ARM Cortex A7 4 SGX 544 ARM v7 28nm
    Nvidia Tegra 3 AP30H ARM Cortex A9 4+1 ULP GeForce ARM v7 40nm
    Nvidia Tegra 3 AP33H ARM Cortex A9 ULP GeForce 4+1 ARM v7 40nm
    Nvidia Tegra 3+ AP37 ARM Cortex A9 4+1 ULP GeForce ARM v7 40nm
    Qualcomm MSM7225A ARM Cortex A5 Adreno 200 1 ARM v7 45nm
    Qualcomm MSM7227A ARM Cortex A5 1 Adreno 200 ARM v7 45nm
    Qualcomm MSM8225 ARM Cortex A5 2 Adreno 203 ARM v7 45nm
    Qualcomm MSM8225Q ARM Cortex A5 4 Adreno 203 ARM v7 45nm
    Qualcomm MSM8260 Qualcomm Scorpion 2 Adreno 220 ARM v7 45nm
    Qualcomm MSM8960 Qualcomm Krait 2 Adreno 225 ARM v7 28nm
    Qualcomm MSM8960 Pro Qualcomm Krait 2 Adreno 320 ARM v7 28nm
    Qualcomm APQ8064 Qualcomm Krait 4 Adreno 320 ARM v7 28nm
    Samsung 4412 ARM Cortex A9 4 Mali 400MP (4 core) ARM v7 32nm
    Samsung 5410 ARM Cortex A15 + A7 4+4 SGX 544MP3 (3core) ARM v7 28nm
    Spreadtrum SC6820 ARM Cortex A5 1 Mali 400 ARM v7 --
    Spreadtrum SP6820 ARM Cortex A5 1 Mali 300 ARM v7 --
    ST-Ericsson U8500 ARM Cortex A9 2 Mali 400 ARM v7 45nm
    TI 4430 ARM Cortex A9 2 SGX 540 ARM v7 45nm
    SOC performance:
    Position Chipset
    1 Samsung Exynos 5410 (octacore)
    2 Qualcomm Snapdragon APQ8064 (quadcore)
    3 Qualcomm Snapdragon MSM8960/Pro (dualcore)
    4 Nvidia Tegra 3+ AP37 (quadcore)
    5 Intel Atom Z2480
    6 Samsung Exynos 4412 (quadcore)
    7 Nvidia Tegra 3 AP30H/33H (quadcore)
    8 MediaTek MT6589 (quadcore)
    9 Texas Instruments OMAP 4430 (dualcore)
    10 Broadcom BCM28155 (dualcore)
    11 ST-Ericsson Novathor U8500 (dualcore)
    12 Intel Z2420
    13 MediaTek MT6577/T (dualcore)
    14 Qualcomm Snapdragon MSM8260 (dualcore)
    15 Qualcomm Snapdragon MSM8225Q (quadcore)
    16 MediaTek MT6575/6515
    17 Broadcom BCM21654
    18 Qualcomm Snapdragon MSM8225 (dualcore)
    19 Qualcomm Snapdragon MSM7227A
    20 Qualcomm Snapdragon MSM7225A
    21 Broadcom BCM21654G
    22 Spreadtrum SC6820/SP6820
    GPU performance:
    Position GPU
    1 SGX 544MP3 (3core)
    2 Adreno 320
    3 Mali 400MP (4core)
    4 ULP GeForce
    5 Adreno 225
    6 SGX 540
    7 Adreno 220
    8 Videocore 4 (2core)
    9 Mali 400
    10 Videocore 4
    11 SGX 531
    12 Adreno 203
    13 Adreno 200
    14 Mali 300
  13. #13
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    Default Re: Mobile Reference Guide: January 2012
    Awesome Job Sam. This is awesome
    Follow me on Twitter: http://twitter.com/wuodland
  14. #14
    Super Moderator Skud's Avatar
    Jun 2004
    10 light years away
    Nice compilation, Sam. Looks like the TDF is going to see some changes in coming months.
    Gaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
    HTPC Rig: C2D E7400 | EP45-DS3R | 2x2GB DDR2 800 | MS Wireless Desktop 2000 | Gigabyte 5770 | Samsung 32" | Seasonic SII 520W | Silverstone LC10
    Audio Gear: Altec Lansing VS2421 | ASUS Vulcan ANC | HiFiMan RE-0
    Storage: 2x250GB | 3x500GB | 3x1TB | 3x2TB
    Android: Galaxy R | Galaxy Y
  15. #15
    Arsenal Fan arsenalfan001's Avatar
    Mar 2009
    Kolkata
    Nice guide Sam.
    Laptop: HP DV6 - 6140tx | i7-2630 | 8GB DDR3 | 500GB 5400rpm | 1GB DDR5 ATI 6770 | Cooler Master Ergostand
    Desktop: i5-3570K | CM Hyper 212 Evo | P8Z77M-Pro | Sapphire HD 7970 Vapor-x | G-skill Ripjaws 8GB | WDC 500GB | Corsair GS 600 | Corsair Carbide 400R | Microsoft Sidewinder X4 | Logitech G400 | CPUZ | GPUZ | Looking to sell my Note 2
  16. #16
    Gadget Freak Tenida's Avatar
    Aug 2008
    Calcutta
    Wonderful work buddy.Keep it up
    My Gizmos O_O
    ||Core i7 2600K | MSI Z68A GD80 | MSI GTX560Ti ||
    ||F&D A555U | Roccat Kave | Funbook | LG Optimus L9 (W) ||
  17. #17
    making future better Vyom's Avatar
    May 2009
    New Delhi
    You saved me the trouble to make a thread for the best Android around Rs. 14k.
    I have a shortlist now!
    An effort like this can't be awarded with a "thank".
    But thanks anyway...!! Thanks for this new year gift...
  18. #18
    sam
    sam is offline
    Jan 2010
    Guwahati
    thanks everyone. will update it whenever necessary but the last part (25K & higher priced mobile) will take a week. college starts from tomorrow & hence less free time.
    Quote Originally Posted by vineet369 View Post
    but you already own one. New mobile for whom?
  19. #19
    New Gen Guru sujoyp's Avatar
    Mar 2008
    Orangecity
    Nice compilation SAM good work
    just found 2 corrections under 15-20k section
    1. Defy+ screen resolution is 480X854 and not 480x584 as written there.
    2. u have named both sections as android smartphone, one should be non-android
    Photography Gears -
    Nikon D3100+18-55+55-200+50mm+55mmMicro,Tamron 17-50mmf2.8 Lowepro pro Runner 200 AW
    Yougnou YN-465 flash , Vanguard ESPOD 203AP, YN603-N3 flash trigger
    My flicker link -> http://www.flickr.com/photos/34748095@N07/
    Samsung Omnia W with Sony MDR-ED12,Micromax Funbook & Samsung 550P-S05
  20. #20
    Rusted... dashing.sujay's Avatar
    Nov 2009
    Bhopal
    Great work Sam. Some points-
    1) In 15-20K section, you've written Non-Andriod section as "Andriod"
    2) What about adding a column for internal memory, especially in sub 20k section as they do matter.
    3) In second line from top- spelling of PRICELIST.
    4) One more suggestion of picking 1 or 2 better phones as suggestions in each section. You can take members help who own them.
    5) A section of info about mobile processors, chipsets, and graphics would help users a lot.!
    FAQ + answers for new members (Read before asking / messaging any moderator for any query)
    Drop Box: Get 500MB free
    Quote Originally Posted by axes2t2 View Post
    Before working on a master piece you have to first master the pieces.
    Sony Vaio CB35 Asus U32U ATH M20 Fiio E6
    Sony Vaio CB35 UnBoxing & Review
    How fast can you type?
  21. #21
    May 2009
    New Delhi
    Quote Originally Posted by Sam View Post
    That one is for a friend/colleague, who maybe secretly hate his Symbian whenever he see my Android!!
    (no offence to Symbian users...)
    It's sad that you won't be able to post regular here, specially since I have just started to get my hands dirty with rooting and all...
    Already read completely your "O1 Review" thread and reached Page 7 of "The Optimus One Thread"...
  22. #22
    Simply a DIGITian krishnandu.sarkar's Avatar
    Nov 2007
    Kolkata
    Awesome sam
    Repped.
    • Read The Forum RULES First.
    • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
    • Before Starting A New Thread Read The STICKY THREADS First
    • Before Participating In Bazaar Section Read The BAZAAR RULES
  23. #23
    sam
    sam is offline
    Jan 2010
    Guwahati
    Quote Originally Posted by sujoyp View Post
    thanks for pointing the errors. corrected
    Quote Originally Posted by dashing.sujay View Post
    1. corrected.
    2. its there for Android mobiles in sub 20k. for the non-Android mobiles, this doesn't really matter i think. i'll check into this.
    3. thanks. was a typo.
    4. initially i too thought same. but some may ask why i gave preference to one & ignore the other. so i gave a note at the end of each section which describes in simple language what you need to look at when buying a mobile within that budget.
    5. yes. that is a nice idea. will surely do some research & add it in coming days. thanks for the tip
    this is specially true for the old Symbian S60s. those can't be compared to Androids at all. even the dumb OS, BADA (no offence to Samsung Wave owners but BADA 1.* is crap) outmatch & outclasses them in looks & usability. Symbian Anna & then Belle has reduced the gap but still lot has to be done.
    i will post regularly (but lately). rooting & installing custom rom is fun & easy. just read the important guidelines given in their respective thread. try something random & you may make the mobile unresponsive or at most need to reinstall the rom again.
    Quote Originally Posted by krishnandu.sarkar View Post
    Awesome sam
    Repped.
    thanks
  24. #24
    Will Power TheLetterD's Avatar
    Aug 2008
    Hey, I know this is asking a lot from you but cant we get the Quadrant scores of the Android Phones with Stock and Custom ROM from some website ?
    Mark my words, Soon after the Zombie Apocalypse, The Apes WILL take over!
    Follow me @ http://twitter.com/ThaLetterD
    Processor/APU: AMD A10 5800K | Mobo: ASUS F2A85 MLE | Corsair Vengeance 8GB DDR3 RAM |
    1 TB WD Blue HDD | Bitfenix Merc Alpha | Corsair CX430 PSU
    iPhone 3GS | Xbox 360 Wired Controller | Altec Lansing 5.1 VS3251 |
  25. #25
    sam
    sam is offline
    Jan 2010
    Guwahati
    not possible. every mobile have many roms. some have rom in hundreds. then add overclock & you are looking at around 100 different configurations per mobile. also quadrant will always be high for custom rom even for slower mobiles. have seen Galaxy5 score around 1.5k in quadrant. outmatching almost all highend mobiles with stock rom.
  26. #26
    Nov 2009
    Bhopal
    ^What is quadrant?
  27. #27
    May 2009
    New Delhi
    ^ A simple Google search could have saved you a lot of embarrassment!
    But if you got genuinely failed in search attempts, here is the app, which is in question here...
    https://market.android.com/details?i...standard&hl=en
    It's a benchmarking app, which gauges the capabilities of your android phone, with respect to other phones.
  28. #28
    Nov 2009
    Bhopal
    ^Well I don't feel embarassed to ask anything upto some limit. And firstly I was too lazy to search Also I guesses it to be something like that (it was clear from above convo), but just wanted to be sure.
  29. #29
    May 2009
    New Delhi
    No hard feeling dude.. just felt like a little trolling.. thats all...
    Btw, @Sam: I am finding Motorola Defy to be a good phone for my friend, as long as he doesn't have that "brand" mania. (He says he don't like "Motorola" and that he have used "Motorola Phones", don't know how to remove the mania from him).
    Just wanted to confirm one thing. Does Motorola Defy really have 1.3 Gb as internal memory? Cause, GSMArena says it has 2 GB!
  30. #30
    sam
    sam is offline
    Jan 2010
    Guwahati
    Quote Originally Posted by Vyom View Post
    next option he'll consider is Galaxy Ace. show him the chart of 10-15k mobile. specially ram. moreover Defy have 2 times the resolution of Ace. if not Defy, Xperia Mini Pro can be brought from letsbuy for just 13.2k after applying coupon code.
    2Gb rom. 1.3Gb free for apps
  1. 13-05-2013, 04:42 PM
  2. 07-05-2013, 09:29 AM
  3. 04-05-2013, 02:04 AM
  4. 03-05-2013, 12:25 AM
  5. 02-05-2013, 11:16 AM
  6. 01-05-2013, 08:56 AM
  7. 30-04-2013, 09:46 PM
  8. 30-04-2013, 06:52 PM
  9. 30-04-2013, 09:23 AM
  10. 30-04-2013, 07:27 AM
  11. 28-04-2013, 11:54 PM
  12. 28-04-2013, 10:52 PM
  13. 28-04-2013, 12:01 PM
  14. 27-04-2013, 08:43 PM
  15. 27-04-2013, 12:07 AM
  16. 25-04-2013, 07:27 PM
  17. 14-03-2013, 09:47 PM
  18. 14-03-2013, 02:17 PM
  19. 19-01-2013, 07:39 PM
  20. 19-01-2013, 10:45 AM
  21. 19-01-2013, 10:37 AM
  22. 19-01-2013, 09:17 AM
  23. 21-12-2012, 11:14 AM
  24. 12-11-2012, 02:15 PM
  25. 12-11-2012, 01:24 PM
  26. 12-11-2012, 12:43 PM
  27. 12-11-2012, 12:42 PM
  28. 12-11-2012, 12:39 PM
  29. 21-10-2012, 09:24 AM
  30. 27-08-2012, 12:52 AM
  31. 01-08-2012, 12:48 PM
  32. 31-07-2012, 08:47 AM
  33. 31-07-2012, 08:07 AM
  34. 05-07-2012, 09:11 PM
  35. 05-06-2012, 10:12 AM
  1. PC Buying Guide 2012 - Q4
    By Jaskanwar Singh in forum PC Components / Configurations
    Last Post: Yesterday, 09:54 AM
  2. Preview and Feedback [August 2012]
    By r4gs in forum Feedback
    Last Post: 26-08-2012, 04:22 PM
  3. By Demand [August 2012]
    By r4gs in forum By Demand
    Last Post: 30-07-2012, 05:34 PM
  4. mobile buying guide
    By iinfi in forum Buying Advice
    Last Post: 07-05-2009, 09:59 PM
