Page 6 of 31 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 26 ... LastLast
Results 151 to 180 of 906
  1. #151
    sam
    sam is offline
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    Default re: Mobile Buying Guide: September 2012
    rule no.1
    Any mobile that is rebranded and sold through a local brand is excluded even if the same is manufactured by International company.
    if i include karbon and spice i'll have to include micromax, lava, iball, etc. So simply excluding any and all local brands.
  2. #152
    C.T.I.D AlphaQ's Avatar
    Jun 2011
    221B,Baker Street.
    correction sam...
    samsung wave y resolution is 240x400(odd)
    sorry sam..my wrong..wave does hv 320x480 res.
    - Tapatalked from my Samsung Galaxy Y GT-S5630.
  3. #153
    sam
    sam is offline
    Jan 2010
    Guwahati
    VB update caused tables to be disabled. guides won't be available till i fix them.
  4. #154
    Alpha Geek choudang's Avatar
    Sep 2005
    Guwahati
    xperia updated to ICS 4.0.
    -- For every action, there is an equal and opposite criticism.
    Nikon D3100, 18-55mm, 35mm, Simpex 333
    Flicker: debaxish
    Blackberry 9100, Xperia Ray
  5. #155
    Apprentice Richie Rich's Avatar
    Apr 2012
    New Delhi
    Is there any news of upcoming phones in the budget of under 25k.
    Intel Core2Duo E8400 3.0Ghz - 4GB DDR3 RAM - Radeon HD 5770 1GB - 1TB 7200rpm Seagate - 320GB Seagate Portable
  6. #156
    sam
    sam is offline
    Jan 2010
    Guwahati
    price cut on Xperia S & One S. Also there is LG Optimus L9 but highly underpowered hardware. no idea of additional launches from Samsung, Sony or HTC.
  7. #157
    Apr 2012
    New Delhi
    when we can expect price cut of One S and Xperia S.
  8. #158
    sam
    sam is offline
    Jan 2010
    Guwahati
    One S already received a massive 5k pricecut and now both cost 27-28k. Xperia S may get a further pricecut if Ion's price come close to 32k. Current selling for 36k or so.
  9. #159
    Rusted... dashing.sujay's Avatar
    Nov 2009
    Bhopal
    Isn't adreno 220 (xperia S) a sucker?
    FAQ + answers for new members (Read before asking / messaging any moderator for any query)
    Drop Box: Get 500MB free
    Quote Originally Posted by axes2t2 View Post
    Before working on a master piece you have to first master the pieces.
    Sony Vaio CB35 Asus U32U ATH M20 Fiio E6
    Sony Vaio CB35 UnBoxing & Review
    How fast can you type?
  10. #160
    sam
    sam is offline
    Jan 2010
    Guwahati
    Quote Originally Posted by dashing.sujay View Post
    Mali 400MP is better than 220. But 220 is not that bad. But problem starts when you mix high resolution display and a mediocre GPU.
  11. #161
    Sony Loverboy randomuser111's Avatar
    Jul 2011
    I'd like to disagree there. Xperia S Adreno 220 is very capable and the proof of that can be seen in benchmarks. It scores as much or more in most graphic benchmarks, especially when you consider its running at 1280x720 resolution.
    Nenamark 2, GL Benchmark 2.5 HD, RD 3D benchmark all prove this fact. Both are about the same.
    Let's compare GL Benchmark 2.5 HD scores of Galaxy S2 Mali 400 vs Xperia S Adreno 220. The figures for Galaxy S2 taken from Anandtech and I ran these tests on my XS on stock ROM with no CPU/GPU overclock. But since its GPU based mostly, even if I overclock I can't get any better scores than when its stock. Only GPU OC can help.
    GL Benchmark 2.5 Fill Test Mtexels/sec
    Galaxy S2 - 395
    Xperia S - 124
    GL Benchmark 2.5 Fill Text Off Screen 1080p
    Galaxy S2 - 312.1
    Xperia S - 131
    GL Benchmark 2.5 Triangle Texture Test Mtriangles/sec
    Galaxy S2 - 9.28
    Xperia S - 26.98
    GL Benchmark 2.5 Triangle Texture Test OffScreen 1080p
    Galaxy S2 - 5.92
    Xperia S - 23.77
    GL Benchmark 2.5 Triangle Texture Text Fragment Lit Mtriangles/sec
    Galaxy S2 - 8.73
    Xperia S - 22.19
    Gl Benchmark 2.5 Triangle Texture Test Fragment Lit Offscreen 1080p
    Galaxy S2 - 5.5
    Xperia S - 21.83
    GL Benchmark 2.5 Triangle Texture Test Vertex Lit MTriangles/sec
    Galaxy S2 - 8.65
    Xperia S - 21.89
    GL Benchmark 2.5 Triangle Texture Test Vertex Lit Off Screen 1080p
    Galaxy S2 - 5.68
    Xperia S - 21.16
    GL Benchmark 2.5 Egypt HD Frames/sec
    Galaxy S2 - 9.1
    Xperia S - 13
    GL Benchmark 2.5 Egypt HD Offscreen 1080p
    Galaxy S2 - 8.8
    Xperia S - 8.3
    GL Benchmark 2.5 Egypt Classic
    Galaxy S2 - 60
    Xperia S - 39
    GL Benchmark 2.5 Egypt Classic Offscreen 1080p
    Galaxy S2 - 31
    Xperia S - 20
    So, you still think Adreno 220 is quite a bit weaker than Mali400 ?
    Other benchmark scores -
    Nenamark 2 - 39.8fps
    RD 3D benchmark - 48 fps
    SONY make.believe :D | BRAVIA | VAIO | XPERIA | CYBERSHOT | WALKMAN | ALPHA | PLAYSTATION | HANDYCAM | XPLOD
  12. #162
    sam
    sam is offline
    Jan 2010
    Guwahati
    mali 400 had some problem and was pointed by many reviews. Adreno and PowerVR are available since along time so all benchmarks works just fine. I think it was anandtech that said Mali 400 is capable but cause of poor support (from either Google or benchmark programmers, not sure) the score was lower than it should be.
  13. #163
    Jul 2011
    Well that's what the point is, in real world and even in benchmarks the Mali400 doesn't have much over Adreno 220. No doubt it has a lot of potential but its pointless that the potential will never be harnessed. The same was the story with Samsung hummingbird chipset (potentially the fastest and most powerful single core chipset) but it never really could perform as good as it could have. Same goes for Exynos Dual and Exynos Quad this year.
    Exynos Quad is also on paper a superior Quad Core chipset than Tegra 3 is, but its getting beaten by One X with Tegra 3 even though on paper Tegra 3 is less powerful.
    So calling Adreno 220 quite a bit weaker doesn't really make any sense as its as fast in real world than the Mali 400.
  14. #164
    In The Zone daksh's Avatar
    Nov 2011
    Moreover galaxy s2 scores from anandtech are old and they improved drastically after ics update. Exynos is way superior than S3.
    Samsung Series 5 NP550P|HTC One X(AOKP 4.2.2)|iPad Mini 16gb|Klipsch Image S4i|Klipsch Image x10|Xbox 360|Logitech g400
  15. #165
    Jul 2011
    Proof for "way superior" ? You know what let's not even get the Xperia S into the picture. Just compare the Galaxy S2 skyrocket and the Galaxy S2 International. The former has Adreno 220 and the later Mali 400. Compare benchmark scores of both and find out for yourself if Mali 400 is much better or not.
    And btw who told you that the above scores are "old" ? GL Benchmark 2.5 only came out last month and this test was also done last month. Check the article date on Anandtech.
  16. #166
    Apr 2012
    New Delhi
    As far as i know Galaxy S2 I9100 with all latest updates is much better than Xperia S in terms of performance. Though screen resolution difference is there.
    can anybody can tell me what is the current quadrant and antutu score of both the devices with all updates?
    Quote Originally Posted by daksh View Post
    Yes, from last year htc sensation lost its market due to some issues and s3 processor performance.
  17. #167
    Jul 2011
    Buddy, don't blame Qualcomm for HTC's own incompetence in optimizing the S3 chipset. Sony and Samsung could extract Exynos level performance from the S3 chipset but HTC couldn't. And it's not fair that you claim the S3 chipset is weak only because of HTC having not optimized it at all. The Exynos maybe far better than the S3 in Sensation and Sensation XE but it's not way better than the S3 in Xperia S/Galaxy S2 skyrocket. GSMArena shootout between GS2 and Xperia S proved that already.
    Anyway I do not know about GS2 but Xperia S Quadrant Score is now ~ 3600 and Antutu ~ 6750
  18. #168
    May 2012
    damn man awesome thread
  19. #169
    Human Spambot pratyush997's Avatar
    Mar 2012
    Is not your concern
    @you made best Guide ever..
    Pantech Burst, Sammy S02IN
    [GUIDE]AndroVM
  20. #170
    Mar 2012
    Is not your concern
    Default Re: Mobile Buying Guide: September 2012
    Hi folks.. How is this one ?
    Xperia s for 22k
    SONY XPERIA S LT26i WITH 1 YEAR WARRANTY | eBay
    [GUIDE]AndroVM
  21. #171
    sam
    sam is offline
    Jan 2010
    Guwahati
    For 4k more you get manufacturers warranty. Your money, Your call.
    BTW, A BIG UPDATE:
    check post #10 first page. A lot of info are missing and things maybe out of place so please help me fix the errors or missing info.
  22. #172
    Genius in making mistakes bhushan2k's Avatar
    Dec 2006
    Mumbai, India
    Quote Originally Posted by Sam View Post
    BTW, A BIG UPDATE:
    you will definitely not get chipset, processor n gpu used in those Indian phones from any site.. i too was looking for the same once...still will let u know if i find it..
    Sony Xperia P Review - my first droid | Nokia Lumia 620 Review
    Facebook | Google+ | Twitter
    Intel Core i5 2400 | Asus P8H61-M Plus 2 | Corsair 4GB XMS3 1600 (2X2GB kit) | FSP Saga II 500w | NZXT Gamma | Seagate 500 GB Sata | Asus 24x DVD RW Sata
  23. #173
    sam
    sam is offline
    Jan 2010
    Guwahati
    most of the info is available if you spend enough time digging. reviews, XDA (all are rebranded chinese mobiles), benchmark sites (that list the GPU ---> i.e. partly the chipset), etc. but not the cheaper ones.
  24. #174
    Jul 2012
    Guwahati
    @Sam
    1st of all thanx for the very nice post n need a Help
    i have decided to go for a mobile bt m very confused
    my spec are
    1ghz processor
    512mb ram min
    ICS os
    andreno205 or more
    internal space 4gb min
    2000mah battery
    3.5 inch min screen (gorrila glass display if )
    5mp back with led and front also
    at last budget 15k max
    if it is a Dual sim then it would be Best plz do a research 4 mine ha
    nd plz i dont know any details like which processor is good bad, gpu, ram etc plz suggest a gwd one
    nd if can can u mention the best VFM under 5-10, 10-15 plz
    thanx
  25. #175
    making future better Vyom's Avatar
    May 2009
    New Delhi
    Quote Originally Posted by aAdirulz View Post
    Oh come on...
    There are best buys given in this thread. You can search on flipkart using numerous filters. You can come to at least a small comprehensive list of your own!
    Do some research lad. This is not a spoon feeding thread!!
  26. #176
    Jul 2012
    Guwahati
    Quote Originally Posted by Vyom View Post
    Oh come on...
    i have done that bt not flipkart at phonecuury n Se live with walkman is gwd bt small screen
  27. #177
    Feb 2012
    Delhi
    It is written "enchanced" in a5 . Please correct it
    Same error in GPU performance chart
  28. #178
    sam
    sam is offline
    Jan 2010
    Guwahati
    lol thats an odd typo. thanks for pointing
  29. #179
    Feb 2012
    Delhi
    Also where is a100 ?
    It is a great phone for 10k
    Also is this correct in a9 ?
    MSM7627A
    It is not mentioned anywhere else . Shouldn't it be msm7227a.
  30. #180
    sam
    sam is offline
    Jan 2010
    Guwahati
    A100 is discontinued by micromax. online or offline, everywhere it is out of stock. most likely a dual core version of A100 will appear.
    7627A = MSM7227A + CDMA or some baseband. performance wise it is same.
  1. Yesterday, 09:00 AM
  2. 15-06-2013, 12:35 PM
  3. 12-06-2013, 10:50 PM
  4. 24-05-2013, 06:11 PM
  5. 13-05-2013, 04:42 PM
  6. 07-05-2013, 09:29 AM
  7. 04-05-2013, 02:04 AM
  8. 03-05-2013, 12:25 AM
  9. 02-05-2013, 11:16 AM
  10. 01-05-2013, 08:56 AM
  11. 30-04-2013, 09:46 PM
  12. 30-04-2013, 06:52 PM
  13. 30-04-2013, 09:23 AM
  14. 30-04-2013, 07:27 AM
  15. 28-04-2013, 11:54 PM
  16. 28-04-2013, 10:52 PM
  17. 28-04-2013, 12:01 PM
  18. 27-04-2013, 08:43 PM
  19. 27-04-2013, 12:07 AM
  20. 25-04-2013, 07:27 PM
  21. 14-03-2013, 09:47 PM
  22. 14-03-2013, 02:17 PM
  23. 19-01-2013, 07:39 PM
  24. 19-01-2013, 10:45 AM
  25. 19-01-2013, 10:37 AM
  26. 19-01-2013, 09:17 AM
  27. 21-12-2012, 11:14 AM
  28. 12-11-2012, 02:15 PM
  29. 12-11-2012, 01:24 PM
  30. 12-11-2012, 12:43 PM
  31. 12-11-2012, 12:42 PM
  32. 12-11-2012, 12:39 PM
  33. 21-10-2012, 09:24 AM
  34. 27-08-2012, 12:52 AM
  35. 01-08-2012, 12:48 PM
  36. 31-07-2012, 08:47 AM
  37. 31-07-2012, 08:07 AM
  38. 05-07-2012, 09:11 PM
  39. 05-06-2012, 10:12 AM
  1. PC Buying Guide 2012 - Q4
    By Jaskanwar Singh in forum PC Components / Configurations
    Last Post: 10-06-2013, 02:28 AM
  2. Preview and Feedback [August 2012]
    By r4gs in forum Feedback
    Last Post: 26-08-2012, 04:22 PM
  3. By Demand [August 2012]
    By r4gs in forum By Demand
    Last Post: 30-07-2012, 05:34 PM
  4. mobile buying guide
    By iinfi in forum Buying Advice
    Last Post: 07-05-2009, 09:59 PM
