| Forum |
| Buying Advice Sub-section for Buying Advice queries. |
#2 (permalink) |
Most probably it is a firmware problem. Take it to the service centre and have the firmware reinstalled. The latest version AFAIK is 5.27 (You can know your firmware version by pressing *#0000# in the standby screen)
#3 (permalink) |
The most probable reason according to me is CommWarrior. Its a virus and spreads thru bluetooth. The solution is to format ur mobile - do this by first powering off ur phine and then pressing[*]+[Green Dial Key]+[3]+[Power].
after this ur phone shud format by itself and the virus be gone. |
#4 (permalink) |
To avoid such problem in future dont install any application from an untrusted source. Also install a good antivirus on your phone. If you want some good software for your phone including an antivirus - jus mail me at < a1sum[at]rediffmail.com > or YIM at sbluehawk
#5 (permalink) |
Yes Its Because of CommWarrior.A
It's a one hell of a program. Tested by myself... It drains your battery, and it drains your account The Better Way to delete is use fexplorer,seleq etc to delete these virus files if u u dont want to format The virus drops these files: X\system\apps\CommWarrior\commwarrior.exe X\system\apps\CommWarrior\commrec.mdl X\system\updates\commrec.mdl X\system\updates\commwarrior.exe X\system\updates\commw.sis X is the drive "C" ur phone memory or Ur card "E" ur card memory Drive check both the drives,if u dont know where u had installed this This is better thn formatting and loosing data,i personally tried many viruses on my nokia 3230,to see their effect!! Hope this will help you!! |
#6 (permalink) |
WAT DO U MEAN U TRIED VIRUSES ON NOKIA
U mean antivirus softwares ehh??? No one wud be crazy enuf to literally infect his fone viruse
The real and only freedom is Public Domain. Everything else in unfree! Even those who claim to be the self styled evangelists of freedom are not free because freedom cannot be forced by any means! |
#9 (permalink) |
dexter boy genius.name shiv manas. created a home surveillance system using pc and normal gadgets.was featured in digit in 2003.was active in forums in 2003 when i joined.became 1st member moderator.
loks like hes busy nowadys.used to give very nice tips. his last post as far as i remember was pocket firefox. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
