03-02-2012, 09:08 PM
#421 (permalink)
Re: ** ~10k mobile advice thread **
Oh fine....I prefer to go for Optimus Net not that dual one......I actually meant the screen clarity....
03-02-2012, 09:15 PM
#422 (permalink)
Both dual sim and the normal version are complete same. Before making final decision try to use both the phones at a shop or mall. That should clear your doubts
04-02-2012, 05:44 AM
#423 (permalink)
Yep..I'll try it..but I still worried about the build quality...does LG have a good build quality..?
04-02-2012, 03:06 PM
#424 (permalink)
i have not used net but if lg have used same build like optimus one, build quality can only be described as premium. the backside got a rubber kind of finish though its plastic. same for front side. side got silver plastic lining which feels like aluminium but is again plastic which actually is an extension of the inside body. credit goes to LG that they didn't used any glossy plastic.
04-02-2012, 05:27 PM
#425 (permalink)
Yes. I can confirm its of same build quality as Optimus One. Just about same phone except a slightly better hardware
04-02-2012, 08:15 PM
#426 (permalink)
Is there any phone under 10k supporting android 4.0 ICS
Yes... I now dont have a PC... :sad:
:meditate:
04-02-2012, 09:06 PM
#427 (permalink)
@ndroholic
Almost all branded company phone will get unofficial ics update.. Huawei ideos u8150 and optimus one already have ics beta rom... For official update, afaik sony ericsson mini is the cheapest mobile to get...
Intel Core 2 Quad Q8400 | Asus EAH4350 HD @ 720/480 need to send for RMA| WD blue 500gb | Intel DG41RQ | 2gb DDR2 | HP DVD-RW | Creative 2.1 | SAMATRON 55V |
Samsung Galaxy Y
Garena id- pramudit
My coil Gun
04-02-2012, 10:08 PM
#428 (permalink)
Wildfire S too should get ICS. but as it is based on ARM v6 instruction set, most likely it'll get skipped by HTC along with Explorer.
05-02-2012, 12:47 AM
#429 (permalink)
But will it be capable to offer ics features , becoz all old phone are designed for froyo , ics has many features which require new hardware features
And the optimus one is two year old phone and many thing has changed since then
:meditate:
05-02-2012, 12:52 AM
#430 (permalink)
@ndroholic
According to xda developer ics has full hadware acceleration on O1 which is a major feature of ics.. But ofcourse you cant use face unlock coz it dont have front camera....
Dont know abt full feature support but newer ARMv7 apps wont work due to its ARMv6 SoC...
Samsung Galaxy Y
Garena id- pramudit
My coil Gun
05-02-2012, 12:57 AM
#431 (permalink)
Hmm .... So will we get any phone with full ics support under 10k
:meditate:
05-02-2012, 01:08 AM
#432 (permalink)
@ndroholic
AFAIK currently there is no such phone under 10K which will get full official ics support...
Samsung Galaxy Y
Garena id- pramudit
My coil Gun
05-02-2012, 01:39 AM
#433 (permalink)
ICS uses GPU to accelerate and render menu, UI. so if mobile got a GPU, it'll support ICS. currently, all Android mobile have GPU except maybe some desi craps like iball & lava.
most budget mobile still uses same SOC as Optimus One. some even with less ram and some with the processor overclocked. So even if Optimus One is a 2yr old mobile (& most likely discontinued) its not underpowered. i am using ICS on Optimus One since last month. Its lot better than gingerbread even on 600Mhz clockspeed. though credit goes to hardworking DEVs that make it possible.
Yes, it won't offer any of the new features of ICS but ICS for old mobiles are more of a evolutionary than revolutionary.
some apps are recompiled for ARM v6 SOCs like Adobe Flash but game won't work.
Optimus Hub & Xperia Mini will get ICS. Wildfire S "may" get ICS. if you check HTC's track record, WS should get ICS. Ace+ "may" get ICS too but Ace will be left out for sure. though none of these are priced anywhere near 10k, but by Q2 2012, they should be priced close to 10k.
05-02-2012, 07:49 PM
#434 (permalink)
I need a mobile for my dad...
Bar type
Brand: Nokia
Price : Below 7k
Full touch
I'm waiting for your's..........................
waiting for your reply guys
05-02-2012, 08:08 PM
#435 (permalink)
@ndroholic
i know that but the list of recompiled apps is negligible....
Samsung Galaxy Y
Garena id- pramudit
My coil Gun
05-02-2012, 08:34 PM
#436 (permalink)
Bar type
Brand: Nokia
Price : Below 6k
Keypad Type ( not QWERTY )
also my suggestion
Nokia asha 300 @ 6800
nokia c2-01 @ 4120
nokia c3 @ 6145
nokia x2 @ 4810
at 6k or below with normal keypad only 1 suggestion is there: Samsung Primo.
Asha doesn't have a D-PAD so all sort of navigation has to be done using only the touchscreen. consider that point first.
05-02-2012, 09:23 PM
#437 (permalink)
Can i go for this If i want to go for a touch phone...????
Samsung Wave S5253 @ 6k
Sony Ericsson Mix Walkman WT13i @65K
05-02-2012, 10:24 PM
#438 (permalink)
Wave is lot better than lowend SE mobiles. Wave is basically a dumbphone is a smartphone cover.
06-02-2012, 12:57 AM
#439 (permalink)
Android Addicted
At 65k  I will purchase 2 Galaxy Note or Apple Iphone 4G! lolz
To Much Ego Can Kill Your Talent! :)
06-02-2012, 05:17 AM
#440 (permalink)
sorry mate...that is 6.5k
06-02-2012, 11:39 AM
#441 (permalink)
FUBAR.
There's no such thing called iPhone 4G
Inactive. For a year.
Twitter
10-02-2012, 08:27 PM
#442 (permalink)
sam need some advice for a friend who needs a mobile for under 10k.
Important thing is Camera I mean it needs to have good camera. not much into gaming.
10-02-2012, 09:54 PM
#443 (permalink)
Galaxy Fit? have check pics clicked with this mobile. Impressive even if it lacks flash. though low light clicks are out of question anyway.
else nearest possible option is Fire XT @ <12k but picture quality is not good. else are 2 more options Wildfire S, Optimus Hub & @ ~12.5k
11-02-2012, 08:45 PM
#444 (permalink)
Guys I'm too worried about the brand LG....Reliability , service etc
The spec of LG optimus Net seems to be far better than the rest @ that price. But can you please specify the next best mobile to buy under 10 k...?
11-02-2012, 08:57 PM
#445 (permalink)
There is Galaxy Fit, Galaxy Y. But both have lot less RAM when compared to Optimus Net.
The Camera on Fit is 5 mp. Galaxy Y its 3. But Fit is a old phone. Get a Galaxy Y if you dont get Optimus NEt.
People might say to go for Dell XCD. But I would say to avoid it. Its just a rebranded ZTE
11-02-2012, 09:26 PM
#446 (permalink)
LG service is good. Don't worry. When my phone P500 was bricked, they gave it back after about 7 days (after replacing the motherboard).
COMMON SENSE, Y U NO SO COMMON?
11-02-2012, 09:29 PM
#447 (permalink)
Samsung = LG = Nokia = proper service in India.
LG wins in build quality hands down in the 10k & below section. i got only 3 complain against LG:
1) 1500mah battery that drains really fast. but depends as i am a heavy user.
2) LG mobile is never tuned for performance as Samsung mobile with similar specs scores more in benchmark.
3) Lastly, if LG wants to pack bloatware, they better pack some usable one. not hyper crappy sh*ts.
Lastly, this sounds odd but true. LG mobiles are best supported by DEVs. look at Galaxy Fit's XDA DEV section. got a ton of rom but most are either beta or alpha. on the other hand Optimus One got a ton of rom but most are perfectly stable and have some really good tweaks and scripts. same is true for Optimus 2X.
also idk why but Fit is not supported by Clockworkmod team (you must have it to use custom rom). a few days ago tried installing clockworkmod recovery on a friend's Fit but software doesn't recognizes mobile properly and keeps offering Huawei & some nameless options to select.
300-350Mb but enough for daily use. in my mobile 300Mb ram is always free  if i could have, i'll allocate another 100Mb to the GPU  (around 95Mb is shared by GPU)
Y got 2Mp.
discontinued hence finding one will be really difficult. also not recommended. better choice is HTC Explorer.
11-02-2012, 11:13 PM
#448 (permalink)
You guys are giving hell lot of support for Optimus Net...so I'll go for it....
Then another request I need a non android mob ranging below 7.5 K be it a full touch screen.
Usage - Music , calls
11-02-2012, 11:24 PM
#449 (permalink)
at 7.5k, Wave Y?
12-02-2012, 06:08 AM
#450 (permalink)
any other competitors....I need some more options./..?
